64
A few months ago, we started developing an app to control an in-house developed test equipment and record a set of measurements. It should have a simple UI, and would likely require threads due to the continuous recording that must take place. This application will be used for a few years, and shall be maintained by a number of computer science students during this period.
Our boss graduated some 30 years ago (not to be taken as an offense; I have more than half that time on my back too) and has mandated that we develop this application in ANSI C. The rationale is that he is the only one that will be around the entire time, and therefore he must be able to understand what we are doing. He also ruled that we should use no abstract data types; he even gave us a list with the name of the global variables (sigh) he wants us to use.
I actually tried that approach for a while, but it was really slowing me down to make sure that all pointer operations were safe and all strings had the correct size. Additionally, the number of lines of code that actually related to the problem in hand was a only small fraction of our code base. After a few days, I scrapped the entire thing and started anew using C#. Our boss has already seen the program running and he likes the way it works, but he doesn't know that it's written in another language.
Next week the two of us will meet to go over the source code, so that he "will know how to maintain it". I am sort of scared, and I would like to hear from you guys what arguments I could use to support my decision.
Cowardly yours,
gnat
  • 21,442
  • 112
  • 288
rick
  • 1,945
  • 220
    "Oh no, this is not the final version, it's just a C# version we quickly wrote in a few days for prototyping and testing, to make sure we understood the requirements and to fine-tune the UI. Implementing this in ANSI C will take another X weeks, because, you know, we have to work around not having all those fancy data structures. ... Well, yes, now that you mention it, the C# version *does* already do everything the final program should, but you said you need it in ANSI C. ... OK, if you insist, let's stay with this version..." – Heinzi Sep 07 '12 at 05:17
    @Heinzi: I've had the same experience: Writing a C# prototype of a library in 2 days, and spending several weeks rewriting it in C. Fortunately, after that project, I was offered the chance to transfer to another team with a more sensible language choice. – dan04 Sep 07 '12 at 06:31
    You need real-time an you argue that manage language is better than C, when all the hurdles of maintenance will fall on another guy? Good move. – Oleg V. Volkov Sep 07 '12 at 09:22
    @OlegV.Volkov "Real-time" does not necessarily mean "fast" (e.g., sub-milisecond latencies). Since it's running on non-RTOS, it doesn't matter whether it's C or C#, if it's *fast enough*. – zvrba Sep 07 '12 at 09:50
    Could you perhaps mention exactly _why_ ANSI C is inadequate? You not being able to program it quickly is most likely not enough on its own to make the platform inadequate. –  Sep 07 '12 at 11:58
  • 49
    Global variables and threads? You are in trouble, my friend, regardless of the programming language you use. – Nemanja Trifunovic Sep 07 '12 at 12:43
    C#? Nooooo! C# was a Microsoft creation - no effort was originally put into running on non-Microsoft platforms. Yes, there's Mono and .GNU now, and I use Banshee on Linux, but it crashes every day. Java was designed to run everywhere equally well. It's practically the same language, only it's always been cross-platform and now it's open-source too! – GlenPeterson Sep 07 '12 at 13:35
    The argument you really need is why you should keep your job. – epo Sep 07 '12 at 14:35
    added to favorites just to see what will happens ! Be sure to give us an update – Tarek Sep 07 '12 at 14:54
    Your assumption is incorrect - ANSI C is adequate for nearly *all* projects. That's why it's still popular after all these years. Whether it's optimal or not is a different question. – Mark Ransom Sep 07 '12 at 15:25
  • By the way, regarding strings at least, there's the [bstring library](http://bstring.sourceforge.net/) around, which sounds like it might make your life somewhat easier in this area. – akavel Sep 07 '12 at 15:26
    Setting aside the technology debate, I think you're in deep doo-doo here. It sounds like you've been developing in C# for far too long to pass off the result as a quick prototype. – mackenir Sep 07 '12 at 15:27
    I think you should let him do the project by himself, if he knows the best way and dictates things even at the micro level, why does he need you the minion around ? Hows the job market in your area - just curious ;-) ? – JVXR Sep 07 '12 at 04:58
    @dan04: Why spend two full days writing the prototype in C# if you could have written it in Haskell in one day? – Giorgio Sep 07 '12 at 18:09
    @justifiably - now it's been next week. How did it go? –  Sep 14 '12 at 05:46
    The problem here isn't so much "use ANSI C", but "use C as if it were Fortran 66, without data abstraction". C was used with data abstraction from the beginning, when they made Unix. – Kaz Oct 18 '13 at 05:37
    I want to know if your boss kicked your ass or not ;) – Sam Watkins Nov 10 '14 at 23:51
  • So, did you get sacked? Can your boss maintain the C# code himself? – Mawg says reinstate Monica May 13 '15 at 09:33
  • I don't understand why the boss would be the one to maintian your code. have you no fellow team members? – Mawg says reinstate Monica May 13 '15 at 09:34
  • @Mawg, in this situation the boss is the only constant figure in the shop - lots of graduate and undergraduate students coming and going, though. – rick May 14 '15 at 13:20
11 Answers11
108
Notice that the "Please do it like this so I am sure I can maintain it" is actually a very good requirement - most programs spend much longer being maintained than being written and keeping a solution in a known technology is usually a good idea.
