48
I have been told that the average number of bugs/defects per line of code is "constant" for different programming languages. 10 KLOC of Ruby would have the same number of bugs as 10 KLOC of c++. The argument is usually used to promote the use of expressive languages (think python/ruby over c++/assembly) since the number of lines to describe the same functionality would be smaller.
Does anybody know where this claim comes from? Does higher-level languages lead to fewer bugs?
Kristian
  • 589
    Seems unreasonable considering that some languages encourage a style that packs more statements into a single line than others do. – Caleb Feb 02 '13 at 16:08
    Bugs / LOC is a very wrong metric for everything. It depends on the language, but it depends far more on the programmer, writing it. So taking the average for the language makes no sense, since the large fluctuations are in the other variable. This is just IMO, ofc. – K.Steff Feb 02 '13 at 16:39
    I thought bugs/loc are _at best_ measurable by a specific programmer/developer and not for languages. Can you provide a source for your statement? – mhr Feb 02 '13 at 17:35
  • @mri: I don't have an authorative source, just random people telling me this. Would like a source, though.. – Kristian Feb 02 '13 at 17:46
    I can tell you that the number of bugs/line I write in Perl will be much greater than the number I write in C. A friend of mine is a Perl wizard, and for him the bugs/line is much greater in C than in Perl. Hard to see how this metric could possibly be useful. – Caleb Feb 02 '13 at 20:31
    Let me ask you this question. Does the answer actually matter to you? If, for example, you were told that a particular higher-level language offered, say, doubled programmer productivity and 1/4 the defect rate, across the board, what would you do with that information? – John R. Strohm Feb 04 '13 at 15:18
    Do you really think that [`{1≥⍴⍵:⍵⋄e←⍵[?⍴⍵]⋄ (∇(⍵e)/⍵}`](http://rosettacode.org/wiki/Quicksort#APL) is as likely to contain an error as [`int pivot = arr.Count / 2;`](http://rosettacode.org/wiki/Quicksort#C.23)? – svick Feb 07 '13 at 20:03
    I just ran across this question. I haven't the foggiest why it was closed; this is a perfect question for this site. For a large project, bugs per KLOC is not a measure of how good programmers are. It is a measure of how good the organization and process are. – David Hammen May 29 '16 at 10:16
8 Answers8
44
Contrary to intuition, the number of errors per 1000 lines of does seem to be relatively constant, reguardless of the specific language involved. Steve McConnell, author of Code Complete and Software Estimation: Demystifying the Black Art goes over this area in some detail.
I don't have my copies readily to hand - they're sitting on my bookshelf at work - but a quick Google found a relevant quote:
Industry Average: "about 15 - 50 errors per 1000 lines of delivered code."
(Steve) further says this is usually representative of code that has some level of structured programming behind it, but probably includes a mix of coding techniques.
Quoted from Code Complete, found here: http://mayerdan.com/ruby/2012/11/11/bugs-per-line-of-code-ratio/
If memory serves correctly, Steve goes into a thorough discussion of this, showing that the figures are constant across languages (C, C++, Java, Assembly and so on) and despite difficulties (such as defining what "line of code" means).
Most importantly he has lots of citations for his sources - he's not offering unsubstantiated opinions, but has the references to back them up.
It seems to boil down to this: The average number of defects per kloc seems to be more a property of the fact that developers are fallible humans than of the peculiar advantages or disadvantages of a particular language or platform.
(Aside: If you don't already have Code Complete, go buy yourself a copy and read it thoroughly - it's well worth the investment. )
Update: There's another factor at play with some of the answers here - large scale statistics are useful for making general predictions but not specific ones. Consider, population mortality tables can predict about how many people will be killed in traffic accidents this year but can't tell you which people will die. Similarly, industry statistics that show a relatively constant number of defects per kloc can't be used to predict how well - or how poorly - a particular developer will perform or what will happen on a given project.
