We're currently reconsidering technologies and frameworks to get more agile with "simple" RMS CRUD-based projects. In short, short-living things like this
Right now we have a custom extension on top of SmartGWT but after some time it has proven not to be flexible enough.
I also personally dislike the java-js compilation process and the whole GWT codebase. Not only is the design ugly, it also makes certain low-level js things very complicated if not completely impossible. So what I'm looking for is:
- closest to web as possible, like JSF or possibly Tapestry, it is very important to be able get "low" and weave framework if necessary. Happens more often than we thought.
- datagrid capable - Ext.js & PrimeFaces looks pretty good, Vaadin does too.
- db-schema generators (optional, no matter in which way)
If it were only on me, I'd probably stick to Ext.js + custom rest-based java solution, possibly generated from database schema (not sure about concrete tooling yet).
I only have experience with vanilla Ext.js, vanilla GWT and JSF 2.0 / Seam, so it hard for me to judge or even propose other frameworks.
Whats your experience?
What are the downsides you've faced?