Just imagine if some new computer kid when asked for writing a C# application wrote it in Haskell in two days and said "Hey, it works and I'm gone, bye" leaving the maintenance on you.
Just imagine if some new computer kid when asked for writing an ANSI C application 15 years ago had written it in Visual Basic 6 in two days and left it. Now you have to maintain it and Windows 7 starts complaining already when the installation media is inserted.
This might be a good opportunity to say - as Heinzi hinted in the comments - that "this is a quick prototype written in C# which happens to look very much like C - shall we make it production ready, or reimplement it in ANSI C like you asked", and then take the discussion now. Having actual source to see, is much better than "Hey, shouldn't we write our next application in Haskell because its faster".
In other words - you now have the opportunity to demonstrate that a new platform could be considered. Bring up that you wrote a prototype before the code review - this will help removing the impression that you are trying to sneak C# in under the radar. I would suggest that you also demonstrate that all existing code written in ANSI C can be used from within C#. Personally I believe you will be told that the target remains ANSI C to stay in a single platform.
  • 26
    +1: for pointing out the requirement "do it like this so I am sure I can maintain it". C# is for sure much easier / faster than C to develop in (in general), but C has changed in the last 30 years less than C# has changed in the last 15 years. So for a product that has to be maintained over many years C could be better suited. You have to compromise between all requirements: complexity of the project (C# is probably a better choice), long term maintenance (C seems to be more stable), who is going to do the maintenance, etc. – Giorgio Sep 07 '12 at 05:40
  • VB6 installs just fine on Windows 7...:-) – Matt Sep 07 '12 at 08:11
  • @Matt On 64 bit? –  Sep 07 '12 at 08:13
  • @ThorbjørnRavnAndersen - Of course it does. Granted the application would be a 32-bit process. I often run tools written in VB 6 on both 64-bit versions of Windows 8 and Windows 7 – Ramhound Sep 07 '12 at 12:08
    @Ramhound I am not talking about VB6 support, but about supporting the Visual Basic 6 _development environment_. My copy of Windows 7 explicitly notified me when inserting the installation media that this was not a good idea. –  Sep 07 '12 at 12:16
    I'm not saying its a good idea, but using the VB6 IDE on Win7 64 bit is possible, I've seen it. Installing it does require some sort of workaround. – Jeanne Pindar Sep 07 '12 at 13:46
    Good points, but what if the boss had asked for it to be written in COBOL? Or 6502 assembly? At what point can you say to your boss, "That language is obsolete for this purpose, and once *you're* gone there will be *no-one left* who understands this stuff"? – Ant Sep 07 '12 at 15:03
    @Ant it depends on all other software they have in department. If all software is in ANSI C, than if the boss leaves, they will have to find someone who knows ANSI C. There's no reason to have software written in all different languages based on developer's whim - even if this one program is better in the language. But I see nothing wrong with suggesting C#. – Alex Sep 07 '12 at 17:11
    @Alex: Consistency is nice, true. But would you write a new web system in C if all of the other (non-web) software written by your department was written in C? I think it comes down to a balance between choosing the appropriate technologies for the system you're writing versus the team's existing skills. Choosing a language with no deliberation because that's what you always use can be detrimental. – Ant Sep 07 '12 at 17:24
    @ant, the one who pays the band get to choose the music. (and we are a COBOL shop - no problem supporting that) –  Sep 07 '12 at 18:41
    There's more COBOL code in production than any other single language. So to get away from having someone around who understands COBOL, you better be ready to write a *lot* of software. – philosodad Sep 08 '12 at 18:47
35
Your boss would seem to be your customer in this case, and his primary requirement is that he be able to maintain the application when you move on. This seems quite reasonable.
