This is a very good question, and a common problem in advancing JavaScript architecture.
It sounds to me like you are describing the situation of "tight-coupling".
Once functions become objectified, the tendency is to reference these wonderful objects directly, from object to object, across namespaces even. Because it is easy right?
var Object1, Object2 = {};
Object1.somefunction = function(){
//Tight Coupling!!
Object2.functionCall();
It is easy, but these seemingly innocent hard-references gang up, to make you sad when you have to remove or replace objects. That happens a lot in JavaScript, so understanding tight-coupling is key to making a JS codebase maintainable.
Here are some other thoughts:
1 - If your objects are not already communicating by - triggering and listening to events; they should be. This is the solution to hard references.
2 - Design Patterns. There are many challenges that have already been solved out there, the standardized reusable solutions - are Design Patterns.
Understanding where the patterns are helps you focus on what solutions may make sense. One pattern for communicating across objects is called Publisher/Subscriber, or PubSub.
3 - These things help with maintainability: MVC with a router, Templates - data binding, AJAX - through a Proxy or Delegate objects.
4 - Look for frameworks and libraries that solve the cross-browser problems for you. Don't re-invent the wheels you don't need to know more about. Depending on your environment, some may frameworks may become obvious choices.
5 - Think about enhancement and optimizations like build systems, minification, linting, tdd, etc.
6 - Also, most important of all: Module Loaders. Take a look at Require.js It is a very nice way to break JS into modules, and then load them all in an optimized way.
Hope that helps.
