13
We are doing some refactoring to a 20 years old legacy codebase, and I'm having a discussion with my colleague about the comments format in the code (plsql, java).
There is no a default format for comments, but in most cases people do something like this in the comment:
// date (year, year-month, yyyy-mm-dd, dd/mm/yyyy), (author id, author name, author nickname) and comment
the proposed format for future and past comments that I want is:
// {yyyy-mm-dd}, unique_author_company_id, comment
My colleague says that we only need the comment, and must reformat all past and future comments to this format:
// comment
My arguments:
  • I say for maintenance reasons, it's important to know when and who did a change (even this information is in the SCM).
  • The code is living, and for that reason has a history.
  • Because without the change dates it's impossible to know when a change was introduced without open the SCM tool and search in the long object history.
  • because the author is very important, a change of authors is more credible than a change of authory
  • Agility reasons, no need to open and navigate through the SCM tool
  • people would be more afraid to change something that someone did 15 years ago, than something that was recently created or changed.
  • etc.
My colleague's arguments:
  • The history is in the SCM
  • Developers must not be aware of the history of the code directly in the code
  • Packages gets 15k lines long and unstructured comments make these packages harder to understand
What do you think is the best approach? Or do you have a better approach to solve this problem?
gnat
  • 21,442
  • 112
  • 288
Diego Alvarez
  • 233
    You really need to learn your SCM's blame/annotate/time-lapse feature. For each line in a file, it shows which revision that line was last changed in. No need to search through a long history. – Karl Bielefeldt Nov 07 '12 at 21:48
  • FWIW, where I work we use the third format (a basic comment) for ordinary descriptive comments, but are required to put author, date and time, and explanation when revisions to the code occur. However, there was dissent when this was implemented, for the reasons stated below. – Robert Harvey Nov 07 '12 at 21:59
    You need to improve your SCM process or toolset. And developers should be scared of changing *every* line regardless of how old it is. – Kirk Broadhurst Nov 08 '12 at 00:24
    I agree 100% with your colleague – wim Nov 08 '12 at 01:55
General Comments
I am a great believer in comments are for why (not how). When you start adding comments about how you fall into the problem that nothing is enforcing that comments be maintained in relation to the code (the why will usually not change (the why explanation may be enhanced some over time)).
In the same way date/authorInfo does not gain you anything in terms of why the code was done this way; just like the how it can degenerate over time because there is no enforcement by any tools. Also the same information is already stored in the source control system (so you are duplicating effort (but in a less reliable way)).
Going through the arguments:
Why. Neither of these things strike me as important to maintaining the code. If you need to talk to the author it is relatively simple to find this information from source control.
The code has life for that reason had an history.
History is stored in source control.
Also do you trust that the comment was written by that person. How comments tend to degrade over time so this kind of history becomes unreliable. Source control systems on the other hand will maintain a very accurate history and you can accurately see when comments were added/removed.
Because without the change date it's impossible to know when a change was introduced without open the SCM tool and search in the long object history.
If you trust the data in a comment.
One of the problems with this kind of things is that the comments become incorrect in relation to the code. Back to the correct tool for the job. The source control system will do this correctly without need for intervention from the user. If your source control system is a pain then maybe you need to either learn how to use it more appropriately (as that functionality is usually easy) or if does not support it find a better source control system.
because the author is very important, a change of authorx is more credible than a change of authory
All authors (apart from yourself) are equally credible.
Agility reasons, no need to open an navigate the SCM tool
If your source control tool are that burdensome you are wither using it incorrectly or (it is more likely) you are using the wrong set of tools to access the source control system.
people would be afraid of change something that someone did 15 years ago, than someting that was receantly made ...
If code has lasted 15 years then it is more likely to be more solid then code that has only lasted 6 months without needing review. Stable code tends to stay stable, buggy code tends to get more complex over time (as the reason it is buggy is the problem is not as simple as first thought).
Even more reason to use source control to get information.
Yes. Best reason yet.
Developers must not be aware of history of the code directly in the code
If I really need this information I will look it up in source control.
Otherwise it is not relevant.
Packages gets 15k lines long and unstructured comments this packages harder to understand
Comments should be a description of why you are doing something anyway.
Comments should NOT be describing how the code works (unless the algorithm is not obvious).
Martin York
  • 11,150
  • 42
  • 70
  • tks for your response, there is enough arguments to change my point of view :) – Diego Alvarez Nov 07 '12 at 21:27
    +1. Just one addition: it is much harder to lie to source control than to a text editor (or mistype, or lapse, or whatever). – tdammers Nov 07 '12 at 21:56
  • if we say that only eight months ago we started using SCM tools for plsql, and the code has 20 years, what do you think if we remove the author and date from historic comments of changes that are not in the SCM? it has any sense? or at this time does not make any sense know who and when a change was made 15-20 years ago? tks for you time and response. – Diego Alvarez Nov 09 '12 at 14:53
I strongly support your colleague. You won't get by without looking at the SCM anyway if you want to understand why something was changed unless you keep the old code in a comment.
If the code is too complex to be understood without writing tons of comments, I'd suggest investing you energy into refactoring to make the code readable/maintanable without tons of comments.
After all, you hire programmers, not story tellers ;-)
Axel
  • 161