So, the choice is to do what he asks, or demonstrate that you can complete development AND teach him how to maintain a C# application within the time constraints and at a lower cost. If you cannot do that, you are not meeting the requirements of the project.
Matthew Flynn
  • 13,345
  • 38
  • 57
    The OP explicitly ignored requirements without notification or discussion. Were the boss a commercial customer he could refuse payment and possibly sue for costs incurred due to wasted time. Reverse the roles, what if you e.g. ordered a bespoke suit and found the tailor didn't like working with the cloth you specified so silently substituted one he did like, in his choice of colour? The OP's problem now is that he can't be trusted with projects without close supervision, demonstrably lacks people skills and has no respect for management. – epo Sep 07 '12 at 14:32
    @epo I believe I understand your assertion that the boss can't trust the OP since they didn't do what was asked. However, if he is a reasonable manager, that shouldn't happen. If the dev approached the manager with a better solution than originally considered, I would hope the manager would be open to it. If I may modify your example slightly, it is like the tailor making a suit in the desired color/pattern with a newer, more durable, better feeling, and cheaper type of cloth than what was asked for even though the buyer asked for a type of cloth they were familiar with. – Taylor Price Sep 07 '12 at 15:35
  • That being said, I also agree that, in this case, maintenance is an important requirement. The OP is now beholden to prove to the manager that they solved the rest of requirements in a way that the manager can quickly and effectively learn to maintain. – Taylor Price Sep 07 '12 at 16:02
26
You haven't given a lot of info but I think C is absolutely the right choice - I work as an Engineer in an industrial plant and most (if not all) of our code is written in C. If you need to get measurements from a device (I'm assuming a flow meter or thermocouple or similar here) and display it in near to realtime C is an excellent choice.
It's fast, portable (I've never written in C# but I don't think it works without a particular version of the framework installed and it is usually only windows based).
By all means you could use another language to do the GUI. But you could save yourself the effort and just use a pre-existing trending package (there are some good opensource ones available).
To summarize I'd say for the underlying interfacing with hardware part C is a fine choice.
superM
  • 7,363
  • 38
Matt
  • 277
    I've had more success porting C# code from Windows to Linux (using Mono) than I've had with C++ code. – dan04 Sep 07 '12 at 06:37
    @dan04: What problems did you have with C++? I thought C++ would be quite portable. Also, C++ is not C. I always found using C with the GNU C library pretty portable, e.g. between GNU Linux and cygwin. – Giorgio Sep 07 '12 at 09:18
    @dan04 C != C++. –  Sep 07 '12 at 11:55
    @Giorgio: An annoyingly large part of it was strings. We had to take out all of the Windows-specific `TCHAR` crap (which we weren't using consistently anyway) and adopted a team standard of using [UTF-8](http://www.utf8everywhere.org) at the same time as the Linux transition. Unfortunately, this required re-implementing a big chunk of the standard library on Windows, [`boost::nowide`](http://cppcms.com/files/nowide/html/) not having existed at the time. – dan04 Sep 07 '12 at 13:04
    @dan04: As said, C is certainly not as expressive as C# (or C++ for that matter), but I have been using the GNU C library (http://www.gnu.org/software/libc/) since 1997 and that's really stable and portable. For C++ I would look at Qt (or at boost and the standard libraries) because they are quite portable. I would avoid Windows-specific stuff if possible: AFAIK it has never been Microsoft's goal to produce portable software since customer lock-in is part of their marketing strategy. – Giorgio Sep 07 '12 at 13:22
    @dan04 totally agree. I've also found porting C code much more error prone than C#, especially on embedded linux. – dodgy_coder Sep 07 '12 at 16:03
24
Oh dear. This is a real-time application? Controlling equipment in real time? Gathering data in real-time? Using a language with a garbage collector? Oh dear.
