I have just started working with symfony2 and have run across comment annotations.
Although comment annotation is not an inherent part of PHP, symfony2 adds support for this feature.
My understanding of commenting is that it should make the code more intelligible to the human. The computer shouldn't care what is in comments.
What benefits come from doing this type of annotation versus just putting a command in the normal PHP code?
ie-
 * @Route("/{id}")
 * @Method("GET")
 * @ParamConverter("post", class="SensioBlogBundle:Post")
 * @Template("SensioBlogBundle:Annot:post.html.twig", vars={"post"})
 * @Cache(smaxage="15")
public function showAction(Post $post)
Patrick
  • 2,922
  • This is a DocComment for the method, and as such it is supported by PHP. See http://php.net/manual/en/reflectionfunctionabstract.getdoccomment.php . There's a distinction between a comment and a doccomment. – bdsl May 08 '18 at 11:27
There are a few issues that immediately come to mind with comment annotations (and, particularly, symfony2's format):
  1. Developer Confusion The code you posted looks exactly like a DocBlock documentation comment. While the comments may be effectively interchangeable between the two meta-processors (each ignoring what they don't understand, or some using some other method of gracefully handling things), developers may or may not understand the purpose of a given comment, especially if they're not wholly familiar with one system or the other. Additionally, it opens the door to confusing annotations with documentation, which can lead to someone removing what they think is supposed to be documentation, but is actually "code".
  2. Potential Meta-Processor Conflicts Because of the above, what happens if one or the other meta-processor decides to be more strict and not allow what it doesn't recognize? Now your processor breaks at every conceivable point. Requiring you to spend time cleaning up, and inevitably losing something of value in the process (including time, and either documentation or annotations). If it must be done in comments (see advantages), then I would have at least gone with a different indicator to distinguish it from the documentation standard (a good example is SASS/Compass comments vs standard CSS comments; CSS /**/ comments are sent through to the compiled CSS, while non-CSS comments // are eaten by the compiler; additionally, it makes it fairly easy to distinguish between the two, simply by looking at the first two characters).
  3. Code/comment line-blurring In programming in general, code and comments are supposed to be separate. Code that's meant to be run shouldn't be in comments, usually for obvious reasons (because it doesn't run). You then start opening the door to doing other things inside comments, potentially pushing out the ability to actually comment, or having to jump through other hoops to distinguish between code-in-comment and actual comments (which will also increase compilation time/resources as the compiler has to go through more comments and determine whether they're meaningful, instead of just ignoring them all). Other alternatives I happened to see with a quick look on comments about Symfony's annotation, include C#'s style of wrapping angle brackets around annotations, Python's decorator style (basically what symfony already has, but not wrapped in comments), and probably just about any other style would be superior to doing it inside comments. (Or, to put it another way - It violates the "I don't need to look inside comments to find the source of bugs" rule.)
That said, doing something like this is not without its advantages.
  1. Adding functionality that is not available natively in the language. First and foremost, this is probably the reason it's done this way by Symfony. PHP doesn't have decorators/annotations, and therefore, if you want that feature, you have to find a way to implement it. Even more, if you want it and don't want your users to be dependent on PHP extensions (because they can't always control that level of their environment), you have to find a way to do it internally that won't break the PHP compiler. Comments are the obvious choice.
  2. Provide a clean way of adding various functionality to specific segments. Were I've seen annotations/decorators the most is Python, but you'll probably see it in a number of other languages, if you use them. For example, CherryPy uses it to expose functions as web page controllers (ie - a function with a specific decorator can be accessed by a browser, in the same way certain public functions in PHP controllers are accessed). They basically provide an "extension" capability to functions, or classes, offering utility features without cluttering the code inside the function.
Unfortunately, I don't know enough about Symfony to point out others with Symfony's format, but there's a lengthy discussion of the pros/cons of this in this Hacker News thread you might be interested in. You might also be interested in the request for change on the PHP site for native annotations.
Shauna
  • 3,519
The costs can effectively be neglected as this is indeed translated to PHP code and then cached. So unless you change the code often it just runs the PHP code(which in theory might even be faster code than what you'd write from hand)
The reason for doing is that this is a nice and compact way of providing this information to the system, these 5 lines would require, written in PHP a few lines more and it nicely fit's next to the thing it is related to.
On the downside each abstraction brings cost and adds a source for new bugs (what if the parser has a bug or generates buggy code?)
johannes
  • 3,601
  • 26
  • 32
    I don't believe that the costs here can be neglected just because they are translated to PHP code. There's still processing time involved with parsing these annotations and development time in training on how to properly use these annotations and the realization that *comments* are effecting *code execution*. – Charles Sprayberry Nov 29 '12 at 16:53
    Due to caching the time involved with parsing can be neglected except for development systems. Unless you have way too many of those on the development system it shouldn't be notable their either. ABout training costs: Yes, that can be true, but once trained this might be seen as "cleaner" code and better readable (once you know it) and therefore speed up again. But that's hard to measure objectivelzy. – johannes Nov 29 '12 at 18:39
To me it seems like a very bad practice. You could achive the same result with having meta functions returning this kind of metadata on functions, like showAction__META() for the above example, but avoid all the downsides - and there are many of them. The need for reading the source code just to run it, which kicks compiler/runtime optimisations in the head. It's also not directly testable, and needs special care when doing syntax checks. It's the same stupid reinvent-the-wheel aproach that various templating languages take, instead of using PHP directly.
Andris
  • 111
