The solution for the 3-d case can be found here; I would like to get the generalized version. There's no simple generalization of the Mathworld algorithm since the cross product is defined only for 3 and 7 dimensions, so I understand.
This is a mathematics question rather than a programming question, isn't it? – Kirk Broadhurst Oct 11 '12 at 22:52
@KirkBroadhurst I was worried about that but I didn't see a 'Stack Exchange Algorithms' site, and there are lots of algorithms on this site--and FWIW I want this because I need to code it... – Matt Phillips Oct 11 '12 at 22:54
3You best bet is probably http://math.stackexchange.com – Robert Harvey Oct 11 '12 at 22:59
1I think we could use an appliedmath.stackexchange for this kind of question. So we could quit bothering the serious mathematicians 8^) – comingstorm Oct 11 '12 at 23:01
Wouldn't the computer science exchange be a better fit than the math? – sunnyrjuneja Oct 11 '12 at 23:46
Even if this weren't more a math question than a programming question, computer science proper doesn't have much to do with this kind of math. The closest fit to this question that I know of is gamedev.stackexchange.com, but there are plenty of applications for this kind of question outside of game development. – comingstorm Oct 12 '12 at 19:25
If you use vector algebra (which is easy with a vector algebra library), there is no real difference between the 3-d case and the N-d case. Unfortunately, the page you link to has written out the vector math element by element, which tends to obscure this.
So, paraphrasing from the article: given a line through two points A
and B
, the minimum distance d
to a point P
can be computed as:
n_vector pa = P - A
n_vector ba = B - A
double t = dot(pa, ba)/dot(ba, ba)
double d = length(pa - t * ba)
Note that adding two n_vector
's is just like adding a 3-vector, except you add N corresponding elements instead of 3 of them, and scaling an n_vector
by scalar t
is just like scaling a 3-vector except you scale N elements instead of 3.
Evaluating the length()
of an n_vector
is only slightly more complicated: you sum up the squares of all N elements (instead of just the 3), and take the sqrt()
of the result. Finally, as you may have guessed, the dot()
product is the sum of the products of the N corresponding elements (again, instead of just the 3).
- 2,727
- 1
- 13
- 14
Express the line as a function of a single parameter t. Call it X(t).
The distance from a point P to a point on the line X(t0) is just u(t) = || X(t0) - P ||, and you don't actually need to do the square root.
Now find the value of t that minimizes u(t). The standard method from first-semester calculus is to form the derivative du/dt, set it to zero, and solve for t.
If the line is actually a straight line, you will get one solution. If the line is a curve, you may get many solutions, and you'll have to look at all of them to find the actual minimum.
- 18,043
- 5
- 46
- 56
Hmm, I'm pretty sure derivatives aren't part of the standard 1st semester Calculus curriculum--they weren't in mine--but anyway, thanks. – Matt Phillips Oct 12 '12 at 01:32
@Matt, PLEASE tell me you're joking. If you didn't cover the basics of integration and differentiation of functions of one variable in 1st semester calculus, what DID you cover? – John R. Strohm Oct 12 '12 at 03:19
Ha, well it was a while ago now but certainly integration, and calculation of the derivative as the limit of (f(x+Dh) - f(x))/Dh. But DiffEq was a second year course, which is my biggest regret not taking as a math major. Tufts U., which is not a bad school. – Matt Phillips Oct 12 '12 at 18:19
The algorithm is to minimise the distance between the point and the line.
The line is a set of points. Write an equation to express the distance between the given point and each point in the line - it will be something like d = sqrt((a1 - b1)^2 + (a2-b2)^2 + ... + (an-bn)^2)
Now minimise that equation.
Rather than implement this algorithm yourself, I'd suggest you find a library for linear equations in your chosen language. I've heard of JAMA (for Java), but I have never needed to do this so haven't researched it.
- 4,199
- 18
- 27
