I'm against compiled stuff going into version control, specially when it comes to compiled binaries, however, my principles are now in question after adding doxygen support for a project.
Should the hundreds of files generated by doxygen go into version control?, what is the recommended practice here?, I think the ideal would be automating the process in a server that publishes that documentation at the same time, however, there is no such server now nor there will be for some time.
dukeofgaming
  • 13,943
  • 50
  • 77
  • Ask yourself: What value does it add, and what does it cost? In general, it clutters repo history forever, and builds (including the documentation) should be reproducable by a single command anyway, so there ought to be little value. Plus, you can host the documentation on a shared network drive or something. –  Nov 13 '12 at 21:37
No.
Keep everything that you need to rebuild anything else. If it's auto-generated then you can go back to any point in the history of your repository and build it again. Why keep it?
pdr
  • 53,387
  • 137
  • 224
    Bingo. Anything you can generate should be treated like object code and should go away when you `make clean`. – Blrfl Nov 13 '12 at 21:47
