Personally, I would use Option #2. While I know it's very possible to solve the problem using EL and gain some bit of reuse across xhtml documents using functions or ui:params it really seems to lack the portability, maintainability and testability of the Java bean implementation.
If a developer is fluent in both EL and Java and owns both the xhtml and Java beans, it doesn't seem to make much sense to use EL to do ANY conditional evaluation with a size > 1.
There just seem to be too many benefits to implementing on the Java side:
- Ability to lean on the IDE + compiler
- Use constants or enums (for "dog" and "bark"), chances are they are being use elsewhere in the code for comparisons as well... if the String value changes it's real fun having to manually replace every occurance of it across a code base
- Instead of having to navigate to the page in question with appropriate data I can exercise logic using unit tests
One of the main arguments I've heard (outside of Stack) in favor of Option 1 is:
"It's a lot easier to see when a component renders if you keep this logic in the view."
I've found that this might be the case for an application in the initial stage of it's life where it's lighter weight and less complicated. However applying this practice on a larger scale and as a smaller application matures it can cause a rats nest of conditionals and become a nightmare to maintain. Here are a couple of examples similar to what I've seen out in the wild:
<h:outputText value="grrr"
render="#{animal.type == 'dog' or animal.type == 'cat' or animal.type == 'horse'
or animal.type == 'pony' or animal.type == 'mule' or animal.type == 'lion'
or animal.type == 'tiger' or (animal.type == 'bird'
and animal.subType == 'macaw') or .... continue this for another line or two}"
Or my favorite, using multiple components with render conditions that are exclusive of one another to represent the different values that could be displayed:
<h:outputText value="grr" render="#{theMonstrosityFromPreviousExample} />
<h:outputText value="cry"
render="#{animal.type == 'human' and animal.subType == 'baby'}" />
<h:outputText value="yo"
render="#{animal.type == 'human' and animal.subType == 'teenager'}" />
<h:outputText value="hello"
render="#{animal.type == 'human' and animal.subType == 'adult'}"/>
Can up to 4 texts be displayed at once? At first glance you can't tell, a check of each condition will be necessary. As a side note I realize this example is also poor design, as these could be put in a c:choose... but I've seen this before.
At the end of the day this is still theoretically 'view' logic since it determines what actually gets displayed so there's a conceptual argument it should live in the xhtml. The problem that I've found is that including logic like this in the view template can make the layout much harder to understand in the long run and I have yet to see that this method of solving the problem holds any real benefit over using the Java bean implementation.
