I have a function that accepts either a string or a dictionary as an argument. That is, it can be called as either:
lookup_person({name: "John Smith", age: 57})
or
lookup_person("John Smith")
My first inclination is to use type
or isinstance
to distinguish the type of the argument, but I've seen a lot of ink spilled over whether and when rigid type detection is appropriate. The prevailing wisdom I've read suggests that I should test if my object implements some interface, but testing for particular string or dictionary methods seems significantly less safe than simply testing if the type of the object is a string or dictionary.
Is it possible to employ duck typing here, and is it appropriate to do so? Or do I have a larger problem, and my approach here somehow fundamentally not Pythonic?
EDIT: To clarify, passing a dictionary is the "typical" use. Passing in a string is simply an API shorthand for a single-entry dictionary with name
, i.e., lookup_person({name:"John Smith"})
