26
Computers have trouble storing fractional numbers where the denominator is something other than a solution to 2^x. This is because the first digit after the decimal is worth 1/2, the second 1/4 (or 1/(2^1) and 1/(2^2)) etc.
Why deal with all sorts of rounding errors when the computer could have just stored the decimal part of the number as another whole number (which is therefore accurate?)
The only thing I can think of is dealing with repeating decimals (in base 10), but there could have been an edge solution to that (like we currently have with infinity).
SomeKittens
  • 4,220
  • 38
    You should look up how decimal types are stored, in contrast to float/double types. – Oded Oct 02 '12 at 21:13
    Don't know how that is any more accurate. The first digit after the decimal is 1/10 the second 1/100 etc. How is that any more accurate you still get rounding problems (how do you represent 1/3)? The only difference is which values that can be represented exactly. – Martin York Oct 02 '12 at 21:17
    Decimal floating point (which is what you're referring two, just in a more awkward representation) is no more inaccurate than binary floating point. The only difference is which values can't be represented, and because we're used to the decimal system we don't notice the errors of the decimal version. And no, neither can represent all rational and irrational numbers. –  Oct 02 '12 at 21:19
    At the end of the day, it boils down to efficiency. Computers are binary and the circuits to work with this binary representation are far less complex. The importance of this may be somewhat diminished today, but thre was a time when this was very significant. Also any representation you choose to store your number (in a finite space) on a computer will have a finite set of values it can represent and all of them will exhibit rounding errors with some inputs. The typical floating point format with Mantissa and Exponent offers a far greater range then would be possible using two integers. – Mr.Mindor Oct 02 '12 at 21:45
    I would highly recommend reading through some of the articles referenced in [my answer](http://programmers.stackexchange.com/a/101197/22493) to the question [What causes floating point rounding errors?](http://programmers.stackexchange.com/q/101163/22493) which I have just updated with details of the last article in the referenced series. In particular, take a look at [Why Fixed Point Won't Cure Your Floating Point Blues](http://accu.org/index.php/journals/1717). – Mark Booth Oct 03 '12 at 14:07
6 Answers6
38
There are numerous ways of storing fractional numbers, and each of them has advantages and disadvantages.
Floating-point is, by far, the most popular format. It works by encoding a sign, a mantissa, and a signed base-2 exponent into integers, and packing them into a bunch of bits. For example, you could have a 32-bit mantissa of 0.5 (encoded as 0x88888888) and a 32-bit signed exponent of +3 (0x00000003), which would decode to 4.0 (0.5 * 2 ^ 3). Floating-point numbers are fast, because they are implemented in hardware, and their precision scales with absolute size, that is, the smaller the number, the better your absolute precision, so the relative rounding error stays constant with absolute size. Floats are excellent for values sampled from a continuous domain, such as lengths, sound pressure levels, light levels, etc., and because of that, they are commonly used in audio and image processing, as well as statistical analysis and physics simulations. Their biggest downside is that they are not exact, that is, they are prone to rounding errors, and they cannot accurately represent all decimal fractions. All the mainstream programming languages have a float point of some sort.
Fixed-point works by using sufficiently large integers and implicitly reserving a part of their bits for the fractional part. For example, a 24.8 bit fixed-point number reserves 24 bits for the integer part (including sign), and 8 bits for the fractional part. Right-shifting that number by 8 bits gives us the integer part. Fixed-point numbers used to be popular when hardware floating-point units were uncommon or at least much slower than their integer counterparts. While fixed-point numbers are somewhat easier to handle in terms of exactness (if only because they are easier to reason about), they are inferior to floats in pretty much every other regard - they have less precision, a smaller range, and because extra operations are needed to correct calculations for the implicit shift, fixed-point math today is often slower than floating-point math.
