I have a condition
if(exists && !isDirectory || !exists)
how can I modify it, so that it may be more understandable.
I have a condition
is commutative so
if(!exists || (exists && !isDirectory))
is equivalent.
Now because exists is always true in the second part of the ||
you can drop the &&
if(!exists || !isDirectory)
Or you can go a step further and do:
if(!(exists && isDirectory))
As a process, I suggest building a truth table:
e = exists
d = isDirectory
e | d | (e && !d) || !e
0 | 0 | 1
0 | 1 | 1
1 | 0 | 1
1 | 1 | 0
This matches the NAND
operation, which is simply:
If you don't remember all your logic gates, wikipedia has a nice reference with the truth tables to boot.
@Christoffer Hammarström brought up an important point about the state of isDirectory
being tied to the state of exists
. Assuming that they refer to the same reference, and that it's not possible to have a state where the reference doesn't exist and is a directory, the truth table can be written as follows:
0 | 0 | 1
0 | 1 | n/a
1 | 0 | 1
1 | 1 | 0
The n/a
is used to represent a state that doesn't matter. Acceptable reductions could result in either 1
or 0
for states resulting in n/a
With this in mind, !(exists && isDirectory)
is still a valid reduction, resulting in a 1
for !e && d
However, !isDirectory
would be a much simpler reduction, resulting in 0
for !e && d
For better readability, I like to extract boolean conditions to methods:
if(fileNameUnused())
public boolean fileNameUnused() {
return exists && !isDirectory || !exists;
Or with a better method name. If you can name this method properly, the reader of your code doesn´t need to figure out what the boolean condition means.
You could just try to nail the no-go case and bail out if that shows up.
while(someCondition) {
if(exists && isDirectory)
continue;
// maybe "break", depends on what you're after.
// the rest of the code
or even
function processFile(someFile)
return false;
You can use a truth table as pointed out. Second step could be a KV-map for minimizing the number of terms.
Using the laws of Boolean algebra is another approach:
A = exists
B = !isDirectory
!A = !exists
[Edit]
A simpler transform, because the operations AND and OR are mutually distributive :
= A*B + !A
= (A + !A) * (B + !A)
= 1*(B + !A)
= B + !A
[/Edit]
= A*B + !A
= A*B + !A*1 //Identity
= A*B + !A*(B+1) //Annihilator
= A*B + !A*B + !A //Distributivity and Identity
= B*(A + !A) + !A //Distributivity
= B*1 + !A //Complementation 2
= B + !A //Identity
= !isDirectory || !exists
Or with double complement (!!x = x):
A*B + !A
= !!(A*B + !A)
= !(!(A*B)*A)
= !((!A + !B)*A)
= !(!A*A + !B*A)
= !(0 + !B*A)
= !(!B*A)
= B + !A
I don't like to use "!" when there is more than one condition in the expression. I'll add lines of code to make it more readable.
doesNotExist = !exists;
isFile = exists && !isDirecotry;
if (isFile || doesNotExist)
As previously indicated, the condition can be reduced to:
if (!(exists && isDirectory))
However, I'll bet that being a directory implies existence. If so, we can reduce the condition to:
if (!isDirectory)
