196
I'm trying to figure out what the Anti-Corruption layer really means. I know that it's a way to transition/work around legacy code or bad APIs. What I don't understand is how it works and what makes it a clean separation from the undesirable layer.
I've done some searching, but I can't find any simple examples or explanations, so I'm looking for someone who understands it and can explain it with simple examples. An answer that would satisfy my question should be simple (not necessarily short), and provide understandable examples of implementation and use.
See this question, for my use case.
knownasilya
  • 3,074
Imagine you have to use someone else's code that is designed as shown below:
    class Messy {
        String concat(String param, String str) { /* ... */ }
        boolean contains(String param, String s) { /* ... */ }
        boolean isEmpty(String param) { /* ... */ }
        boolean matches(String param, String regex) { /* ... */ }
        boolean startsWith(String param, String prefix) { /* ... */ }
Now imagine you find out that your code that depends on it looks like the following:
String process(String param) {
    Messy messy = new Messy();
    if (messy.contains(param, "whatever")) {
        return messy.concat(param, "-contains");
    if (messy.isEmpty(param)) {
        return messy.concat(param, "-empty");
    if (messy.matches(param, "[whatever]")) {
        return messy.concat(param, "-matches");
    if (messy.startsWith(param, "whatever")) {
        return messy.concat(param, "-startsWith");
    return messy.concat(param, "-whatever");
    // WTF do I really need to repeat bloody "param" 9 times above?
...and that you want to make it easier to use, in particular, to get rid of repetitive usage of parameters that just aren't needed for your application.
Okay, so you start building an anti-corruption layer.
  1. First thing is to make sure that your "main code" doesn't refer to Messy directly. For example, you arrange dependency management in such a way that trying to access Messy fails to compile.
  2. Second, you create a dedicated "layer" module that is the only one accessing Messy and expose it to your "main code" in a way that makes better sense to you.
Layer code would look like the following:
    class Reasonable { // anti-corruption layer
        String param;
        Reasonable(String param) {
            this.param = param;
        String concat(String str) { return messy.concat(param, str); }
        boolean contains(String s) { return messy.contains(param, s); }
        boolean isEmpty() { return messy.isEmpty(param); }
        boolean matches(String regex) { return messy.matches(param, regex); }
        boolean startsWith(String prefix) { return messy.startsWith(param, prefix); }
As a result, your "main code" does not mess with Messy, using Reasonable instead, about as follows:
    Reasonable reasonable = new Reasonable(param);
    // single use of "param" above and voila, you're free
    if (reasonable.contains("whatever")) {
        return reasonable.concat("-contains");
    if (reasonable.isEmpty()) {
        return reasonable.concat("-empty");
    if (reasonable.matches("[whatever]")) {
        return reasonable.concat("-matches");
    if (reasonable.startsWith("whatever")) {
        return reasonable.concat("-startsWith");
    return reasonable.concat("-whatever");
Note there is still a bit of a mess messing with Messy but this is now hidden reasonably deep inside Reasonable, making your "main code" reasonably clean and free of corruption that would be brought there by direct usage of Messy stuff.
Above example is based on how Anticorruption Layer is explained at c2 wiki:
If your application needs to deal with a database or another application whose model is undesirable or inapplicable to the model you want within your own application, use an AnticorruptionLayer to translate to/from that model and yours.
Note example is intentionally made simple and condensed to keep explanation brief.
If you have a larger mess-of-API to cover behind the anti-corruption layer, same approach applies: first, make sure your "main code" doesn't access corrupted stuff directly and second, expose it in a way that is more convenient in your usage context.
When "scaling" your layer beyond a simplified example above, take into account that making your API convenient is not necessarily a trivial task. Invest an effort to design your layer the right way, verify its intended use with unit tests etc.
In other words, make sure that your API is indeed an improvement over one it hides, make sure that you don't just introduce another layer of corruption.
For the sake of completeness, notice subtle but important difference between this and related patterns Adapter and Facade. As indicated by its name, anticorruption layer assumes that underlying API has quality issues (is "corrupted") and intends to offer a protection of mentioned issues.
You can think of it this way: if you can justify that library designer would be better off exposing its functionality with Reasonable instead of Messy, this would mean you're working on anticorruption layer, doing their job, fixing their design mistakes.
As opposed to that, Adapter and Facade do not make assumptions on the quality of underlying design. These could be applied to API that is well designed to start with, just adapting it for your specific needs.
Actually, it could even be more productive to assume that patterns like Adapter and Facade expect underlying code to be well designed. You can think of it this way: well designed code shouldn't be too difficult to tweak for particular use case. If it turns out that design of your adapter takes more effort than expected, this could indicate that underlying code is, well, somehow "corrupted". In that case, you can consider splitting the job to separate phases: first, establish an anticorruption layer to present underlying API in a properly structured way and next, design your adapter / facade over that protection layer.
