15
I am developing an application which will need to store inline, intext metadata. What I mean by that is the following: let's say we have a long text, and we want to store some metadata connected with a specific word, or sentence of the text.
What would be the best way to store this information?
My first thought was to include in the text some kind of Markdown syntax that would then be parsed on retrieving. Something looking like this:
Lorem ipsum dolor sit amet, consectetuer adipiscing elit,
sed diam __nonummy nibh__[@note this sounds really funny latin]
euismod tincidunt ut laoreet dolore magna aliquam erat volutpat.
This would introduce two problems I can think of:
  1. A relatively small one, is that if said syntax happen to be fortuitously on the said text, it can mess with the parsing.
  2. The most important one is that this doesn't maintain this metadata separate from the text itself.
I would like to have a discrete data structure to hold this data, such a different DB Table in which these metadatas are stored, so that I could use them in discrete ways: querying, statistics, sorting, and so on.
EDIT: Since the answerer deleted his answer, I think it might be good to add his suggestion here, since it was a workable suggestion that expanded on this first concept. The poster suggested to use a similar syntax, but to link the metadata to the PRIMARY KEY of the metadata database table.
Something that would look like this:
sed diam __nonummy nibh__[15432]
Where 15432 would be the ID of a table row containing the necessary, queriable information, as per example below.
My second thought was to store information of this kind in a DB Table looking like this:
TABLE: metadata
ID    TEXT_ID    TYPE    OFFSET_START    OFFSET_END    CONTENT
1     lipsum     note    68              79            this sounds really funny latin
In this way the metadata would have a unique id, a text_id as a foreign key connected to table storing the texts and it would connect the data with the text itself by using a simple character offset range.
This would do the trick of keeping the data separated from the metadata, but a problem that I can immediately see with this approach is that the text would be fundamentally not editable. Or, if I wanted to implement the editing of the text after the assignation of metadata, I would basically have to calculate characters additions, or removal compared to the previous version, and check whether each of this modifications adds or remove characters before or after each of the associated metadata.
Which, to me, sounds like a really unelegant approach.
Do you have any pointers or suggestions for how I could approach the problem?
Edit 2: some XML problems
Adding another case which would make quite necessary for this separation of data and metadata to happen.
  • Let's say I want to make it possible for different users to have different metadata sets of the same text, with or without the possibility of each user actually displaying the other user metadata.
Any solution of the markdown kind (or HTML, or XML) would be difficult to implement at this point. The only solution in this case that I could think about would be to have yet another DB Table which would contain the single user version of the original text, connecting to the original text table by the use of a FOREIGN KEY.
Not sure if this is very elegant either.
  • XML has a hierarchical data model: any element which happens to be within the borders of another element is considered as its child, which is most often not the case in the data model I'm looking for; in XML any children element must be closed before the parent tag can be closed, allowing for no overlapping of elements.
Example:
<note content="the beginning of the famous placeholder"> Lorem ipsum dolor sit <comment content="I like the sound of amet/elit"> amet </note>, consectetuer adipiscing elit </comment> , <note content="adversative?"> sed diam <note content="funny latin"> nonummy </note> nibh </note> euismod tincidunt ut laoreet dolore magna aliquam erat volutpat.
Here we have two different problems:
  1. Different elements overlapping: The first comment starts within the first note, but ends after the end of the first note, i.e. it's not its child.
  2. Same elements overlapping: The last note and the boldfaced note overlap; however, since they are the same kind of element, the parser would close the lastly opened element at the first closure, and the first opened element at the last closure, which, in this circumstance, is not what is intended.