Decimal types work much like floats or fixed-point numbers, but they assume a decimal system, that is, their exponent (implicit or explicit) encodes power-of-10, not power-of-2. A decimal number could, for example, encode a mantissa of 23456 and an exponent of -2, and this would expand to 234.56. Decimals, because the arithmetic isn't hard-wired into the CPU, are slower than floats, but they are ideal for anything that involves decimal numbers and needs those numbers to be exact, with rounding occurring in well-defined spots - financial calculations, scoreboards, etc. Some programming languages have decimal types built into them (e.g. C#), others require libraries to implement them. Note that while decimals can accurately represent non-repeating decimal fractions, their precision isn't any better than that of floating-point numbers; choosing decimals merely means you get exact representations of numbers that can be represented exactly in a decimal system (just like floats can exactly represent binary fractions).
Rational numbers store a numerator and a denumerator, typically using some sort of bignum integer type (a numeric type that can grow as large as the computer's memory constraints allow). This is the only data type out of the bunch that can accurately model numbers like 1/3 or 3/17, as well as operations on them - rationals, unlike the other data types, will produce correct results for things like 3 * 1/3. The math is pretty straightforward, although coming up with an efficient factoring algorithm is rather challenging. Some programming languages have rational types built into them (e.g. Common Lisp). Downsides of rationals include that they are slow (many operations require reducing fractions and factoring their components), and that many common operations are hard or impossible to implement, and most implementations will degrade the rational to a float when this happens (e.g. when you call sin() on a rational).
BCD (Binary Coded Decimal) uses "nibbles" (groups of 4 bits) to encode individual digits; since a nibble can hold 16 different values, but decimal numbers require only 10, there are 6 "illegal" values per nibble. Like decimals, BCD numbers are decimal-exact, that is, calculations performed on decimal numbers work out just like they would if you did them using pen and paper. Arithmetic rules for BCD are somewhat clumsy, but the upside is that converting them to strings is easier than with some of the other formats, which is especially interesting for low-resource environments like embedded systems.
Strings, yes, plain old strings, can also be used to represent fractional numbers. Technically, this is very similar to BCD, only that there's an explicit decimal dot, and you use one full byte per decimal digit. As such, the format is wasteful (only 11 out of 256 possible values are used), but it is easier to parse and generate than BCD. Additionally, because all the used values are "unsuspicious", harmless, and platform-neutral, string-encoded numbers can travel over networks without problems. It is uncommon to find arithmetic being done on strings directly, but it is possible, and when you do it, they are just as decimal-exact as the other decimal formats (decimals and BCD).
tdammers
  • 52,406
  • 106
  • 154
  • Surely 32-bit fixed point has more precision than 32-bit floating point, since fixed point representations do not include a mantissa. – han Oct 03 '12 at 04:55
    @han: Depends on the size of the number you want to store. Floats will (roughly) give you the same precision no matter how large or small the number is while fixed point will only give you full precision if the number you wish to store fits perfectly into its range. – Leo Oct 03 '12 at 06:42
  • @han Not necessarily, both still can represent 2^32 distinct values. The amount of carried information is identical, regardless of presentation. Range and precision go hand in hand though, so on that regard fixed-point arithmetic can be more accurate in certain ranges. And avoids nasty random rounding issues, if you know the limits within which you can work with. – zxcdw Oct 03 '12 at 10:15
  • @han: they have the same precision (or almost). The difference is that for fixed-point numbers, the precision (as in the size of a discrete step from one number to its successor) is constant, just like with integers, whereas with floats, it grows roughly linearly with absolute value - the float number 1.0 has more precision to it than the number 10,000,000.0 (a million times more, roughly). – tdammers Oct 03 '12 at 14:11
35
There are actually modes of numbers that do that.
Binary-coded decimal (BCD) arithmetic has the computer work in base 10. The reason you run into this rarely is that it wastes space: each individual digit of a number takes a minimum of four bits, whereas a computer could otherwise store up to 16 values in that space. (It can also be slower, but it's possible to have hardware-accelerated BCD math that works just fine.). This is, in fact, exactly what most calculators do, which is why there are certain classes of rounding problems you'll never hit on a $5 Casio that will eat your lunch on a desktop computer.
