Possible Duplicate:
Do I need to use an interface when only one class will ever implement it?
I am taking over a project where every single real class is implementing an Interface. The vast majority of these interfaces are implemented by a single class that share a similar name and the exact same methods (ex: MyCar and MyCarImpl). Almost no 2 classes in the project implement more than the interface that shares its name.
I know the general recommendation is to code to an interface rather than an implementation, but isn't this taking it a bit too far? The system might be more flexible in that it is easier to add a new class that behaves very much like an existing class. However, it is significantly harder to parse through the code and method changes now require 2 edits instead of 1.
Personally, I normally only create interfaces when there is a need for multiple classes to have the same behavior. I subscribe to YAGNI, so I don't create something unless I see a real need for it. Am I doing it all wrong or is this project going way overboard?