Sunyatasattva
  • 440
    It sounds a little like you're writing your own markup language. You could use HTML for which there is a well established parsing system and you can edit your text by manipulating the resulting parse tree. For database storage you could us a NoSQL db, such as Oracle's XMLDB or Mark/Logic. – ipaul Mar 03 '13 at 16:16
  • The problem is not so much practical, as conceptual. I mean, I *could* use HTML, or Markdown, or build my very simple markup language along with a parser. The problem is that I want to keep those separated. Keep the content at bare minimum, maybe just keep basic *rich-text* information inside the content, but everything else should be separate. – Sunyatasattva Mar 03 '13 at 22:18
    @Sunyatasattva what is the benefit of adding such complexity ? – Clement Herreman Mar 06 '13 at 17:33
  • @ClementHerreman Which added complexity? You mean the added complexity of keeping data and metadata separated? – Sunyatasattva Mar 07 '13 at 00:37
  • Is the text intended to be a living document, which may be changed or updated, and for which metadata will need to be maintained over several versions of the text? Or is the text to which the metadata is applied purely static and unchanging? – Kyle Lowry Mar 07 '13 at 01:06
  • I would say that right now my practical concert is over a static and unchanging text. However, thinking ahead, I would most possibly like an architecture in which I am not bound by this decision, and implementing the changing of the text would not need a complete rewrite (of course it might need loads of work anyways). The metadata should stay for the *revisions*, but should stay **reasonably glued** to the position in the text (I would say to particular words and sentences). – Sunyatasattva Mar 07 '13 at 01:14
  • It sounds to me like you need to be doing some kind of processing on the text itself to identify words, regions, phrases, etc., with some kind of fuzziness. Perhaps coming up with an identifier system that was based on fuzzy matching. Each metadata item would be associated not to a discrete ID#, word ID#, or absolute position, but rather to a group of fuzzy criteria (e.g. relative position in document, applies to this word/general sequence of words, etc). This would need more processing, and would need to involve AI/heuristics given the kinds of changes that could be made to text over time. – Kyle Lowry Mar 07 '13 at 20:54
I'd go for a mix of your solutions, but instead, I'd use a standard : XML. You'd have a syntax like this one
sed diam <note content="It sound really funny in latin">nonummy nibh</note>
Why XML
If you think about it, it's exactly how the whole web is structured : content (actual text) that carries semantic - what you're calling metadata - through html tags.
This way you have a really cool world that opens :
  • Free parser
  • Battle tested way to add metadata to content
  • Ease of use (depending on which users you are targeting)
  • You can easily extract the raw text, without the metadata, as it's a standard features on XML parsers. That is very useful to have an indexable version of your content, so Lorem <note>ipsum</note> is raised when you are searching for lorem ips* for example.
Why XML over Markdown
A website like stackexchange uses markdown as the semantics its content convey is rather basic : emphasis, links/urls, image, header etc. It seems the semantic you're adding to your content is
  1. More complex
  2. Subject to change or must be extensible
Thus I sense Markdown wouldn't be a really good idea. Also Markdown isn't really standardized, and parsing/dumping it might be a pain in the ass, even more a markdownish syntax see Jeff Atwood's post about the WTF he met on parsing Markdown.
On separation between data and metadata
Per se, such separation isn't mandatory. I assume you are looking for the advantage it brings:
  • Possibility to have the raw content without the metadata
  • Separation of concerns: I don't want to have side-effect/complexity overhead when manipulating metadata because of the data, and otherwise.
All these concerns are cleared by the use of XML. From the XML, you can easily dump any tag-stripped content, and data/metadata are separated, just like attribute and actual text is separated in XML.
Also I don't think you can really have your metadata totally not bound to your data. From what you describe, your metadata are a composition of your data, ie deleting the data leads to metadata deletion. This is where you metadata diverge from the usual HTML/CSS. CSS doesn't disapear when an html element is removed, because it can be applied to other elements. I don't feel this is the case in your metadata.
Having metadata close to the data, as in XML or Markdown, allow an easy understanding (and maybe debugging) of the datas. Also, the example you give on your second thought add some complexity, because for each data I'm reading, I need to query the metadata table to get these. If the relation between your data and your metadata is 1:1 or 1:N, then it's IMO clearly useless, and only brings complexity (a good case of YAGNI).
