What is the best practice for packaging Java enums?
is it separate file for each enum?
or
having same file for all the enums?
What are the pros and cons ?
or
First, an overriding rule is that if an enum
is public, it must be declared in a file of its own. This is a Java rule that applies to all classes, interfaces, and enum
s, which cannot be broken.
For non-public enum
s, you should follow the same rule, except when multiple enum
s are closely connected.
For example, if you are building an expression processor and declaring an enumeration for an expression sub-type, a binary expression sub-type, and a unary expression sub-type, you may want to group the three enumerations together in a single file.
Enums are classes so you should pack them as ordinary classes. If the enum is used in many places inside the package then put it in a single file. If the enum is strongly linked with a class, then put it as a public (or protected) static inner class.
I do not see reasons for placing all the enums in a single file unless they are related.