Bevan
  • 3,170
    Don't have a copy of Software Estimation, but in Code Complete McConnel cites Capers Jones "Program Quality and Programmer Productivity" 1977 report as the source of a table of errors per LOC per project size. The point McConnel tries to make is that errors increase dramatically as the project's size increases, and notes that the data are only a "snapsot of the industry" and that "the numbers may bear little resemblance to those for the projects you’ve worked on". I don't really see anything in there that has anything to do with this question. – Roc Martí Feb 03 '13 at 00:09
  • Which edition of Code Complete do you have @RocMartí? I know that the second edition was a major update. Will have to dig it out and see what it says when I get to work Monday. – Bevan Feb 03 '13 at 03:01
  • I think your edit (**Update:**) is the core of the problem. Or, as Mark Twain said, there's three kinds of lies: Lies, Damn Lies, and Statistics. – GalacticCowboy Mar 26 '13 at 17:59
    @RocMartí "errors increase dramatically as the project's size increases" Did he also point out that water is wet? Of course there are errors when things get more complicated. Because every new change has to keep in mind every possible piece that could be affected. Which grows as the project grows. – Parthian Shot Aug 12 '14 at 21:23
    The quote is either wrong or outdated. In the second edition, it's on page 521: "Industry average experience is about 1 - 25 errors per 1000 lines of code for delivered software. The software has usually been developed using a hodgepodge of techniques." – Aryeh Leib Taurog Jul 28 '15 at 08:27
  • At the time, there were no high level languages (in common usage) with very compact code and little compile time type checking. Hence I don’t think his results are still valid. – Ian Nov 22 '17 at 10:17
  • I disagree - there were a number of languages in widespread use by 1993 that had rigorous type systems (I studied several of them while doing my Computer Science degree and 1993 was my final year). Perhaps the depth of programming language history is deeper than you think @ian – Bevan Nov 22 '17 at 20:41
18
The claim is - at best - naive.
SLOC isn't exactly a reliable metric for anything useful, except perhaps comparing the size of two or more projects. Furthermore there are two distinct types of SLOC, physical LOC and logical LOC, and those might differ significantly. Consider this example, from Wikipedia:
for (i = 0; i < 100; i += 1) printf("hello");
Here we have one physical LOC, but two logical ones (for and printf statements). But we could of course write the example as:
  printf("hello");
Which would give us two physical and two logical LOCs. I think it's clear that any "bug per loc" measurement that would depend on physical LOCs would be tainted by programming style, thus our measurement would be largely useless.
If, on the other hand, we went with logical LOCs then our measurement would heavily depend on the language's syntactic idiosyncrasies. Although the resulting metric might be a bit useful when comparing projects written in the same language, it would be fairly useless for projects written in different languages.
One possible source for the claim is Les Hatton's Software failures-follies and fallacies:
We can conclude that programming language choice is at best weakly related to reliability.
Later on, the paper mentions similar defect densities for C and C++:
In a recent study comparing two similar systems of similar size, (around 50,000 lines each), one in C and one in object-designed C++, the resulting defect densities were shown to be around the same at 2.4 and 2.9 per 1000 lines respectively.
This, however, doesn't mean that "bug per LOC" is constant across programming languages, or that it would be significant if it was.
