This idea simply amounts to a "Self_Test" method within the context of an object-based or object-oriented design. If using a compiled object-based language like Ada, all the self-test code will be marked by the compiler as unused (never invoked) during the production compilation, and therefore it will all be optimized away - none of it will appear in the resulting executable.
Using a "Self_Test" method is an extremely good idea, and if programmers were really concerned with quality they would all be be doing it. One important issue, though, is that the "Self_Test" method needs to have intense discipline, in that it cannot access any of the implementation details and must instead rely only on all the other published methods within the object's specification. Obviously, if the self test fails, the implementation will need to change. The self test should be rigorously testing all the published properties of the object's methods, but never ever relying in any way upon any details of any specific implementation.
Object-based and object-oriented languages frequently do provide exactly that type of discipline with respect to methods external to the tested object (they enforce the object's specification, preventing any access to its implementation details and raising a compilation error if any such attempt is detected). But the object's own internal methods are all given complete access to every implementation detail. So the self test method is in a unique situation: it needs to be an internal method because of its nature (self test is obviously a method of the object being tested), yet it needs to receive all the compiler discipline of an external method (it has to be independent of the object's implementation details). Few if any programming languages provide the capability to discipline an object's internal method as if it were an external method. So this is an important programming language design issue.
In the absence of proper programming language support, the best way to do it is to create a companion object. In other words, for every object you code (let's call it "Big_Object"), you also create a second, companion object whose name consists of a standard suffix concatenated with the name of the "real" object (in this case, "Big_Object_Self_Test"), and whose specification consists of a single method ("Big_Object_Self_Test.Self_Test (This_Big_Object : Big_Object) return Boolean;"). The companion object will then depend upon the specification of the main object, and the compiler will fully enforce all of the discipline of that specification against the companion object's implementation.
