40
We have reached the point in our project where we have almost a thousand tests and people have stopped bothering with running them before doing a check in because it takes so long. At best they run the tests that are relevant to the piece of code that they changed and at worst they simply check it in without testing.
I believe this problem is due to the fact that the solution has grown to 120 projects (we usually do much smaller projects and this is only the second time we do TDD properly) and the build + test time has grown to about two-three minutes on the lesser machines.
How do we lower the run time of the tests? Are there techniques? Faking more? Faking less? Maybe the bigger integration tests shouldn't run automatically when running all the tests?
Edit: as a response to several of the answers, we already use CI and a build server, this is how i know the tests fail. The problem (actually a symptom) is we keep getting messages about failed builds. Running partial tests is something that most people do but not all. and regarding the tests, they are actually pretty well made, they use fakes for everything and there is no IO at all.
Ziv
  • 2,946
  • 26
    Get better hardware? Hardware is cheap compared to programmer time. – Bryan Oakley Jan 25 '13 at 16:48
  • You say build + test is 2-3 minutes at worst. How much is build and how much is test? – Sign Jan 25 '13 at 16:49
    You already implied the solution in your question: only run the tests that are relevant to the piece of code that was changed. Run the entire test suite periodically, as part of the QA/Release cycle. That said, 2 to 3 minutes doesn't sound like a lot of time, so it is possible your developer team is checking in things too frequently. – Robert Harvey Jan 25 '13 at 16:50
    First benchmark, to figure out where the performance cost comes from. Are there a few expensive tests, or is it the sheer amount of tests? Are certain setups expensive? – CodesInChaos Jan 25 '13 at 17:20
    Damn, I wish our tests were only 2-3 minutes. To run all our unit tests, it takes 25 minutes - and we don't have any integration tests yet. – Izkata Jan 25 '13 at 19:46
  • Do the tests touch the file system? Are there any tests that apply concurrency or sleep statements in order to produce some effects? You have already hinted that you have "integration tests". What does that involve? – Tormod Jan 25 '13 at 21:09
    Run a profiler over your tests. It's a fair bet that a small proportion of the tests are much slower than the vast majority. Break those tests down, and mock out slow collaborators. – Sean McMillan Jan 25 '13 at 21:51
    2 to 3 minutes? Jeez. Ours can run hours... – Roddy of the Frozen Peas Jan 25 '13 at 22:59
  • Am I missing something in your edit? If there is a test and we assume that test is valid and must pass for our software to work properly why would a developer not want to get an e-mail about a failed build? – Mike Jan 30 '13 at 21:58
  • Check out these awesome slides https://speakerdeck.com/bkeepers/why-our-code-smells – Haralan Dobrev Feb 06 '13 at 00:34
  • Unit tests should run in-mem and instantanously. 1 second max for thousand of tests. Otherwise you are doing something wrong (io). They should be enabled to run as a pre-commit hook. Integration tests (or other slow tests) should be enabled on your build server. Merges should not be allowed to happen unless the tests pass. – oligofren Jun 07 '16 at 07:44
  • 2-3 minutes sounds pretty fast. Is that for a full build and the entire test suite? My techniques rely on (1) incremental builds, and (2) subset tests/suites that provide enough coverage for the code I'm working on at the time. It usually means that while developing I'm running only some tests, and before I push (or merge, depending) I run the full test suite. – xaviersjs May 15 '19 at 21:35
13 Answers13
51
A possible solution would be to move the testing portion from the development machines to a continuous integration setup (Jenkins for example) using version control software of some flavor (git, svn, etc...).
When new code has to be written the given developer will create a branch for whatever they are doing in the repository. All work will be done in this branch and they can commit their changes to the branch at any time without messing up the main line of code.
When the given feature, bug fix, or whatever else they are working on has been completed that branch can be merged back into the trunk (or however you prefer to do it) where all unit tests are run. If a test fails the merge is rejected and the developer is notified so they can fix the errors.
You can also have your CI server run the unit tests on each feature branch as commits are made. This way the developer can make some changes, commit the code, and let the server run the tests in the background while they continue to work on additional changes or other projects.