Clement Herreman
  • 778
  • Another advantage I am looking for is **being able to use the metadata independently**, this means querying just metadata, without caring about the content. Why would the relationship data:metadata of 1:n “clearly be useless” in your opinion? – Sunyatasattva Mar 07 '13 at 00:49
  • Let's add another case that makes any use of any *metadata inside the data* solution useless: I want to make it possible for a single text to have metadata from different users, which may (or may not), be able to see other users' metadata. – Sunyatasattva Mar 07 '13 at 00:50
  • I elaborated a bit on this in my new edit. – Sunyatasattva Mar 07 '13 at 00:57
  • +1 This is exactly what SGML and XML were designed for. – Ross Patterson Mar 08 '13 at 22:21
  • I think a problem is that, as far as I know, in XML any element which happens to be inside another is considered **child** of the element, and overlapping of tags is not possible (i.e., *you have to close the children before closing the parent*). In my case there is no such hierarchical structure, as two notes can certainly overlap (added example at the end of my answer). – Sunyatasattva Mar 09 '13 at 22:37
The Solution Use Case
I disagree with some of the other answers, simply because, while great solutions, they are probably not your solution. Yes XML has the word markup in it's acronym, but it is probably not ideal for your situation. It is way too complex, it offers little assistance in keeping the meta data separate from the original text. Essentially it will turn everything into a form of metadata, creating one overweight data-set.
Since there is likely no absolutely correct solution or approach, the best solution answers the question:
How will the data be used by the system?
Also, if you try and ask, how a solution design could inherently add to the value of the system, in the way that it will be used, then you are closer to finding your elegant answer.
Understanding the problem
Ok enough commentary, let's dig into the problem. This is the problem as I understand it is (obviously adding to this will be beneficial):
  • There is an original text
    • Assumptions about this original text:
    • This text, may or may not be made up of several independent documents
    • This text, may or may not be edited by one or more users
    • This text, contains related information. By that I am assuming (correct me if I am wrong) that the metadata is related and not descriptive. So it stores information related to the original text, and not information that describes the text. So it will store notes about the original text, and not by example describe that the text is a heading that is bold and is a link to a website, etc.
    • The text should be easily filtered distinct from the metadata
    • The text should be protected from being corrupted by, and corrupting the metadata
  • There should be a means of storing information related to the original text (metadata)
    • This metadata also needs it's own (meta)metadata, that would hold information such as which user's (or groups?) the meta data is relevant for, such as a description of the metadata, say weather it is a note, or comment, or description etc.
    • This metadata (and it's (meta)metadata) need to withstand alterations in the original text, alterations of the metadata and alterations of the (meta)meta data
    • The metadata (+ Meta-Metadata) needs to be structured well and easily queried, and indexed or even joined in a relational way to other datasets. The relational nature of the metadata should not just be limited to Queries, but also facilitate updates or write back and alteration of the metadata as a result of the relational data activities.
    • The value of the metadata (+ Meta-Metadata) is in it's very related nature. It becomes immediately counter productive the moment it looses it's relation to the original text. Thus the integrity of it's relation to the original text is a mandatory design imperative.
  • Other assumptions about the nature of the problem and how it will be used are:
    • Concurrent heterogeneous system access. That is to say that the user's may wish to view the text and edit metadata, at the same time as the administrator (or another process) is performing relational data queries on the structured metadata.
    • The system will have several users
    • The system is modern. That is to say that it is not constrained by storage space, or processing speed, or real-time imperatives. The integrity and purpose focused functionality is a higher priority than physical computing resource limitations.
    • There is a (albeit low) chance that the uses and functionality of the system may evolve or change somewhat, as the system is used.
Building the solution design
Understanding the problem as I have outlined it above, I will now start to suggest possible solutions and approaches that aims to solve the above problem.