While I agree that you can probably do the app in a more modern language in less time, that's probably not the major criterion. EASE OF YOUR PROGRAMMING IS PROBABLY MUCH LESS IMPORTANT THAN THE OTHER CRITERIA, such as the ones your boss laid down, AND response time, and deterministic behavior.
I would have suggested you do a prototype in C# or Python, just to test out the main functionality and UI. THEN test the heck out of it, measuring actual latencies and response times, when the app gets hit with a lot of data, over many days of continuous running. Odds are, the app could end up being too slow or fall behind at random times, when VM or the garbage collector kicks in.
I suggest you present what you've done as a PROTOTYPE.
Coding in C isn't that hard. If you're not up to it, say so. There's plenty of us up for the challenge. ( I've been doing real-time C coding for, argh, decades now ).
Gumpy Gus
  • 249
    Lets phrase the first bit differently. _Oh dear. This is a real-time application? Controlling equipment in real time? Gathering data in real-time? RUNNING ON A NON-REALTIME THREADED ENVIRONMENT? Oh dear._ You are always going to have to sample when you cross device boundaries. 'Real time' is a straw-man argument and an ill defined requirement. C# is fine. – Gusdor Oct 17 '13 at 10:45
  • You've obviously not heard of [Joe Duffy's work](https://www.infoq.com/news/2016/06/systems-programming-qcon). He's been working on [Systems programming in C# since at least 2013](http://joeduffyblog.com/2013/12/27/csharp-for-systems-programming/). The Roslyn compiler can compile into native code (that's how UWP works) and garbage collection isn't an issue if you pay attention to what you're doing. – RubberDuck Sep 25 '16 at 23:26
14
Well, the first thing to do is to go to your boss and fess up. You've disregarded his clear request, and worse have been doing so for months. I don't know how much time you've got into this, but assuming that it's most of the time allocated for getting the project done, you have to face up to the fact that you may soon be looking for a new job.
The sooner you deal with this the better.
Secondly, I don't think you can convince him that ANSI C is inadequate, what you need to do is convince him of several other things (1) that c# is adequate, (2) he can easily learn to maintain c#, (3) that you were inadquate to writing it in C. Assuming that you still have a job and a part to play with this project, I would concentrate on 2, emphasising the similarities between c and c#.
Quotes in response to comments...
A few months ago, we started developing an app [...] After a few days, I scrapped the entire thing and started anew using C#
jmoreno
  • 10,640
  • Nowhere did he mention he'd been building a C# version for months? – Anonymous Sep 07 '12 at 11:08
    @Anonymous - It does not matter if it was days or months he still DID NOT follow his managers instructions. The author clearly did not have the skills required to develop the application in ANSI C. – Ramhound Sep 07 '12 at 12:19
    @Ramhound - I'm not disputing that he didn't follow his managers instructions, I'm just saying jmoerno was making out as if he'd spent months going off on tangents. Besides, if he pieced the project together in a couple of days to serve as a working prototype upon which the more stable C version specified can be based upon then it makes perfect sense. It's part of the planning stage. – Anonymous Sep 07 '12 at 12:33
  • @jmoreno - Apologies, I must have misread the question. – Anonymous Sep 07 '12 at 14:56
    @jmoreno - Of course. I posted my last comment after seeing the quote you added. Apologies once again. – Anonymous Sep 07 '12 at 15:34
12
This is a pretty reasonable requirement.
This doesn't make sense. Now it is starting to smell a bit suspicious, because this is a program design requirement and not a language requirement. If the code should be easy to maintain, implementing ADTs or using well-tested, pre-existing ones should be a priority.
Ok, so now it stinks. Now we can tell that your boss has limited experience not just from various programming languages, but from programming in general. A skilled veteran programmer, no matter language preference, would never make such a statement. (The only exception that I can think of is if most of the code is intended to run on a fairly small embedded system, and therefore that all necessary working memory for the code was expected to be pre-allocated. The idea that the same code is expected to have a screen level UI argues against strongly that being the case, however).
