27
I recently came across some newly written code that was interspersed with lots of Debug.Assert (C#).
Should we still use this widely despite the usage of TDD, BDD and Unit Testing in general?
Dominik Fretz
  • 371
    I can't see how one excludes the other. – superM Jan 10 '13 at 08:07
    @superM I've definitely seen lazy developers add tests as asserts before as they had writen their code such that it was hard to mock out dependencies. needless to say I wouldn't recommend this – jk. Jan 10 '13 at 08:42
I don't see any reason why you shouldn't use Assert. By doing so you've already acknowledged a need for guards, like preconditions & invariants, and are making a move towards Design by Contract. Assert is only one way of achieving this...
// Precondition using Asert
void SomeMethod(Foo someParameter)
    Debug.Assert(someParameter != null)
// Precondition using If-Then-Throw
    if (someParameter == null)
        throw new ArgumentNullException("someParameter");
// Precondition using Code Contracts
    Contract.Requires(someParameter != null);
// Precondition using some custom library
    Require.ArgumentNotNull(() => someParameter);
All are ways of achieving the same thing: robustness in code. It just comes down to choosing an option, of which Assert is a valid choice.
Note that I have not mentioned unit tests at all so far, as they accomplish something very different. A unit test formally proves the robustness of the code by exercising a guard:
[Test]
void SomeMethod_WhenGivenNull_ThrowsArgumentNullException()
    delegate call = () => someObject.SomeMethod(null);
    Assert.That(call).Throws<ArgumentNullException>();
This is an entirely different kind of assert...
**Note that in some frameworks it's actually quite difficult to unit test for an assertion failure, as an assertion failure can bring down the entire runtime, so one of the other options might be preferred...*
Amy Barrett
  • 473
MattDavey
  • 7,096
  • 32
I consider asserts and unit tests to be two different tools in my toolbox. Some things are better suited to one, and some are better suited to the other.
As an example, these days I mostly make use of asserts to validate parameters for non-public methods.
vaughandroid
  • 7,569
I view Debug.Assert as premature optimization nowadays. Unless you really need the performance, suppressing the Assert in release mode can hide bugs for longer.
As MattDavey points out code contracts can be a superior, providing static checking instead of dynamic checking, and if not available I'd prefer Trace.Assert or a plain old if(x) throw SomeException;
jk.
  • 10,216
  • 43
    It is worth to mention that generating code with Visual Studio in release mode will cause all calls to methods of the `Debug` class to be skipped from compilation... so suppressing calls to `Assert` simply for performance is not just premature optimization, it is a plain nonsense. – Konamiman Jan 10 '13 at 12:47
  • @Konamiman that's the point, I almost always want it to fail in the same way in release mode :. Debug.Assert is of no use to me 97% of the time – jk. Jan 10 '13 at 12:50
  • What's that 3% then, @jk? Only legacy code, or some other instance? – DougM Feb 28 '14 at 14:08
    @DougM performance critical code, its a reference to the knuth quote. I'd also add that I think the heartbleed bug demonstrates that my view is the correct one, unless you have no other choice, do not elide precondition checks in your release code – jk. Apr 17 '14 at 12:35