Components
So I would see that there would need to be a custom built user access system. It would filter relevant and irrelevant metadata from the original text. It would facilitate the editing and viewing of metadata into the text. It would ensure the integrity of the relationship between the metadata and it's original text. It would structure the metadata and offer a data source to a relational data system. It will most likely provide a host of other purpose driven functions.
Structure
So since it is important to keep the metadata's integrity to the original text, the best way of ensuring this, is to keep the metadata inline with the original text. This will offer the benefit that the original data can be confidently edited without breaking this integrity.
The concerns with this approach are the corruption of the metadata by the original data and vice versa. The adequate indexing and structuring of the metadata and it's (meta)metadata in a way that allows for queries and updates and efficient access. The easy filtering of metadata from the original text.
With this in mind, I would suggest that a portion of the solution be based on the approach of using ESCAPE CHARACTERS within the original text. This is not the same as designing your own Mark-up Language or using an existing Markup Language such as XML or HTML. It is easy to design an ESCAPE CHARACTER that has a zero, or near zero chance of existing in the original text.
My advice to you in this regard would be to carefully consider the original data, and try and determine the nature of the code-page that it is stored in and then look for an ideal CHARACTER or CHARACTER SEQUENCE that is unlikely or impossible to occur. For example in ASCII there are literally built-in control characters with byte values that are never used in standard user interfaces. The same can be said for a font based or relational data based information system. Just be careful with binary data codecs. Depending on the nature of the original data it may be valuable to build a parser that confirms the discovery of a control sequence, perhaps by looking at the data that is escaped and verifying it's integrity, either with a simple inspection of the structure of the escaped data, or even by including a control character that is calculated for each escaped data sequence.
Example Data With Escape Sequences
This is a story of a man. >>>>(#)Why is this story about a man not a woman?(#)()userid::77367()Manager's Comment()DataID::234234234>>>> A man who went to mow a meadow, went to mow a meadow. The man went with his dog >>>>(#)Ask the client if the story would be better with a cat instead(#)>>>> to mow the meadow. So now this is the story of a man and his dog who went to mow a meadow.
One man and his dog, went to mow a meadow, went to mow a meadow, a meadow reached over the mountain. >>>>(#)This sounds alot better with a forest(**)Suggestion Note(#)>>>>
The man and his dog and his mission, to mow a meadow, a meadow reached over the mountain is only reached when crossing the river.
Example Data Without Escape Sequences
This is a story of a man. A man who went to mow a meadow, went to mow a meadow. The man went with his dog to mow the meadow. So now this is the story of a man and his dog who went to mow a meadow.
Obviously this is easily parsed, not complex as an entire Mark-up language and easily adaptable to your purpose.
Solved Yet? Well, I would say no. Our solution still has some holes. The indexing and structured access of this data is poor. Also, it would not be reasonable to query this file (or several files) at the same time as editing it.
How could we solve that problem?
I would suggest a DATA ALLOCATION TABLE as a document header. I would also suggest implementing a TRANSACTIONAL TABLE UPDATE QUEUE. Let me explain. The designers of a file system, particularly a rotational disk file system, faced similar design challenges to the ones you have described above. They needed to embed information about the files on the disk with, along with the data. A great solution to the relationship integrity of this data, was to DUPLICATE it in a File Allocation Table (FAT).
This means that for each individual Metadata Item, there is a corresponding entry in the Data Allocation Table. So it is fast, structured and relational, and independent of the original data. If queries or joins or updates need to be performed on the metadata, then it is easily done by simply accessing the Data Allocation Table.
