Nice in theory, terrible in practice
By CSV I'm going to assume you mean the convention as described in RFC 4180.
While matching basic CSV data is trivial:
"data", "more data"
Note: BTW, it's a lot more efficient to use a .split('/n').split('"') function for very simple and well-structured data like this. Regular Expressions work as a NDFSM (Non-Deterministic Finite State Machine) that wastes a lot of time backtracking once you start adding edge cases like escape chars.
For example here's the most comprehensive regular expression matching string I've found:
re_valid = r"""
# Validate a CSV string having single, double or un-quoted values.
^ # Anchor to start of string.
\s* # Allow whitespace before value.
(?: # Group for value alternatives.
'[^'\\]*(?:\\[\S\s][^'\\]*)*' # Either Single quoted string,
| "[^"\\]*(?:\\[\S\s][^"\\]*)*" # or Double quoted string,
| [^,'"\s\\]*(?:\s+[^,'"\s\\]+)* # or Non-comma, non-quote stuff.
) # End group of value alternatives.
\s* # Allow whitespace after value.
(?: # Zero or more additional values
, # Values separated by a comma.
)* # Zero or more additional values
$ # Anchor to end of string.
It reasonably handles single and double quoted values, but not newlines in values, escaped quotes, etc.
Source: Stack Overflow - How can I parse a string with JavaScript
It's becomes a nightmare once the common edge-cases are introduced like...
"such as ""escaped""","data"
"values that contain /n newline chars",""
"escaped, commas, like",",these"
"un-delimited data like", this
"","empty values"
"empty trailing values", // <- this is completely valid
// <- trailing newline, may or may not be included
The newline-as-value edge case alone is enough to break 99.9999% of the RegEx based parsers found in the wild. The only 'reasonable' alternative is to use RegEx matching for basic control/non-control character (ie terminal vs non-terminal) tokenization paired with a state machine used for higher level analysis.
Source: Experience otherwise known as extensive pain and suffering.
I am the author of jquery-CSV, the only javascript based, fully RFC-compliant, CSV parser in the world. I have spent months tackling this problem, speaking with many intelligent people, and trying a ton if different implementations including 3 full rewrites of the core parser engine.
tl;dr - Moral of the story, PCRE alone sucks for parsing anything but the most simple and strict regular (Ie Type-III) grammars. Albeit, it's useful for tokenizing terminal and non-terminal strings.
