In general, should I use some sort of convention for structure names which is distinct from other type name? I was thinking about this when my professor started talking about structures.
I had the following discussion with myself, and since I do not want to come to any unreliable conclusions. How would you answer the question(s) and which answer(s) are untrustworthy?
Q: Should I distinguish structure names and type names to make the code more clear?
A: A structure is a type, so there doesn't need to be a distinction.
RE: Q: So there is never a case when someone uses typedef int SOMETYPE
to rename a built-in type to make the code more flexible?
RE: A: There is no practical reason to rename built-in types. Actually, defining int
types as SOMETYPE
makes the code less readable because someone reading the code will not know the built-in type used for that type.
Honestly I do not trust either answer. Looking at some of the base structure in a new Win32Project using Visual Studio, I see things like typedef short HFILE;
which, I guess, makes it more clear to the programmer what the variable is used for. Perhaps that is too subjective however.
As an aside, how does one usually determine what is going on when they come across variable declarations which use types you have never seen before. Do you just rely on the IDE to take you to or display the declaration?
