Avoid Double Meanings
You have deliberately selected a word that has more then one meaning, and that first decision is the problem. There are a ton of words that are problematic for programmers. Another example would be phone
. You can phone
someone, or you could have a phone
in your pocket.
Use Getters and Setters
The standard naming for most objects is the getters/settings methods for properties.
Battery.Charge // would be a property
Battery.setCharge(value) // would set the property
Battery.getCharge() // would get the property
Properties Are States Not Nouns
I think you are mistaken by classifying object properties as nouns, and variables could also be thought of states. They are states relevant to the local scope of their existence.
You could describe the value that they hold as a noun, but I'm not sure that is true in all cases.
In OOP terminology object properties describe the state of that object. In your case the Battery
is an object, and it's Charge
is a state. So that would be a property of the object, but this depends on the context of how it's used.
If you need to be able to Charge
the battery, and also know what it's current Charge
is, then you have a problem.
Using Scope To Enforce Context
Context is what will clarify which meaning of a word you intend a method or property to convey. Scope is setting the accessibility of a property/method from outside the object.
Batter._charge // a hidden private property
Battery.setCharge(value) // would set the private property
Battery.getCharge() // would get the private property
Battery.Charge() // would perform the Charge action
Methods Are Verbs
You can describe the method of an object as a verb, but the word action is better suited. In OOP terminology you perform actions upon objects using their methods. It's bad form to modify an object's property from outside the object. It's preferred to call a method that performs the actions required that causes it's state to change.
The word Charge
is a verb, but it's also a noun. When used to call the method of an action it becomes clear that the verb is being used Battery.Charge(....)
But, context is very important. While the word Charge()
is a verb it's not as meaningful as startCharging()
Valid methods for Battery
could include Charging
, Discharging
, setCharge
, getCharge
, hasCharge
, Discharge
and Charged
Simple one word methods often don't explicitly state their actions clearly, but there are some cases like open
and close
where little explaining is required.
So there isn't really a correct answer as to how to name these types of properties/methods. Except that you need to use the above techniques wisely to ensure there is no confusion.