Obviously care must be given to ensure that the original in-line metadata is a true reflection of the Data Allocation Table data. That is where a Transactional Table Update Queue comes in. Every change, addition or removal of metadata, is made not on the data it'self, but rather on the queue. the queue will then ensure that either all the changes are made to both the in-line and table data, or no change is made at all. It also allows for asynchronous updates to be performed, for example, all the metadata of a certain user can be deleted by running a delete command on the queue. If the inline metadata was locked and in use, the queue would not perform any changes until it could do it to both the Table data and the inline data.
yannis
  • 39,547
  • 40
  • 183
  • 216
Stephen
    Hi Stephen and welcome to Programmers! While I appreciate the enthusiasm in your answer, I had to remove the irrelevant commentary from it. We prefer answers to be as concise, precise and to the point as possible, to be more accessible to a wider audience. – yannis Mar 08 '13 at 20:54
  • First of all, I must say that I liked the enthusiasm in the answer, it was great to hear such good feedback. As for the answer itself, I must say that I would be against same syntax for opening and closing the tags; and perhaps, to avoid the XML problem I described above in my most recent update, I would specify what's being opened and what's being closed in the tag itself; perhaps like so: `>>>>>(#1) Lorem ipsum (#1)>>>>>>`. Also, it seems like your approach in intext comments would have them bind to a certain fixed position, how would that work if the offset is moved? – Sunyatasattva Mar 10 '13 at 20:18
  • Also, how would you go and approach the fact of binding the comment to an **offset-range** instead of a precise point? Last but not least: the data allocation table and transactional update queue seem amazing concepts. I did some research about the topics, but could you elaborate a bit on how you would go and implement those concepts in this architecture problem? – Sunyatasattva Mar 10 '13 at 20:20
This is a typical kind of engineering question in that all your options have different tradeoffs, and which is best depends on what is important to you. Unfortunately, you haven't given enough information to make the determination.
You also haven't appeared to consider an important semantic problem. Lets say the original text is
My friend Bob lent me five dollars
Someone adds a comment around "Bob" saying
Bob is a complete idiot
Then the original text is edited to
Jane lent Bob five dollars which he later lent to me
You might make some sense of this particular case using a text matching algorithm such as what is used to show a diff file, but character offsets are going to make the metadata attach to the "Jan" in "Jane".
Worse is if the text is edited to
My friend Steve lent me five dollars
You could manage to figure out how to attach the metadata to "Steve", but how do you know if it applies?
Also, have you decided if the metadata itself can have metadata? That might change your implementation.
Beyond semantic issues, it isn't very clear what you are doing with the data. I thought perhaps it was very inconvenient to have the original text "polluted" with any markup, but then you were sort of OK with having ID values in it. Which doesn't make a lot of sense if the metadata applies to a section of text instead of being inserted into a point in the text.
My guess is that for most purposes storing marked up text is easier, or, second choice, going all SQL and having the text and markup represented by a node hierarchy - basically a DOM in table form. If your data is hierarchical than it may be easier to use XML and get existing parsers for free, versus writing your own.
It is quite possible that there is some fairly simple solution that is good enough for your exact situation, but I can't tell you what that is because it really depends on just what you are trying to do, in detail.
I would strongly suggest you encapsulate whatever strategy you choose as much as you can, though this is fairly hard to do if much of your implementation needs to be visible to many SQL queries.
Sorry that the reply is so scattered and so full of "it depends", but real world design questions are like that.
psr
  • 12,846
  • 39
  • 67
  • I understand, and I am not looking for a precise, correct, answer. But for ideas of implementation, analysis of the tradeoffs, or perhaps I thought there was an answer which was *better* than others and I just wasn't thinking of it. To answer the question you pose: no, in my case the metadata itself will not have any metadata. – Sunyatasattva Mar 07 '13 at 00:36
  • What's *better* depends on what you trying to do. – psr Mar 07 '13 at 00:44
  • What other detail do you reckon are missing from my question to give you a clear picture? – Sunyatasattva Mar 07 '13 at 00:51
  • More than you could reasonably explain. How important is it to have metadata about a section of text vs an insertion point, how important is keeping the text together in one field in the DB, how often is each edited, how much will queries be analysis in straight SQL vs. pulling the text then analyzing later and what is your comfort level with each, what scale does this happen at, what is likely to change over time, if you go with markup are you comfortable writing your own simple parser or would you do better with XML, which is less customized but has more tools... – psr Mar 07 '13 at 20:19
  • Which is why I can only offer guidelines. Especially since the answer is meant to possibly help others in similar situations, not only you. – psr Mar 07 '13 at 20:19
I think the suggestion from the previous answerer, the one you mentions on you question) is a very good one.
