I just started playing around with async/await in .Net 4.5. One thing I'm initially curious about, why is the async keyword necessary? The explanation I read was that it is a marker so the compiler knows a method awaits something. But it seems like the compiler should be able to figure this out without a keyword. So what else does it do?
There are several answers here, and all of them talk about what async methods do, but none of them answer the question, which is why async
is needed as a keyword that goes in the function declaration.
It's not "to direct the compiler to transform the function in a special way"; await
alone could do that. Why? Because C# already has another mechanism where the presence of a special keyword in the method body causes the compiler to perform extreme (and very similar to async/await
) transformations on the method body: yield
Except that yield
isn't its own keyword in C#, and understanding why will explain async
as well. Unlike in most languages that support this mechanism, in C# you can't say yield value;
You have to say yield return value;
instead. Why? Because it was added in to the language after C# already existed, and it was quite reasonable to assume that someone, somewhere, might have used yield
as the name of a variable. But because there was no pre-existing scenario in which <variable name> return
was syntactically correct, yield return
got added to the language to make it possible to introduce generators while maintaining 100% backwards compatibility with existing code.
And this is why async
was added as a function modifier: to avoid breaking existing code that used await
as a variable name. Since no async
methods already existed, no old code is invalidated, and in new code, the compiler can use the presence of the async
tag to know that await
should be treated as a keyword and not an identifier.
- 82,151
- 24
- 234
- 309
2Doesn't that mean that in some future version, the requirement to specify the `async` keyword can be dropped? Obviously it would be a BC break but it could be thought to affect very few projects and be a straight-forward requirement to upgrade (i.e. changing a variable name). – Quolonel Questions Oct 11 '19 at 09:13
Ton of thanks Mason! This has buged me for a while, and thank you for explaining it so crystal clear. – Weipeng Sep 11 '20 at 07:40
1The article in question, as far as I can tell, can now be found here https://docs.microsoft.com/en-us/archive/blogs/ericlippert/asynchrony-in-c-5-part-six-whither-async – Rotem May 10 '22 at 19:15
it changes the method from a normal method to a object with callback which requires a totally different approach for code generation
and when something drastic like that happens it is customary to signify it clearly (we learned that lesson from C++)
- 25,706
- 2
- 62
- 97
So this is really something for the reader/programmer, and not so much for the compiler? – ConditionRacer Feb 18 '13 at 21:34
@Justin984 it definitely helps to signal to the compiler something special needs to happen – ratchet freak Feb 18 '13 at 21:37
2I guess I'm curious why the compiler needs it. Couldn't it just parse the method and see that await is somewhere in the method body? – ConditionRacer Feb 18 '13 at 21:39
it helps when you want to schedule multiple `async`s at the same time so they don't run one after another but concurrently (if threads are available at least) – ratchet freak Feb 18 '13 at 21:45
1@Justin984: Not every method returning `Task
` actually has the characteristics of an `async` method - for example, you might just run through some business/factory logic and then delegate to some *other* method returning `Task – Aaronaught Feb 18 '13 at 23:58`. `async` methods have a return type of `Task ` in the *signature* but don't *actually* return a `Task `, they just return a `T`. In order to figure all of this out without the `async` keyword, the C# compiler would have to do all sorts of deep inspection of the method, which would probably slow it down quite a bit, and lead to all manner of ambiguities.
The whole idea with keywords like "async" or "unsafe" is to remove ambiguity as to how the code they modify should be treated. In the case of the async keyword, it tells the compiler to treat the method modified as something that does not need to return immediately. This allows for the thread where this method is used to continue without having to wait on the results of that method. It's effectively a code optimization.
I'm tempted to downvote because while the first paragraph is correct, the comparison to interrupts is incorrect (in my informed opinion). – paul Feb 18 '13 at 22:01
I see them as somewhat analogous in terms of purpose but I'll remove it for the sake of clarity. – Feb 18 '13 at 22:04
Interrupts are more like events than async code in my mind -- they cause a context switch and run to completion before normal code is resumed (and the normal code might be completely ignorant of it running, too), whereas with async code the method might not have completed before the calling thread is resumed. I see what you were trying to say w.r.t. different mechanisms requiring different implementations under the hood, but interrupts just didn't jibe with me to illustrate this point. (+1 for the remainder, btw.) – paul Feb 19 '13 at 14:11
OK, here is my take on it.
There is something called coroutines that has been known for decades. ("Knuth and Hopper"-class "for decades") They are generalizations of subroutines, in such as not only do they get and release control at function start and return statement, but they also do it at specific points (suspension points). A subroutine is a coroutine with no suspension points.
They are PLAIN EASY to implement with C macros, as shown in the following paper about "protothreads". (http://dunkels.com/adam/dunkels06protothreads.pdf) Read it. I'll wait...
The bottom line of this is that the macros create a big switch
, and a case
label at each suspension point. At each suspension point, the function stores the value of the immediately following case
label, so that it knows where to resume execution next time it is called. And it returns control to the caller.
This is done without modifying the apparent flow of control of the code described in the "protothread".
Imagine now that you have a big loop calling all these "protothreads" in turn, and you get concurrently executing "protothreads" on a single thread.
This approach has two drawbacks:
- You cannot keep state in local variables between resumptions.
- You cannot suspend the "protothread" from an arbitrary call depth. (all suspension points must be at level 0)
There are workarounds for both:
- All local variables must be pulled up to the context of the protothread (context which is already needed by the fact the protothread must store its next resumption point)
- If you feel you really need to call another protothread from a protothread, "spawn" a child protothread and suspend until completion of the child.
And if you had compiler support to do the rewrite work that the macros and workaround do, well, you could just write your protothread code just as you intend and insert suspension points with a keyword.
And this is what async
and await
are all about: creating (stackless) coroutines.
The coroutines in C# are reified as objects of (generic or non-generic) class Task
I find these keywords very misleading. My mental reading is:
async
as "suspensible"await
as "suspend until completion of"Task
as "future …"
Now. Do we really need to mark the function async
? Apart from saying that it should trigger the code rewrite mechanisms to make the function a coroutine, it resolves some ambiguities. Consider this code.
public Task<object> AmIACoroutine() {
var tcs = new TaskCompletionSource<object>();
return tcs.Task;
Assuming that async
is not mandatory, is this a coroutine or a normal function? Should the compiler rewrite it as a coroutine or not? Both could be possible with different eventual semantics.
- 535
- 3
- 8
