16
We're a software consultancy with a multitude of projects for different customers. We traditionally use Subversion, but are currently considering moving to Git.
A significant portion of the documents we produce are shared with our customers (requirements, global designs, test specs, etc), and we use MS Office to produce these. In Subversion, we could use its "Lock" feature to ensure that no one was editing the same document at the same time. In Git, you can't do that since by its distributed nature, git doesn't have locks.
Locks are really little more than a communication mechanism, but they're a very effective one.
Currently, our code and customer-facing documents are typically in different subfolders of a different svn repository. When moving to git, what would you recommend we do? I see a set of options:
  1. We move the svn repositories to git 1-on-1. Instead of using locks on the Office files, we do what the git people suggest and somehow try to change our workflow to fix it. This could be working in a branch on any document edit, and merging that over review. This approach breaks over e.g. Excel sheets that contain project management info; they're easily edited by team members (and we encourage that this is done), but not subject to any formal review process
  2. We use git for code and svn for docs and project management. This has the disadvantage that certain more design-ish documents won't be "nearby" the code it specs, increasing the chance that people forget to update them. Additionally, everybody has to use and understand two sets of tools. That said, maybe this is a great opportunity to move to text-based doc tools (latex, markdown, HTML, whatever) for non-customer-facing design docs.
  3. Like 1, but we hack up a git lock command that does what svn lock does for us (toggle the read-only flag appropriately and sync with a server through some means).
I don't buy the argument that locks don't work in a DVCS because the system should even work when you're entirely offline. Svn locks can be overridden as well; they're a communication mechanism. Without some sort of network connection, you won't get your computer to communicate a lot.
We can't be the only shop who're very happy with how svn lock fits in our workflow, right?
Any ideas or tips?
I found https://stackoverflow.com/questions/119444/locking-binary-files-using-git-version-control-system but the discussion is rather technical; i'm looking for ways to solve or avoid the practical problem of two team members editing the same binary file at the same time.
skrebbel
  • 326
  • Could you clarify how you "share" your documents with customers? I'm hoping they have read-only access and changes are managed by your team as the result of change requests from them. Is that correct? – vaughandroid Jan 22 '13 at 10:33
    You might want to use asset management tool (with locking feature) instead of a VCS for handling binary documents. I worked at a place that had 2 GB och images checked in SVN, which made committing everything else super slow. After we moved all that to a folder under back-up things got speedy and easier to handle. – Spoike Jan 22 '13 at 11:16
    @Baqueta By email or on paper. The point is that "Only use text for docs!" isn't a reasonable approach here, since the effort involved into making it look half-decent is much higher than in tools like MS Word. – skrebbel Jan 22 '13 at 12:32
  • @Spoike, sounds like a valid answer to me :-) Anyway, any recommendations? – skrebbel Jan 22 '13 at 12:33
  • @skrebbel One word, LaTeX. – remmy Jan 27 '13 at 21:05
  • @Demizey So you're suggesting we move our entire firm's document templates and stationery and *all* currently relevant documents for all projects for all our customers to LaTeX before we switch to git? Wow, Subversion looks a whole lot more attractive again. – skrebbel Jan 30 '13 at 12:32
  • To minimize conflicts (while providing better cross-platform support (OSX/Win/Linux)), I use git w/ OpenDocument (OpenOffice/LibreOffice), using master documents (.odm), isolating styles in templates (.ott). Actual edits are in "included" documents (.odt), ranging from one to 15 pages, included into the master(s). Images and other assets are external, also "included" in the ".odt" files. Conflicts can still be merged (OpenDocument has better tool & utility support than MS Office); and since styles are external, you just merge content. Hooks (or jenkins) can generate pdf's after a git push. – michael Jan 31 '13 at 11:56
  • @michael_n hey, that looks like a nice middle ground. Thanks for the idea! – skrebbel Feb 01 '13 at 09:55
  • Use the appropriate tools, for documents i would use tools as Samepoint, Microsoft SharePoint or alternatives (http://stackoverflow.com/questions/1096392/any-good-open-source-alternative-to-sharepoint) – alinoz Mar 30 '16 at 10:19
  • Have you considered using git with an external diff & merge tool for Word and Excel documents? [http://blog.martinfenner.org/2014/08/25/using-microsoft-word-with-git/] describes using pandoc for this. Would such an approach work? Or will the resulting conversions destroy the document in your case? – Kasper van den Berg Mar 30 '16 at 10:52
I would advise you to stay with SVN for the MS Office documents for two reasons:
  1. It is already there and it is (in my opinion) better for keeping Office documents (look here). Has much more third party tools for doing this.
  2. The lock, though can be achieved in Git, is not "the Git kind of way of doing things". If you need these features, stick with the tool that gives you the best solution.
There is a saying that I like that says something like this: "When You're Holding a Hammer, Everything Looks Like a Nail". Just because you are moving to Git to hold you code, it doesn't mean that you should use it to hold your documents.
Code version control is not the best tool to work on Office files, because they are binary and these tools work on file-level modification.