Glorfindel
  • 3,137
yannis
  • 39,547
  • 40
  • 183
  • 216
  • If you assume that bugs/statement is constant then there is a difference for languages. The C example commonly has bugs in the for() and the printf() args. If you had to code the printf functionality out in full you would have proportionally more bugs and if you had a higher level language with a single printRepeat() call there would be less opportunities to get it wrong. – Martin Beckett Feb 02 '13 at 18:36
    Summary: bugs per statement/function point is constant, low level languages have more code written by the fallible programmer, high level languages you type less - therefore less bugs. Although totally incorrect design type bugs are probably the same! – Martin Beckett Feb 02 '13 at 18:37
    Let alone that what constitutes "one bug" is highly subjective, and that bugs differ wildly in severity, impact, and importance. – tdammers Feb 02 '13 at 21:35
  • @tdammers And that importance can be negative. We have a handful of bugs that the client is used to/expects/wants, so we can't fix them... – Izkata Feb 03 '13 at 17:19
  • @Izkata: depends on your definition of a bug... – tdammers Feb 03 '13 at 19:35
  • Unfortunately, Hatton's paper is paywalled by the IEEE, so it is impossible to determine whether it says anything useful. (That the second comment compares C and C++ seems to argue against it.) – John R. Strohm Feb 04 '13 at 15:23
  • @JohnR.Strohm http://www.leshatton.org/wp-content/uploads/2012/01/FFF_IEE397.pdf – yannis Mar 26 '13 at 19:00
  • The problem, of course, with talking about a "logical line of code", is that there is no way to delimit such a thing. For example, that `for` statement could be viewed as one logical line of code- as you did- or, as the AST would probably determine, at least four (while, initialization stmt, condition, update stmt). You provide an eloquent hypothesis for why you believe the statement is naive, but you fail to provide supportive statistical evidence. Which forces me to file this answer under "opinion". But it's well-spoken and researched, so I won't downvote. – Parthian Shot Aug 12 '14 at 21:30
13
This observation is very old, and comes from a very venerable source, namely Fred Brooks in his book "The Mythical Man Month". He was a top manager at IBM, and managed many programming projects including the milions-of-lines operating system OS/360. In fact he reported that the number of bugs in a program is not proportional to the length of code, but quadratic! According to his research, the number of bugs was proportional to the length of the program to the power 1.5. In other words, a program that is ten times longer has 30 times more bugs. And he reported that this held over all programming languages, and levels of programming languages.
  • Thank you for providing a source. I did review this book, but did not find this information. I did find that the time taken to find and fix bugs becomes quadratic (the last few bugs are the hardest to find an fix and take the most time - ch. 1), and effort to *write* debugged code scales quadratically (ch.8 calling the shot), but I could not find number of bugs being quadratic. Reading between the lines of the book, effort should be 50% writing and 50% debugging, so debugging time should scale to the 1.5 power w.r.t. length of the program. Can anyone find a specific reference for this? – Charles L. Jun 21 '20 at 07:01
I don't find Bugs per LOC to be constant at all for a given language. Bugs per LOC seem like a metric some Managers use to determine the quality of developers when it comes to review time.
Now outside of that, some languages are more prone to errors or defects than others. Usually, but not always this is a lower level language than a higher one. For example coding in C versus C# (or Java.) I say usually because the reality of it and the crux of the answer you are looking for comes down to quality of developer and the coding practices in place. I have seen very good C developers with much higher code quality and lower defect counts than average Java/C# developers. This is one item that separates a senior developer from a junior one. Not how many LOC they write in a given time frame, but quality of the code the write regardless of language, LOC or time frame.
The only thing answer I can give that might relate is that the more LOC there are the more likely-hood of there being a defect and the more defects that exists.
Akira71
  • 2,935
  • My question is about average number of defects per line of code independent of language. – Kristian Feb 02 '13 at 17:52
    @Kristian there is no such number. It changes per person relative to the job and expertise of the developer and language they are coding in. I don't think there is a universal average. – Akira71 Feb 02 '13 at 19:47
    @Akira71 "there is no such number" Well, sure. But there are probability distributions, from which you can extract numbers. There's also no number for how many inches of rain fall annually in the Amazon rainforest, but you can take an average. – Parthian Shot Aug 12 '14 at 21:34
Bugs Per Line Of Code
Bugs / LOC is only relative to an individual. For businesses that implement bug tracking tools that link with their source code repository. It's possible for a manager to organize issues by developer, sorted by past issues and code changes.
Bugs Are Relative To Your Job
A senior software developer, who is highly experienced, highly skilled, very smart and able to take on independent jobs is far more likely to have way more bugs logged in a tracking system, then a junior developer with little experience.
How is that possible?
