We recently had a consultant tell us that if a feature can only be tested via automated UI tests (e.g. Selenium, Coded UI), then there is an underlying architectural issue. While this statement might be a bit extreme, it is along the same lines of the testing pyramid in that UI tests should make up a small portion of your overall automated test suite.
So, what kinds of features should have automated UI testing? Will a system with a cogent architecture still have features that can only be verified through UI tests, or should these tests just serve as "back-up" for a suite of unit and service tests?
