Before deciding on such security matters, you should assess the threat model. Without an idea what you're defending against, any measures you take are likely to be of little value.
Now, there are a few things you could worry about in this context:
- Attackers gaining physical access to your data (e.g., breaking into the datacenter, stealing backup tapes, etc.)
- Attackers gaining read access to your raw database
- Attackers compromising your application, e.g. through SQL injection, buffer overruns, etc.
For the first scenario, storing the database and all backups on encrypted volumes should work, provided the server is headless - stealing the server or the tapes would then require breaking the disk-level encryption.
For the second scenario, encrypting database data does help, but only if you don't store the required keys or passphrases anywhere.
In the third scenario, everything depends on the context in which the attack happens: if it is, for example, an XSS or CSRF attack, then an attacker can do anything the legitimate user can, and encrypting your data doesn't help at all.
You threat model, thus, is an attacker who gains read access to the raw database, either by finding the login credentials and managing to log into the database server from outside, or by gaining root access to the database server. A typical path is to first gain shell access on the web server; from there, an attacker can then read the access credentials from the configuration file and connect to the database.
An additional consideration is where you keep the keys and passphrases, especially if you're using a platform with a stateless execution model such as PHP. Ideally, you have the customer type their passphrase when required, and keep it only in memory, or even better, do the decryption client-side (but this is not often feasible). On a stateless platform, state is usually carried along using sessions, memcache, databases, or flat files; but all these are far more vulnerable than keeping state in a stateful web application's own memory. Avoiding this is a chicken-and-egg problem, because if you encrypt the state before persisting it, you just created another secret that you have to remember safely. Remembering the passphrase on the client and sending it along with each request that needs it may be the least horrible solution then; the client is still vulnerable if you have any XSS leaks, and you need to take the usual precautions (serve only https, set all cookies to httponly and secure, etc.), but those are issues you have anyway.