A great guide to one way of doing such a setup can be found here (git specific but should work for other version control systems): http://nvie.com/posts/a-successful-git-branching-model/
Mike
  • 2,046
    This. If the developers "have stopped bothering with running them (the unit tests) before doing a check in", then you want your CI setup to be running them *after* a check in. – Carson63000 Jan 25 '13 at 19:45
  • +1: A further improvement would be to modularize the tests. If a specific module/file has not changed since the last run, there is no reason to re-run the tests that are responsible for testing it. Sort of like a makefile not recompiling everything just because one file has changed. This may require some work but will probably give you cleaner tests as well. – Leo Jan 25 '13 at 23:06
  • Will the branching methodology work with TFS? We write C# with TFS and branching in TFS is less friendly than in git. I believe this idea will even be rejected since we never do branching. – Ziv Jan 26 '13 at 10:23
  • I have no personal experience working with TFS; however, I was able to come across this guide from Microsoft which seems to show a simlilar branching strategy to the one in the post: http://msdn.microsoft.com/en-us/magazine/gg598921.aspx – Mike Jan 30 '13 at 22:15
35
The majority of Unit Tests should take under 10 milliseconds each or so. Having 'almost a thousand tests' is nothing and should take maybe a few seconds to run.
If they're not, then you should stop writing highly coupled integration tests (unless that's what the code needs) and start writing good unit tests (starting with well decoupled code and proper usage of fakes/mocks/stubs/etc). That coupling will impact test quality and the time it takes to write them too - so it's not just a matter of reducing test run time.
Telastyn
  • 108,850
  • 239
  • 365
    Well, you probably shouldn't stop writing integration tests and other non-unit automated tests, as they are useful in their own right. You just shouldn't confuse them with unit tests, and keep them separate, partly because they're slower. –  Jan 25 '13 at 17:25
    Your correct that these seem to be integration tests. – Tom Squires Jan 25 '13 at 17:31
  • I like having some slow and comprehensive unit tests, but I don't run them on every build. – CodesInChaos Jan 25 '13 at 17:34
  • @delnan - ah yes. quite correct. – Telastyn Jan 25 '13 at 18:01
  • Telastyn: Sorry to say but I have a three-part rebuttal to your answer. Moderator: sorry to post this in comments but I feel that this rebuttal needs to be public. – rwong Jan 26 '13 at 08:46
    This answer is not productive. Firstly, it sets an unreasonable expectation. There are overheads in the unit testing framework itself; that each test take less than a millisecond does not imply a thousand test must take less than a few seconds. That the OP's entire test suite finishing in 2-3 minutes is a very good sign, by most measures. – rwong Jan 26 '13 at 08:47
  • Secondly, a software development process must incorporate sufficient safeguards to assure quality to the extent that is economically feasible. While it is useful to separate integration tests and unit tests into different suites, it must not be done in a way that undermines the safeguards. What tests deserve to be run, need to be run. Otherwise, it gives a false sense of security. – rwong Jan 26 '13 at 08:47
  • Finally, the crux of this question is about removing interruptions to the development flow due to test running. If one tries to solve this problem by moving slower tests into a different suite, then a second question can be asked: how to remove interruptions to the flow due to running this second suite (the slower one), which still needs to be run. Automating asynchronously, as done in Continuous Integration (see Mike's [answer](http://programmers.stackexchange.com/a/184841/620)), is the correct answer. – rwong Jan 26 '13 at 08:49
    @rwong - sorry, I call bullshit. The metric I got was from running the two different professional projects available to me: one with ~300 tests, one with ~30000 tests and looking at the test runtimes. A test suite taking 2-3 minutes for <1000 tests is _atrocious_ and a sign that the tests are not sufficiently isolated. – Telastyn Jan 26 '13 at 13:19
    @rwong In the same vein as Telastyn, here's a data point from me: Even with quite a few larger-than-ideal tests, the test framework (`py.test`) doing tons of magic in the background, and everything being pure Python code ("100x slower than C"), running the circa 500 tests in a project of mine takes less than 6 seconds on an several years old, slow netbook. This figure is roughly linear in the number of tests; while there is some start-up overhead, it is amortized over all tests, and the per-test overhead is O(1). –  Jan 26 '13 at 15:43
  • Note that OP said 2-3 minutes was for build+test, not just test. It would be interesting to know what just the test time was. – Ben Jan 31 '13 at 20:56
16
There are several approaches I have used to solve similar issue:
  1. Check execution time, and find all most slowest tests and then analyze why they take so much time to execute.
  2. You have 100 projects, may be you do not need to build and test them every time? Could you run all unittest only at a night builds? Create several 'fast' build configurations for daily use. CI server will perform only limited set of unittests projects related to 'hot' parts of your current development process.