Use a collaboration tool, like MediaWiki (free) or Atlassian Confluence (paid), from which you can easily extract Word document. Or use LaTex to generate the Office files.
Let me expand...
If you need to collaborate you must adopt a model that highlights the modifications (e.g. changed a word, rephrased, or just changed a font) to a unit, e.g. a file.
SVN and Git, even if thought for code, are low-level tools that compare their files by textual content. But the problem is that they can work only on text files, because they don't care about the nature/contents of the file to extract a high-level modifications model.
A clear example is an image file. Though TortoiseMerge is a tool that helps SVN users by comparing the images for their real modifications, the normal VCSes run by content patches over the files. Let me explain. A tool such as TortoiseMerge can tell you that a new version of an image file is changed only by a few pixels, or luminance if it implements a more complex HSV analysis of the two files. You can add a watermark or change colour levels, a tool that compares image files will highlight you the differences if it implements good comparison algorithm. But in order to check the new file in your client must produce a delta. A delta is a set of lines that are removed and lines that are added to the file. Binary files have no line breaks if they don't happen to have \r\n, or similar, in their payload, and in a delta if you change a single character you are replacing an entire line.
So here is the problem. Binary files are not good for version control because you could be almost replacing the entire file for every revision. Consider when you write Office files using MS Office and your collaborator edits with OpenOffice. If they implement even a slightly different version of the compression algorithm of OpenXML files, you will end up in completely different files even if you changed a single comma in the document.
Collaboration softwares render documents internally in a text-based format, because text is what is really meaningful to your company, and can compute the differences or handle conflicts. LaTex, or Markdown if you like, is a way to store a document as a textual file with advanced markup, so not like the classic TXT file that has no font/formatting control.
But obviously your customers won't like to open Markdown files, will they? Ok, you can simply, and I really mean simply, use any software I'm currently too lazy to google for in order to convert a source document to PDF, Word or whatever.
Summarizing
If you start checking text files into your source control you have greater control over file history and can easily manage conflicts, especially without using VCS locks.
Before sharing a document officially you need a routine to export the source text document to an Office file
Separating the two steps makes people happy at the cost of a learning curve.
  • Linux and Mac text files don't have lines either according to your definition :-) deltas can be created for binary files just as easily. You decide on a different algorithm. SVN for example creates nice, small deltas just fine for binary files (at least with large .dll files which is what I have most experience with) – gbjbaanb Mar 30 '16 at 12:20
  • Yes of course non-Windows have different line terminators. Anyway even if you manage to create a smaller delta (I'll need to rephrase a bit of the answer) does it make differences human-readable? Of course not. You won't tell which classes have been modified between the DLLs. And again the problem is that two compiler **may** (I said **may**) produce completely different files by reordering the classes the way they like. That was the point of the answer – usr-local-ΕΨΗΕΛΩΝ Mar 30 '16 at 12:35
-1
You can use git for those documents without adding locking. Choose a git workflow that blocks pushes to the master branch if not on master. (There are several workflows to choose from.) This will prevent people from overwriting each other's modifications to binary document files. Assume two people modify the same binary document. The first one that pushes it to master gets their changes in. The second one will get blocked because their copy is behind the master branch. They have to synch first. So the second person does synch. It will show a merge conflict for the binary document. That person saves their version somewhere and resolves the conflict by taking the version from master (that was pushed by the first person). At this point the second person's files are up to date with the master branch. They merge in their changes to the latest binary document (by hand), which will then contain both the first person's and the second person's changes. Then the new version is pushed to master and becomes the new master branch. The merging is a pain, but it only happens when there is a conflict. Also, changes don't get lost or overwritten. The conflicts are detected and users are able to resolve them cleanly.
    Exactly this merging pain is what locks are supposed to prevent. – oefe Jan 27 '13 at 22:08
  • There are in fact merge tools that can merge Word documents. I don't have any experience with them however, so how good they are I have no idea of? – Pete Jan 30 '13 at 08:37
  • Thanks for your answer. I see that this is the Git way of working. @Pete, Word itself can do a pretty decent Diff, not sure about merge. But still, it's a pain that's easier avoided with locks. We seldomly edit Office documents simultaneously; most of our work (including detailed docs) are in the code. This question is about the 2% of cases where 2 people *do* edit the same document at the same time. Given that it's 2%, not 30%, a merge solution feels suboptimal. – skrebbel Jan 30 '13 at 12:33
-2
Put your first 2 solutions together and you don't need a third.
If you save your spreadsheets on disk as CSVs, Excel will still edit them and then git will be happy to merge them for you.
Similarly, you can open, edit, and save your files in Word if they are HTML or (god help us) RTF. Word of course will add more bloat than useful text, but it's still just text that git is happy to merge for you.
Granted, these solutions assume that you don't make use or could move away from MS-specific features which is really only possibly an issue on the Excel side.
Unless of course you also require Word to be installed on a system to be able to read your documentation, which is in itself a terrifying prospect to me...
Steven
