One of the problems is that you may find yourself writing lots of code to express something in a way you will do in another language, while there is a more straightforward way in the language you use.
For example, in an answer on Stack Overflow, I've explained how code contracts, concept used in .NET Framework, can be partially emulated in PHP which doesn't support them. I ended up writing lots of code for nothing, since the same thing was doable with simple arrays.
More generally, each language has its own culture, its own best practices, its own style.
If I start writing C# code like it was C, it would be ugly.
If I apprehend Haskell as a Java developer who was forced to use Haskell, but don't want to understand its strengths and just want to clone the concepts of Java, the code I would write will suffer.
etc.
There is nothing wrong trying to enhance the language (for example enhance C# by introducing units of measure like in F#), but if you are doing it too much, you should maybe choose a different language which actually fits your needs.
