31
I have some C++ knowledge and know that pointers are commonly used there, but I've started to look at PHP open source code and I never see code using references in methods.
Instead, the code always uses a return value instead of passing the reference to the variable to the method, which then changes that variable's value and just returns it.
I have read that using references uses less memory, so why aren't they used in PHP?
Alexander Cogneau
  • 453
    Using pass-by-reference parameters is "side-effect programming" - using a function to return a single value is significantly clearer when reading code. That said, quite a few PHP core functions use references. – halfer Feb 28 '13 at 15:58
    PHP passes objects by reference by default. –  Feb 28 '13 at 16:04
    array sorts are a prime exanmple of core PHP functions that pass by reference – Mark Baker Feb 28 '13 at 16:05
    PHP references are _not_ pointers, and are often a pain in the ass if you aren't fully expecting them where they appear. – lanzz Feb 28 '13 at 16:07
    If you need multiple returns, `return array($foo, $bar);` and `list($A, $B) = foobar();` – Izkata Feb 28 '13 at 17:35
7 Answers7
53
Your assertion that references are rarely used is incorrect. As others have already mentioned there's a ton of native functions that use references, notable examples include the array sorting functions and preg_match() / preg_match_all(). If you are using any of these functions in your code, you are also using references.
Moving on, references in PHP are not pointers. Since you're coming from a C++ background I can understand the confusion, but PHP references are an entirely different beast, they are aliases to a symbol table. Any performance gains you might have expected from C++ references simply don't apply to PHP references.
In fact, in most scenarios passing by value is faster and less memory intensive than passing by reference. The Zend Engine, PHP's core, uses a copy-on-write optimization mechanism that does not create a copy of a variable until it is modified. Passing by reference usually breaks the copy-on-write pattern and requires a copy whether you modify the value or not.
Don't be afraid to use references in PHP when you need to, but don't just do it as an attempt to micro-optimize. Remember, premature optimization is the root of all evil.
Further reading:
yannis
  • 39,547
  • 40
  • 183
  • 216
  • Thanks for the correction @NikiC. Bit of a lazy answer this one... – yannis Mar 02 '13 at 09:26
  • To complete the answer, it'd be nice to point out that all objects are passed by reference in PHP. – Florian Margaine Mar 02 '13 at 09:40
  • @FlorianMargaine That's not entirely accurate (see second link in further reading). – yannis Mar 02 '13 at 09:42
  • That's pretty similar though. – Florian Margaine Mar 02 '13 at 09:45
    @FlorianMargaine No, the two are very different and it's important to realize why that is so. – phant0m Mar 02 '13 at 12:05
  • From a user point of view, they're the same. – Florian Margaine Mar 02 '13 at 12:29
  • "Passing by reference usually breaks the copy-on-write pattern and requires a copy whether you modify the value or not." <- source? to my knowledge this is not the case — in many scenarios passing references won't be faster or use less memory than passing by value thanks to the copy-on-write mechanism, but I've never heard of references creating a copy by default. – Mahn Mar 04 '13 at 22:52
    @FlorianMargaine No, suppose objects *were* passed by reference in PHP: `f($obj)` given `function f($x) { $x = new X; }`, would have `$obj` refer to a *different* object than before the call to `f()`. However, since objects *aren't* passed by reference, $obj isn't modified if you were to execute this with PHP. In that way, PHP does the same as Java. – phant0m Apr 23 '13 at 09:27
  • See also https://schlueters.de/blog/archives/180-References-Still-bad-in-PHP-7.html – Mikko Rantalainen Mar 28 '18 at 07:06
PHP already does a copy-on-write thing where it doesn't create a new value til you change something, so there's not much memory saved by using references. Doing so can even mess with some stuff PHP does internally to reduce memory usage, making things even worse.
Add to that the fact that references make things a bit too magical in general. The default, and thus what most people expect, is pass-by-value; when i pass $i to a function, it complicates things tremendously to have to care whether that function mysteriously changes $i to something else entirely, and thus make defensive copies just in case. (It can already modify $i if the value is an object, but in my opinion it shouldn't.)
Basically, i'd only find pass-by-reference useful for "out" parameters, meaning variables i expect to get back from the function rather than pass in, a la preg_match's &$matches. Even for functions that clearly modify the object being passed in, like sort or array_pop, that feels a bit icky...but that's what we're stuck with.
cHao
  • 1,030
PHP is a web-oriented language.
Web-pages being served fast and should be lightweight.
Usual PHP program lives fraction of second and consume few hundred kilobytes of memory.
There is no use for such optimizations.
Some reasons on the fly :
  • PHP is a scripting language, and doesn't aim to be used as a core embedded software (basically, memory is cleared at the end of the script),
  • Since PHP5, pass-by-reference is implicit for object parameters (so PHP uses pass-by-reference "in your back").
AlterPHP
  • 147
I think this is just a choice of the developers, nothing to do with the language. Plenty of PHP code (built-in and not) use references. Take a look at the array functions in PHP, lots of those use references. preg_match uses references.
I think one of the reasons developers choose not to use references is because it can be confusing. You call a function and one of the variables may (or may not) be updated because it was a reference. So, when you debug, it may not be clear why the value of $x jsut magically changed.
gen_Eric
  • 121
The fundamental problem with your question is that you assume that this is common in C++, too. It isn't. We don't like output parameters and use them as little as possible- they're only really common in C-style APIs.
DeadMG
  • 36,794
  • 70
  • 139
I know many php functions that do so. Have a look at preg_match() for instance. $matches will be passed by reference
If you want write a function for yourself that takes arguments by reference then use the following syntax
function byref(&$a, &$b, $c) {
    $a += $c;
    $b += $c;
    return $a * $b;
$a and $b are passed by reference $c is passed by value.
hek2mgl
  • 109