I'm guessing that your boss has never been involved in large scale, mission critical software projects, but he has more likely been floating around in various low-quality ones.
So this has nothing to do with the programming language C. You can easily write equally icky programs in C# as well. It is a very common mistake to believe that good program design depends on the language. That is simply not true!
C# certainly has prettier, cleaner and less obscure syntax than C. It has plenty of program design support, since it has far more OO-related keywords than C. But apart from that, it does not tell you how to write your programs. If you believe that everything written in C is awful by default and everything written in C# is heaven by default, I bet you are currently writing rather awful C# programs without realizing it.
What I would suggest is that you make an abstract, language-independent, but detailed program design before anything else. Use the normal, object-oriented approach. What objects are there and how do they communicate between each other, what are the dependencies needed etc etc. When you have given the program design enough thought and gotten it down on paper, it shouldn't matter much to you nor to your boss which language you chose to implement it in.
The first issue you have to address is an emotional, irrational one. The IT industry is one in constant change and, although there are places for everything, refusing to improve or embrace change is a problem.
Why is your boss clinging to ANSI C? If that is the only language he or she knows then maybe it is time for a change but a rational argument may be insufficient. Will your boss feel undervalued or possibly fired if forced to work in an unfamiliar language? Emphasize the experience that he has and other benefits he brings.
If you do not solve this problem, all the rational arguments you can bring will be wasted. As a subordinate, you may not be the one that can have this discussion with him. Perhaps broach this subject to one of the other managers, if there are any.
Also consider it from your perspective. Why do you want to use C#? How much of this is the desire to use something new and cool? Be honest with yourself. If you recognise this, it will help you argue more effectively.
The second issue is one of risk and cost. Writing software is expensive and the choice of language is a major factor in that. Consider:
  1. How long will it take to write in C# versus C? With easier object orientation and better garbage collection, C# may be easier. However, if the application uses lots of unmanaged API calls, C may be easier.
  2. If you use C#, do you need to purchase additional tools? It sounds like you already use Visual Studio but do you need additional tools for localization, code review and analysis, debugging and so on?
  3. How easy is it to maintain? If you find a bug, how quickly can it be fixed. C# can reduce this object orientation. Automatic garbage collection also avoids most memory leak and pointer issues.
  4. How easy is it to support? If you have support staff, they may know how to read a crash dump but do they know how to use windbg with SOS? Do the target machines already have an appropriate version of the .Net framework installed?
  5. Consider staffing. How many people know C versus C#? If either or both of you left the organization, how easy would it be to replace you? Are C developers cheaper or more expensive than C# developers?
I could go on but the point is to stop arguing on the technical merits of the languages alone. Technical merits are things only you and your boss understand. If you start talking business impact, you pull in a much wider group of people and make a far more convincing argument.
Maybe C is a better choice. C# is no automatically better for all situations. Maybe you do this project using C but do a C# proof of concept for the next one. Remember you can lose the battle but still win the war, too.
akton
  • 6,912
    I disagree with the implicit assumption that C# is by default a better choice than ANSI C. For instance if you want to stay platform independent C# is most likely a bad choice. –  Sep 07 '12 at 11:18
  • @ThorbjørnRavnAndersen I agree. Please see last paragraph. I also mention cases like calling unmanaged code. I assume that platform independence would have excluded C# in the OP. Perhaps this is an incorrect assumption. – akton Sep 07 '12 at 11:20
    Platform independence was just one possible reason. Wording like "clinging to ANSI C" does - in my opinion - indicate a bias. –  Sep 07 '12 at 11:54
  • @akton - Since when can you not call unmanaged code from C#. Of course it requires a wrapper and that introduces additiona support problems but it is possible. Furthermore you can support C# on multi-platforms if you want. Mono is support on every major desktop platform ( OS X, Windows, and Linux ). Granted as the Microsoft Windows based .NET Framework advances the feature base of Mono won't match it exactly ( that is already the case with WPF ) and of course you won't be able to develop Metro applications that run on Linux. Of course its unlikely that would be done in this case. – Ramhound Sep 07 '12 at 12:12
  • @Ramhound I did not say you cannot call unmanaged code from C#, just that lots of it can be a pain. Similarly, you can do cross platform development in C# but C is almost universal, as Thorbjorn said. – akton Sep 07 '12 at 12:15
  • It seems that an answer focusing on the people aspects and business case rather than technical details has certainly polarized people. – akton Sep 07 '12 at 12:17
  • @Ramhound Regarding Mono you might find http://programmers.stackexchange.com/questions/20275/mono-is-frequently-used-to-say-yes-net-is-cross-platform-how-valid-is-that interesting. –  Sep 07 '12 at 12:18
Maybe another argument: It's probably very hard to find computer science students who have enough experience to write C code without making mistakes. ANSI C is not the first thing people learn today.