Senior developers are often engaged in higher risk development tasks. Refactoring of code and building new systems as an example. Junior developers are often assigned to fix known issues that aren't worth the time of a senior developer.
Therefore, by task assignment a junior isn't introducing bugs but fixing them, and a senior developer is allowed the risk of introducing them, because the benefit of what they are trying to archive is more important then the minor issues that are raised completing those tasks.
Language Syntax Is Important
The argument that a language introduces less bugs, because it can achieve more in fewer lines of code is a complete myth. Highly structured languages like C++/C#/Java force the developer to clearly express in writing what the desired instruction should be, where as languages like Python/PHP are very unstructured. Those languages allow for written expressions that not only will confuse a developer, but also the language parser.
The Compiler Reduces Bugs
How many bugs in Python/PHP have made it out into production servers, because there was no compiler to warn the developer that something was incorrect. When you measure bugs per LOC is that before or after a compiler has processed the source code?
Update 2019:
Compilers make no difference on the nature or number of bugs. Bugs are purely relative to the person who wrote the source code, and bugs themselves can be very subjective in nature.
Reactgular
  • 13,040
  • 81
    Re compiler reducing bugs: Both Python and PHP technically have compilers, they just don't do the same checking that statically typed languages do. I also don't agree that such checking has a significant effect on the ending bug count because virtually all errors that can be caught by a compiler are caught with minimal testing. – Winston Ewert Feb 02 '13 at 21:53
    Agreed that bugs that could be caught by the compiler will generally be caught with reasonable automated or manual testing. The difference is that statically typed languages give you the first pass of testing (a) for free, and (b) really, really quickly. A good suite of Ruby unit tests is better than a compiler, but you usually can't run them as fast, you don't get them for free, and they normally won't point nearly as closely to the line of code that's the problem. – Ken Smith Jun 11 '15 at 22:38
  • @KenSmith static types are not free. https://courses.cs.washington.edu/courses/cse590n/10au/hanenberg-oopsla2010.pdf – Hugo Wood Feb 15 '17 at 10:39
FWIW, in my experience
  1. There are two kinds of bugs: a) where the program does not meet expectations, and b) where the program cannot meet any reasonable expectations, because it crashes/hangs/won't compile.
  2. Regardless of language, bugs of type (b) are caused by redundancy in data/class structure, where changing something in one part of the data structure puts the structure in an inconsistent/broken state until one or more corresponding changes are made in other parts. Contributing to this is redundancy of source code, where an edit to one line of code makes the code incorrect until one or more changes are made in other parts. These two types of redundancy are closely related, of course, and since programmers are not super-persons they get distracted, forget things, and make mistakes, thereby putting in bugs.
These things (again, in my experience) are not really a function of the language, but of the skill/maturity of the programmer. Programs that are much less bug-prone also tend to be much smaller, in terms of LOC, for a given set of functionality.
I've seen systems where some people write programs, while others write directories, and the former tend to "just work" compared to the latter.
Mike Dunlavey
  • 12,815
  • 35
  • 58
I would expect that a key factor in coding errors relates to what I call the "semantic gap" between a particular type of solution definition and the code to solve it - where these are close reformulation errors would be more apparent, where the code is very different, many errors could be expected. The paradigm of certain languages closely match certain problem domains - spreadsheets are very appropriate to everyday business calculations, resulting in both very little "code" and the "code" being very close to the problem domain. The expected code is both very concise (little KLOC) and few errors. Conversely using assembler would require many KLOC and is likely to produce immense number of errors.
Instead of talking about lines of code - which are indeed a useless metric - I'd like to address this part of your question:
This is different than bugs/LOC, because higher-level languages do more with less code. Implementing some feature requirement might take 500 lines of LISP vs 15000 lines of x86 assembly.
So, even if bugs/LOC is constant between all languages, the higher-level language will still yield fewer bugs.
Misko
  • 1,070
    Lines of code a "useless metric"? No, it is a rough approximation of program complexity. It can be useful because it is easy to measure and is also closely related to development time. –  Apr 21 '13 at 07:34