  3. Mock and isolate everything you could, avoid disk/network I/O whenever it's possible
  4. When it isn't possible to isolate such operations, may be you have integration tests? May be you could schedule integration tests to night builds only?
  5. Check all occasional singletons, that keep references to instances/resources and that consume memory, this could leads to performance degradation while running all tests.
In addition you could use following tools to make both your life easy and tests run faster
  1. Gated commit some CI servers could be configured to perform build and test before commiting code to source repository. If someone commits code without running all tests beforehand, that contains also failed tests, it will be rejected and returned back to author.
  2. Configure CI server to execute tests in parallel: using several machines or processes. Examples are pnunit and CI configuration with several nodes.
  3. Continuous testing plug-in for developers, that will automaticaly run all test during writing code.
Akim
  • 999
0. Listen to your programmers.
If they're not running the tests, it means they perceive the cost (waiting for the tests to run, dealing with false failures) to be greater than the value (catching bugs right away). Decrease the costs, increase the value, and people will run the tests all the time.
1. Make your tests 100% reliable.
If you ever have tests that fail with false negatives, deal with that right away. Fix them, change them, eliminate them, whatever it takes to guarantee 100% reliability. (It's OK to have a set of unreliable, but still useful tests that you can run separately, but the main body of tests must be reliable.)
2. Change your systems to guarantee that all tests pass all the time.
Use continuous integration systems to ensure that only passing commits get merged in to the main/official/release/whatever branch.
3. Change your culture to value 100% passing tests.
Teach the lesson that a task isn't "done" until 100% of tests pass and it has been merged in to the main/official/release/whatever branch.
4. Make the tests fast.
I have worked on projects where tests take a second, and on projects where they take all day. There is a strong correlation between the time it takes to run tests and my productivity.
The longer tests take to run, the less often you'll run them. That means you'll go longer without getting feedback on the changes you're making. It also means you'll go longer between commits. Committing more often means smaller steps that are easier to merge; commit history is easier to follow; finding a bug in the history is easier; rolling back is easier, too.
Imagine tests that run so fast that you don't mind automatically running them every time you compile.
Making tests fast can be hard (that's what the OP asked, right!). Decoupling is key. Mocks/fakes are OK, but I think you can do better by refactoring to make mocks/fakes unnecessary. See Arlo Belshee's blog, starting with http://arlobelshee.com/post/the-no-mocks-book.
5. Make tests useful.
If the tests don't fail when you screw up, then what's the point? Teach yourselves to write tests that will catch the bugs you're likely to create. This is a skill unto itself, and will take lots of attention.
Jay Bazuzi
  • 1,604
    STRONGLY agree, particularly point 3 & 1. If developers aren't running tests, then the tests are broken, the environment is broken, or both. Point 1 is the minimum. False fails are worse than missing tests. Because people learn to accept fails. Once failure is tolerated, it spreads, and it takes a mighty effort to get back to 100% passing and EXPECTING 100% passing. Start fixing this *today*. – Bill IV Sep 07 '14 at 19:29
  • And how can you possibly not agree with #5?!? in addition to 1 & 3, or heck, 2 & 4, too! Anyway, great answer all around. – fourpastmidnight Aug 22 '18 at 20:54
  • Can't agree more! Someone tried to convince me that doing all development in Virtual Machines would be a good route to go. But unit tests ran 400% SLOWER in the VM,. making it so that we spent more time sitting there waiting to get feedback on code, rather than actually coding. – kiwicomb123 Jan 21 '22 at 06:01
A couple minutes is OK for unit tests. However, keep in mind that there are 3 major types of tests:
  1. Unit tests -- test each "unit" (class or method) independently of the rest of the project
  2. Integration tests -- test the project as a whole, usually by making calls into the program. Some projects I've seen combine this with regression tests. There is significantly less mocking here than unit tests
  3. Regression tests -- test the completed project as a whole, as the test suite is an end user. If you have a console application, you would use the console to run and test the program. You never expose internals to these tests and any end user of your program should (in theory) be able to run your regression test suite(even though they never will)
These are listed in order of speed. Unit tests should be quick. They won't catch every bug, but they establish that the program is decently sane. Unit tests should run in 3 minutes or less or decent hardware. You say you only have 1000 unit tests, and they take 2-3 minutes? Well, that's probably OK.
Things to check:
  • Make sure to ensure that your unit tests and integration tests are separate though. Integration tests will always be slower.