Now all computer science students will kill me.
JohnB
  • 179
  • ANSI C was actually one of the first things I learned at college. I started in 2004. So within the last 10 years it was still being taught. I spent many late nights connected via SSH to a Unix environment trying to compile my code. – Ramhound Sep 07 '12 at 12:14
    Funny, I didn't learn ANSI C until my final year at University. The first language taught was Pascal, so that I am protected... – tehnyit Sep 07 '12 at 14:25
  • Recent graduate here; we had exposure to both C and C++, however the C was in an embedded context and minimal. Both were in my final year - purely C# and Java before that. – Ross Sep 07 '12 at 14:41
    C simply being hard to program right is probably the best point against using C. – Paul Nathan Sep 07 '12 at 16:06
You have completely failed to convince us that ANSI C was inadequate. C is an excellent language that seems adapted for the kind of tasks you have described. With the short description of the task (except the language requirement), I would also recommend C (or maybe go).
I think the problem is that you were programming in C with your mind thinking in C#. I have a similar problem when I switch from Perl to C or java. You must learn to adapt to the language, and not learn to translate from your way of thinking toward the language of the day.
The problem is not your boss or the C language, the problem is to open your mind toward different ways of thinking. Changing programming language is something that will benefit you.
BOC
  • 181
    Thank you for answering your first question on Stack Exchange Programmers. However, you may wish to make your future answers a little less personal by not using phrases like "you have completely failed", "the problem is to open your mind". Please review the FAQ http://programmers.stackexchange.com/faq#etiquette . I think you can make a good description of your point with neutral language. – DeveloperDon Oct 01 '12 at 22:01
First off, you need to tell your boss it's in a different language, now. He'll be (understandably) angry if you bring back something purposefully against the requirements with no notice.
Now, the best way to explain these things to boss/managers is to put it in terms of time and money. Estimate how much time such a project would take in ANSI C, and then estimate how much time it would take in something higher level such as C#. Note I said higher level, not modern. This may help to smooth things over as well. I mean, you wouldn't tackle painting a room with just a tiny paint brush, you'd use rollers and other things that make each stroke(line of code) cover more area of the project. Also, if you or one of your team members do not know C, or comfortable making a large project in C, this eats into the time issue even more because they'll be having to get up to speed.
It also sounds like your boss is trying to micromanage. I'm sure one of the other answers will try to explain how to get your boss to do that less
Earlz
  • 22,658
  • 60
  • Affordability seems a possible argument. While the boss (as a customer, per @MatthewFlynn's suggestion) argues that he cannot afford the program *not* being written in C, OP can argue that the the boss will also not be able to afford the implementation and maintenance costs associated with the program being written in C. Either way, compromises are needed to make things happen. – rwong Sep 07 '12 at 07:47
The supervisor aversion to ADTs was addressed elsewhere, as was the dev's seeming unawareness of GC costs, so I'll focus on "threads".
Perhaps rather than thinking in terms of .NET (or JVM, if so indoctrinated) threading, what you may want is multiple processes, using some inter-process communication (IPC) mechanism to communicate between them. E.g - windows messages, shared memory, memory mapped file buffer, named pipe, whatever. Dedicate small processes to interacting with a device or aspect of the device and checking the IPC to communicate updates and acknowledge requests, and have a somewhat larger process to maintain the GUI and communicate with the equipment "monitors" using whatever IPC you select.
Roboprog
  • 131