It would behave the same way we post links on the StackExchange sites, but the info data would be on another table. The benefits are, you have the data separated, and therefore queryable and indexable. On edit the text, you can check for deleted metadata IDs and clean the metadata table.
The only small problem like you said is the parsing, but you can deal with it pretty easily.
RMalke
  • 727
  • What previous answer? The order of answers presented isn't guaranteed to be in any order - or for that matter, the answer may be radically changed or deleted to make yours less useful. Could you modify your question such that it doesn't need to reference another answer? –  Mar 06 '13 at 17:39
  • I mean, the previous answer mention by the OP in the question – RMalke Mar 06 '13 at 17:47
Lets say I have a text:
Lorem ipsum dolor sit amet, consectetuer adipiscing elit, sed diam nonummy nibh euismod tincidunt ut laoreet dolore magna aliquam erat volutpat.
I add the note like this:
Lorem ipsum dolor sit amet, consectetuer adipiscing elit, sed diam [@123,#456,2w]nonummy nibh euismod tincidunt ut laoreet dolore magna aliquam erat volutpat.
[@123,#456,2w] means: user_id=123, note_id=456, and the text marked by this note spans for the next 2 words (could be chars (c), sentences (s), paragraps (p) or whatever). Exact syntax may be different, of course.
In plain text editors notes' text can be easily stored at the end of the document, just like with Markdown footnotes.
In rich text editors this kind of note can be displayed in the text as an icon, and marked text can be highlighted in some way. User can then delete such notes just as normal characters with Del or Backspace, and edit them with some kind of special editing mode. I imagine resizing noted areas with a mouse and editing note text with popup window.
Pros:
  • Goes nicely with "intersections" since you mark an offset (implicitly by note's position in the text) and a length for each note.
  • Supports multiuser environment. (In fact, this needs some deeper research and you'd probably have to deal with something like Google Wave operational transformations, which my brain cannot handle.)
  • Can be edited with both rich and plain text editors.
  • You can easily handle revisions, since all markers are in-place - when you edit the text before a marker, marker just shifts along with other text.
  • Easy to parse.
  • No need for external DB, but you can still use one if you want.
  • Can be mixed with Markdown or XML if you choose some unobtrusive syntax.
Cons for plain text editing:
  • You can't see areas in text marked with notes (unless you highlight plaintext, which is an option too), but just the places where notes start. This is compensated by the ability to choose arbitrary length units: chars, words, sentences, paragraphs.
  • You can edit the text under a note without noticing, especially if a note spans quite long (e.g. 2+ paragraphs). Can be compensated by revison control mechanism which compares a text under each note with it's previous version and notifying a user if it was changed.
General cons:
  • Troubles with multiple users editing the same text, but I think it is inavoidable anyway. I'm not an expert in this field.
scriptin
  • 4,432
  • 32
  • What is in your opinion the pro of not adding a closure tag but working with offsets? Isn't it too risky? What if I add a word between `nonummy` and `nibh`, wouldn't it mess up with my offsets? – Sunyatasattva Mar 10 '13 at 02:39
  • Yes, that could mess with an offset and that issue can be solved in a rich text editor with "virtual" end-of-note marker, which acts exactly like start marker, except it cannot be edited explicitly (it's just there to mark an end-of-note, shifting along with the edited text) and it is not saved with the text. You just insert it while editing and then drop it when saving. Generally, I think there might be even more problems with both start and end markers then with just only one of them, but of course I may be wrong. – scriptin Mar 10 '13 at 09:50