  • Ensure that your unit tests are running in parallel. There is no reason for them not to if they are true unit tests
  • Ensure your unit tests are "dependency free". They should never access a database or the filesystem
Other than that, your tests don't sound too bad right now. However, for reference, one of my friend's on a Microsoft team has 4,000 unit tests that run in under 2 minutes on decent hardware(and it's a complicated project). It's possible to have fast unit tests. Eliminating dependencies(and mock only as much as needed) is the main thing to get speed.
Earlz
  • 22,658
  • 60
Train your developers on Personal Software Process (PSP) helping them to understand and improve their performance by using more discipline. Writing code has nothing to do with slamming your fingers on a keyboard and afterwards press a compile and check in button.
PSP used to be very popular in the past when compiling code was a process which took a lot of time (hours/days on a mainframe so everybody had to share the compiler). But when personal workstations became more powerful, we all came to accept the process:
  1. type some code without thinking
  2. hit build/compile
  3. fix your syntax to make it compile
  4. run tests to see if what you wrote actually makes sense
If you think before you type, and then after you typed, review what you wrote, you can reduce the number of errors before you run a build and test suite. Learn not to press build 50 times a day, but maybe once or twice, then it matters less that your build and testing time takes a few minutes more.
Bart Koopman
  • 249
    I agree heavily with your list, but absolutely not with "running build only twice a day is better than 50 times". – Doc Brown Jan 25 '13 at 17:24
One possible way: split your solution. If a solution has 100 projects, then it's quite unmanageable. Just because two projects (say A and B) use some common code from another project (say Lib) doesn't mean they have to be in the same solution.
Instead, you can create solution A with projects A and Lib and also solution B with projects B and Lib.
svick
  • 9,999
  • 51
I am in a similar situation. I have unit tests which test communication with the server. They are testing the behavior with timeouts, cancelling connections etc. The whole set of tests runs 7 minutes.
7 minutes is a relatively short time but it's not something you will do before every commit.
We also have a set of automated UI tests, their run time is 2 hours. It's not something you want to run every day on your computer.
So, what to do?
  1. Changing the tests is usually not very effective.
  2. Run only the relevant tests before your commit.
  3. Run all of your tests every day (or several times a day) on a build server. This will also give you the possibility to generate nice code coverage & code analysis reports.
The important thing is: all of your tests should be run often because it's important to find the bugs. However, it's not absolutely necessary to find them before the commits.
Sulthan
  • 1,459
    As to tests that talk to servers: If it's talking to a server, it's not really a unit test, it's something higher. If I were you, I'd separate out the unit tests (which should run quick) and at least run those before every commit. That way you'll at least get the quick stuff (things that don't need to talk to the server) out of the way before code is committed. – Michael Kohne Jan 25 '13 at 17:47
  • @MichaelKohne I knew someone would spot it. I know they are not exactly unit tests but they serve the same purpose, it's only about how you name them. – Sulthan Jan 25 '13 at 18:10
    mostly it's about how you name them, but it's good to keep the difference in mind (whatever name you use). If you don't differentiate, then (in my experience) the devs have a tendency to just write higher-level tests. At which point you don't get the tests forcing you to be sensible in your abstractions and coupling. – Michael Kohne Jan 25 '13 at 19:09
Though your description of the problem does not give a thorough insight into the codebase, I think I can safely say your problem is two-fold.
Learn to write the right tests.
You say you have almost a thousand tests, and you have 120 projects. Assuming that at most half of those projects are test projects, you have 1000 tests to 60 production code projects. That gives you about 16-17 tests pr. project!!!
That is probably the amount of tests that I would have to cover about 1-2 classes in a production system. So unless you only have 1-2 classes in each project (in which case your project structure is too fine grained) your tests are too big, they cover too much ground. You say this is the first project that you are doing TDD properly. A say, the numbers that you present indicate that this is not the case, you are not doing TDD property.
You need to learn to write the right tests, which probably mean that you need to learn how to make the code testable in the first place. If you cannot find the experience inside the team to do that, I would suggest hiring help from the outside, e.g. in form of one or two consultants helping your team over a duration of 2-3 months to learn to write testable code, and small minimal unit tests.
As a comparison, on the .NET project that I am currently working on, we can run roughly about 500 unit tests in less than 10 seconds (and that was not even measured on a high spec machine). If those were your figures, you would not be afraid to run these locally every so often.
