The short answer is that cases seem to be few and far between. There are probably a few though.
One would be when you need to store a small number of large objects -- especially, objects that are so large that it's impractical to allocate space for even a few extra of them. There's basically no way to stop a vector or deque from allocating space for extra objects -- it's how they're defined (i.e., they must allocate extra space to meet their complexity requirements). If you flat-out can't allow that extra space to be allocated, an std::list
may be the only standard container that meets your needs.
Another would be when/if you'll store an iterator to an "interesting" point in a list for an extended period of time, and when you do insertions and/or deletions, you (nearly) always do it from a spot to which you already have an iterator, so you don't walk through the list to get to the point where you're going to do the insertion or deletion. Obviously the same applies if you work with more than one spot, but still plan on storing an iterator to each place you're likely to work with, so you most manipulate spots you can reach directly, and only rarely walk through the list to get to those spots.
For an example of the first, consider a web browser. It might keep a linked list of Tab
objects, with each tab object representing on open tab in the browser. Each tab might be a few dozen megabytes of data (of more, especially if something like a video is involved). Your typical number of open tabs might easily be less than a dozen, and 100 is probably close to the upper extreme.
For an example of the second, consider a word processor that stores text as a linked list of chapters, each of which might contain a linked list of (say) paragraphs. When the user is editing, they're typically going to find a particular spot where they're going to edit, and then do a fair amount of work at that spot (or inside that paragraph, anyway). Yes, they'll move from one paragraph to another now and again, but in most cases it'll be a paragraph near where they were already working.
Once in a while (things like global search and replace) you end up walking through all the items in all the lists, but it's fairly uncommon, and even when you do, you're probably going to do enough work searching within an item in the list, that the time to traverse the list is nearly inconsequential.
Note that in a typical case, this is likely to fit the first criterion as well -- a chapter contains a fairly small number of paragraphs, each of which is likely to be fairly large (at least relative to the size of the pointers in the node, and such). Likewise, you have a relatively small number of chapters, each of which might be several kilobytes or so.
That said, I have to admit that both of these examples are probably a little contrived, and while a linked list might work perfectly well for either, it probably wouldn't provide a huge advantage in either case as well. In both cases, for example, allocating extra space in a vector for either some (empty) web pages/tabs or some empty chapters is unlikely to be any real problem.
