26
I'm in the process of creating my own programming language, which I do for learning purposes. I already wrote the lexer and a recursive descent parser for a subset of my language (I currently support mathematical expressions, such as + - * / and parenthesis). The parser hands me back an Abstract Syntax Tree, on which I call the Evaluate method to get the result of the expression. Everything works fine. Here is approximately my current situation (Code examples in C#, although this is pretty much language-agnostic):
public abstract class Node
    public abstract Double Evaluate();
public class OperationNode : Node
    public Node Left { get; set; }
    private String Operator { get; set; }
    private Node Right { get; set; }
    public Double Evaluate()
        if (Operator == "+")
            return Left.Evaluate() + Right.Evaluate();
        //Same logic for the other operators
public class NumberNode : Node
    public Double Value { get; set; }
        return Value;
However, I would like to decouple the algorithm from the tree nodes because I want to apply Open/Closed Principle so I don't have to reopen every node class when I want to implement code generation for example. I read that the Visitor Pattern is good for that. I have a good understanding of how the pattern works and that using double dispatch is the way to go. But due to the recursive nature of the tree, I'm not sure how I should approach it. Here is what my Visitor would look like:
public class AstEvaluationVisitor
    public void VisitOperation(OperationNode node)
        // Here is where I operate on the operation node.
        // How do I implement this method?
        // OperationNode has two child nodes, which may have other children
        // How do I work the Visitor Pattern around a recursive structure?
        // Should I access children nodes here and call their Accept method so they get visited?
        // Or should their Accept method be called from their parent's Accept?
    // Other Visit implementation by Node type
So this is my problem. I want to tackle it immediately while my language does not support a lot of functionnality to avoid having a bigger problem later.
I did not post this to StackOverflow because I don't want you to provide an implementation. I only want you to share ideas and concepts that I might have missed, and how I should approach this.
marco-fiset
  • 8,721
  • 35
It is up to the visitor implementation to decide whether to visit child nodes and in which order. That's the whole point of the visitor pattern.
In order to adapt the visitor for more situations it is helpful (and quite common) to use generics like this (it's Java):
public interface ExpressionNodeVisitor<R, P> {
    R visitNumber(NumberNode number, P p);
    R visitBinary(BinaryNode expression, P p);
And an accept method would look like this:
public interface ExpressionNode extends Node {
    <R, P> R accept(ExpressionNodeVisitor<R, P> visitor, P p);
This allows to pass additional parameters to visitor and retrieve a result from it. So, the expression evaluation can be implemented like this:
public class EvaluatingVisitor
    implements ExpressionNodeVisitor<Double, Void> {
    public Double visitNumber(NumberNode number, Void p) {
        // Parse the number and return it.
        return Double.valueOf(number.getText());
    public Double visitBinary(BinaryNode binary, Void p) {
        switch (binary.getOperator()) {
        case '+':
            return binary.getLeftOperand().accept(this, p)
                + binary.getRightOperand().accept(this, p);
        // More cases for other operators here.
The accept method parameter isn't used in the above example, but just believe me: it is quite useful to have one. For example, it can be a Logger instance to report errors to.
lorus
  • 497
I have implemented the visitor pattern on a recursive tree before.
My particular recursive data structure was extremely simple - just three node types: the generic node, an internal node that has children, and a leaf node that has data. This is much simpler than I expect your AST to be, but perhaps the ideas can scale.
In my case I deliberately did not let the Accept of a node with children call Accept on its children, or to call visitor.Visit(child) from within the Accept. It is the responsibility of the correct "Visit" member implementation of the visitor to delegate Accepts to children of the node being visited. I chose this way because I wanted to allow different Visitor implementations to be able to decide the order of visitation independently of the tree representation.
A secondary benefit is that there are almost no artifacts of the Visitor pattern inside my tree nodes - each "Accept" just calls "Visit" on the visitor with the correct concrete type. This makes it easier to locate and understand the visiting logic, it's all inside the visitor implementation.
For clarity I've added some C++-ish pseudocode. First the nodes:
class INode {
  public:
    virtual void Accept(IVisitor& i_visitor) = 0;
class NodeWithChildren : public INode {
  public:
     virtual void Accept(IVisitor& i_visitor) override {
        i_visitor.Visit(*this);
     // Plus interface for getting the children, exercise for the reader ;-)
 class LeafNode : public INode {
   public:
And the visitor:
class IVisitor {
  public:
     virtual void Visit(NodeWithChildren& i_node) = 0;
     virtual void Visit(LeafNode& i_node) = 0;
class ConcreteVisitor : public IVisitor
  public:
     virtual void Visit(NodeWithChildren& i_node) override {
       // Do something useful, then...
       for(Node * p_child : i_node) {
         child->Accept(*this);
     virtual void Visit(LeafNode& i_node) override {
        // Just do something useful, there are no children.
Joris Timmermans
  • 8,998
  • 60
    +1 for `allow different Visitor implementations to be able to decide the order of visitation`. Very good idea. – marco-fiset Mar 06 '13 at 15:52
  • @marco-fiset The algorithm (visitor) will then have to know how the data (nodes) are structured. This will break down the algorithm-data separation that the visitor pattern gives. – B Visschers Dec 26 '14 at 12:30
    @BVisschers The visitors implement a function for each node type, so it knows which node it operates on at any given time. It does not break anything. – marco-fiset Dec 31 '14 at 15:20
You work the visitor pattern around a recursive structure the same way you would do anything else with your recursive structure: by visiting the nodes in your structure recursively.
    public int SomeProperty { get; set; }
    public List<OperationNode> Children { get; set; }
public static void VisitNode(OperationNode node)
    ... Visit this node
    foreach(var node in Children)
         VisitNode(node);
public static void VisitAllNodes()
    VisitNode(rootNode);
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
  • This can fail for parsers if the language has deeply nested constructs - it can be necessary to maintain a stack independently of the language's call stack. – Pete Kirkham Mar 06 '13 at 15:56
    @PeteKirkham: That would have to be a pretty deep tree. – Robert Harvey Mar 06 '13 at 15:56
  • @PeteKirkham What do you mean it can fail? Do you mean some kind of StackOverflowException or that the concept won't scale well? For the moment I don't care about performance, I only do this for fun and learning. – marco-fiset Mar 06 '13 at 16:05
  • @marco-fiset Yes, you get stack overflow exception if you say, try to parse a large, deep XML file with a visitor. You'll get away with it for most programming languages. – Pete Kirkham Mar 06 '13 at 18:49