Learn to manage the project structure.
You have divided the solution into 120 projects. That is by my standards a staggering amount of projects.
So if it makes sense to actually have that amount of projects (which I have a feeling it doesn't - but your question does not provide enough information to make a qualified judgement of this), you need to divide the projects into smaller components that can be build, versioned, and deployed separately. So when a developer runs unit the test suite, he/she only needs to run the tests relating to component he/she is working on currently. The build server should take care of verifying that everything integrates correctly.
But splitting up a project in multiple components build, versioned, and deployed separately requires in my experience a very mature development team, a team that is more mature than I get the feeling that your team is.
But at any rate, you need to do something about the project structure. Either split the projects into separate components, or start merging projects.
Ask yourself if you really need 120 projects?
p.s. You might want to check out NCrunch. It's a Visual Studio plug-in that runs your test automatically in the background.
Pete
  • 8,916
  • 41
  • 53
JUnit test are normally to be quick, but some of them simply must take some time to excecute.
For example, the database test are usually taking a few time to initialize and finish.
If you have hundreds of tests, even if they are fast, they require a lot of time to run because of their number.
What can be done is:
1) Identify the crucial tests. Those for the most important parts of libraries and those which are most likely to fail after changes. Only those test should be run always on compile. If some code is often broken, its tests should be obligatory even if they take long to execute, on the other side, if some part of software never caused a problem, you can safely skip tests on each build.
2) Prepare the continuous integration server, which will run all tests in the background. It's up to you if you decide to build every hour or to build after every commit (the second makes sense only if you want to automatically detect whose commit has caused trouble).
Issues I have seen:
a) Using IOC to build up test elements. 70 seconds -> 7 seconds by removing Container.
b) Not mocking out all classes. Keep your unit tests to a single element. I have seen tests that ramble through a couple of classes. These are not unit tests and much more likely to break.
c) Profile them to find out what was happening. I found the constructor was building stuff I did not need so I localised it and reduced run times.
d) Profile. perhaps the code is not that good and you can gain some efficiency out of a review.
e) Remove dependencies. Keeping you test executable small will reduce the time to load. Use an interface library and IOC containers to run your final solution but your main test projects should only have the interface library defined. This ensures separation, ensures it is easier to test, and also makes your test foot print smaller.
I feel your pain, and I have run into several places where the build speed can be improved a lot. However, the number on thing I recommend is to measure at a granular detail to figure out where your build is taking the longest. For example, I have a build with around 30 projects that takes just over a minute to run. However, that is only part of the picture. I also know which projects take the longest to build, which helps focus my efforts.
Things that eat up build time:
  • Package downloading (Nuget for C#, Maven for Java, Gem for Ruby, etc.)
  • Copying large amounts of files on the file system (example: GDAL support files)
  • Opening connections to the database (some take over a second per connection to negotiate)
  • Reflection based code
  • Autogenerated code
  • Using exceptions to control program flow
Mock libraries either use reflection or inject code using bytecode libraries to generate the mock for you. While it's very convenient, it eats up test time. If you are generating mocks inside a loop in your test, it can add a measurable amount of time to the unit tests.
There are ways to fix the problems:
  • Move tests involving a database to integration (i.e. only on the CI build server)
  • Avoid creating mocks in loops in your tests. In fact just avoid loops in your tests altogether. You can probably get the same results using a parameterized test in that case.
  • Consider splitting your massive solution into separate solutions
When your solution contains over 100 projects, you have a combination of library code, tests, and application code. Each of the libraries can be it's own solution with it's associated tests. Jet Brains Team City is a CI build server that doubles as a Nuget server--and I'm sure it's not the only one. That gives you the flexibility to move those libraries that probably don't get changed often to their own solutions/projects and use Nuget to resolve the dependencies for your application code. Smaller solutions mean that you can make your changes to a library quickly and without any fuss, and enjoy the benefits in the main solution.
Berin Loritsch
  • 45,784
  • 87
  • 160
-1
Can your test environment run anywhere? If it can, use cloud computing to run the tests. Split the tests among N virtual machines. If the time to run the tests on a single machine is T1 seconds, then the time to run them split up, T2, could approach T2=T1/N. (Assuming each test case takes about the same amount of time.) And you only have to pay for the VMs when you're using them. So you don't have a bunch of test machines sitting in some lab somewhere 24/7. (I'd love to be able to do this where I work, but we're tied to specific hardware. No VMs for me.)