Deduplicator
  • 8,591
  • 50
gnat
  • 21,442
  • 112
  • 288
    How does this scale if there is a whole structure of dependant API classes? Is it still more manageable then the layer it's protecting the rest of the application from? – knownasilya Jan 22 '13 at 18:12
    @Knownasilya that's a very good question, answer expanded to address that – gnat Jan 22 '13 at 18:36
    You read my mind about the whole API/Adapter and Facade vs Anti-Corruption. – knownasilya Jan 23 '13 at 01:38
  • This is a technique that helps a great deal with JPA and JSF, using an anti-corruption lair to access the actual entity and keep the raw entity information clean without having it directly accessed by the web application. – Neil Jan 23 '13 at 12:43
    @Neil I think that would be the *Facade* and *Adapter* patterns, since JPA is a good ORM specification, in my opinion. – knownasilya Jan 23 '13 at 14:58
    @Knownasilya, that's an excellent observation, you're probably right. – Neil Jan 23 '13 at 15:13
    `In other words, make sure that your API is indeed an improvement over one it hides, make sure that you don't just introduce another layer of corruption.` That entire section is worthy of a bold tag. – Lilienthal Jan 29 '15 at 22:30
  • 39
    Anti-corruption layers are nothing to do with dealing with poor quality APIs. They are about dealing with conceptual mismatches, adapting domains we could only use by "corrupting" our code to domains we can use more easily. – Ian Fairman Jun 10 '16 at 10:17
  • 26
    Ian Fairman got it right, while the author of this answer most definitely did not. If you go to the source of the concept (the DDD book), you'll find at least two things that contradict this answer: 1) an anti-corruption layer is created to avoid corrupting the *new domain model that we are developing* with elements from the model of an existing external system; it is not that the other system is "corrupted", in fact it may be perfectly good and well-designed; 2) an anti-corruption *layer* will usually contain several classes, often *including* _Facades_ and _Adapters_, as well as _Services_. – Rogério Aug 24 '16 at 01:39
    so is this esentially a "mapper" ive been seeing in various ddd examples? – filthy_wizard Oct 13 '16 at 11:06
    Your example only introduces more code duplication. – D Drmmr Feb 03 '18 at 10:45
  • Regarding the Messy class, how about passing "param" to the constructor so that it's not repeated in the main code? Why would you need a wrapper class like Reasonable? – emeraldhieu May 13 '23 at 09:05
  • @emeraldhieu anticorruption layer is used when one has no option to improve like you describe. You can think of Messy class for example as coming from some external library which you just can not modify for some reason – gnat May 14 '23 at 16:50
62
To quote another source:
Create an isolating layer to provide clients with functionality in terms of their own domain model. The layer talks to the other system through its existing interface, requiring little or no modification to the other system. Internally, the layer translates in both directions as necessary between the two models.
Eric Evans, Domain Driven Design, 16th printing, page 365
The most important thing is that different terms are used at each side of the anti corruption layer. I was once working on a system for transportation logistic. Rounds had to be planned. You had to equip the vehicle at a depot, drive to different customer sites and service them and visit other places, like a tank stop. But from the higher level this was all about task planning. So it made sense to separate the more general task planning terms from the very specific transportation logistic terms.
So an anti corruption layers isolation is not just about protecting you from messy code, it is to separate different domains and make sure that they stay separated in the future.
SpaceTrucker
  • 1,462
    This is very important! An ACL is not just to be used with Messy code, but as a means to communicate between bounded contexts. It translates from one context to the other, so that data in each context reflects the language and the way that that context thinks and talks about the data. – Didier A. Nov 14 '14 at 01:43
49
Adapter
When you have incompatible interfaces, that perform similar logic, to adapt one into the other, so that you can use implementations of one with things that expect the other.
Example:
You have an object that wants a Car, but you only have a 4WheelVehicle class, so you create a CarBuiltUsing4WheelVehicle and use that as your Car.
Facade
When you have a complex/confusing/gigantic API and you want to make it simpler/clearer/smaller. You will create a Facade to hide away the complexity/confusion/extras and only expose a new simple/clear/small API.
Example:
You are using a library that has 100 methods, and to perform certain task you need to do a bunch of initialization, connecting, opening/closing things, just to finally be able to do what you wanted, and all you wanted is 1 feature of all 50 the library can do, so you create a Facade that has only a method for that 1 feature you need and which does all the initializing, cleaning, etc. for you.
Anti-corruption Layer
When you have a system that's out of your domain, yet your business needs requires you to work with that other domain. You do not want to introduce this other domain into your own, therefore corrupting it, so you will translate concept of your domain, into this other domain, and vice-versa.
Example:
One system views the custumer having a name and a list of strings, one for each transactions. You view Profiles as stand alone classes having a name, and Transactions as stand alone classes having a string, and Customer as having a Profile and a collection of Transactions.
So you create an ACL layer that will let translate between your Customer and the other system's Customer. This way, you never have to use the other system's Customer, you simply need to tell the ACL: "give me the Customer with Profile X, and the ACL tells the other system to give it a Customer of name X.name, and returns you a Customer with Profile X.
All three are relatively similar, because they are all indirection patterns. But they address different structures, classes/objects versus APIs versus modules/sub-systems. You could have them all combined if you needed to. The sub-system has a complex API, so you build a FACADE for it, it uses a different model, so for each data representation that don't fit your model, you would TRANSLATE that data back into how you model it. Finally, maybe the interfaces are also incompatible, so you would use ADAPTERS to adapt from one to the other.
Didier A.
  • 1,327
  • Could you add Ambassador Pattern please? I have a doubt between Ambassador and Anti-Corruption in the level of microservices I Was thinking is the same thing – Zaha Jan 05 '23 at 17:39
41
A lot of answers here say that ACLs are "not just" about wrapping messy code. I'd go further and say they are not about that at all, and if they do then that is a side benefit.
An anti-corruption layer is about mapping one domain onto another so that services that use second domain do not have to be "corrupted" by concepts from the first. ACLs are to domain models what adapters are to classes, it's just happening at a different level. The adapter is arguably the most important design pattern - I use it all the time - but judging the wrapped class as being messy or not is irrelevant. It is what it is, I just need it have a different interface.
Focussing on messiness is misleading and misses the point of what DDD is about. ACLs are about dealing with conceptual mismatches, not poor quality.
Ian Fairman
  • 510