The other route you can take is to use rational numbers--that is, a numerator and a denominator, stored as integers. This is actually available in nearly all languages, is exact, and allows you to store everything in native binary formats. The problem is that, at the end of the day, users probably do not want to see fractions like 463/13, nor even 35 and 8/13. They want to see 35.615..., and the moment you get there, you face all the typical problems. Add in that this format takes even more space, and can be significantly slower than floating point arithmetic, and you'll find no computers use this format by default.
So: computers can do what you want, but it's slow and it wastes space, so they only do it when they really have to. The rest of the time, the speed and space savings of floating point are a better trade-off.
Benjamin Pollack
  • 1,183
  • Don't you mean *four bits* (not bytes) in the BCD paragraph? –  Oct 02 '12 at 21:20
    The other option is fixed point arithmetic, where an integer represents a decimal fraction if a number - e.g. Storing money values (without calculations involving decimals or percentage) where 1 represents $0.01. – mattnz Oct 02 '12 at 22:35
    @mattnz: True—fixed-points are a special case of rationals. – Jon Purdy Oct 03 '12 at 00:20
  • Awesome, didn't know that calculators did that. – SomeKittens Oct 03 '12 at 01:05
  • The major thing you miss with fixed point or rationals compared to floating point is range. conversion to decimal is not really an issue as long as its done for display only – jk. Oct 03 '12 at 08:44
    There is a third option. Floating point with a decimal exponent, like how C# `decimal` is implemented: http://stackoverflow.com/a/5019178/174335 It's not BCD as there is no individual representation of decimal digits, and it's not fixed point. – Joren Oct 03 '12 at 14:50
  • s/regally/really in the last paragraph – Ptharien's Flame Oct 04 '12 at 04:22
  • @joren You're completely right, but that's (in my opinion) more an optimization of rational numbers than its own format, so I think it can safely be skipped for the purposes of asking the original question. – Benjamin Pollack Oct 04 '12 at 15:19
Floating point numbers represent a vast range of values, which is very useful when your don't know ahead of time what the values might be, but it's a compromise. Representing 1/10^100 with a second integer wouldn't work.
Some languages (and some libraries) have other characteristics. Lisp traditionally has infinite precision integers. Cobol has calculations with fixed point decimal numbers.
You have to select your number representation appropriate to the problem domain.
ddyer
  • 4,060
It sounds like you're describing fixed-point numbers.
Bear in mind that storing the fractional part of a number in a separate location is precisely identical to creating a single space, twice as long, and storing the whole and fractional part in the two separate halves. In other words, it's identical to storing the number as an integer but simply assuming a fixed number of decimal spaces.
Normally floating-point numbers are stored using a binary variation on scientific notation because what usually matters is significant digits. Many other methods exist though. Fixed-point decimal numbers are commonly used for example for storing currency values, where accuracy is critical up to a certain whole number of decimal places but the number of required decimal digits never changes.
tylerl
  • 4,850
  • 32
The short answer is that floating point was designed for scientific calculations. It can store a number with (up to) a specified number of significant digits, which fits closely with how precision is measured in most scientific calculations.
That tends to be supported in hardware largely because scientific calculations have tended to be the ones that benefited the most from hardware support. For one example, financial calculations are often done with other formats -- but financial software usually does little enough real calculation that even though the necessary formats are only supported in software, performance remains perfectly adequate for most financial software.
Jerry Coffin
  • 44,385
  • 89
  • 162
That would be called BCD, I think you can still use it if you really want to. However it's not really worth it as:
  1. You'll very rarely run into a rounding error with 64 bit floating point
  2. It makes the arithmatic complex and inefficient
  3. It wastes 6 values every 4 bits
Inverted Llama
  • 413
  • BCD math was used a lot on early 8-bit microprocessor systems; indeed, on one popular microprocessor (the 6502), addition and subtraction with BCD are just as fast per byte as with binary. Video games frequently used BCD math for score-keeping. There's no special handling for scores wrapping at 1,000,000 points. Instead, adding 1 to "99 99 99" yields "00 00 00" with a carry which is ignored. The extra overhead of adding scores at BCD is tiny compared with the cost of converting a binary value to displayable format. – supercat Sep 13 '13 at 20:21
