Let's pretend you are copying a data structure from one file to another, and you use a buffer to store the data between the time you read it and the time you write it.
There is an overhead when you read and write data. On disk, the head has to find the sector and read or write the track. In memory, it takes a processor instruction to move a chunk of memory (usually 1-8 bytes at a time) plus a bus operation to move data from one part of memory to another, or between memory and the processor or memory and disk. Each chunk that you read is processed in a loop somewhere and the smaller the chunks, the more times the loop has to be executed.
If your buffer is a single byte, you will incur this overhead every time you read or write a byte of data. In our example, the disk can't read and write simultaneously, so the write may have to wait until the read is finished. For a one-byte file, this is the best you can do, but for a 1MB file, this will be extremely slow.
If you have a 10MB buffer and want to copy a 10MB file, you can read the whole thing into your buffer, then write it all out again in one step.
Now, if you want to copy a 20GB file, you probably don't have that much memory. Even if you do, if every program allocated 20GB of memory for buffers, there wouldn't be anything left! When you allocate memory, you have to release it, and both the allocation and release can take time.
If a client of some kind is waiting for whole chunks of data, sometimes smaller chunks are better. If the client gets a few chunks and knows they don't want the rest, they can abort, or maybe they can display what they have while waiting for more so that a human user can see that something is going on.
If you know the amount of data you are copying before you have to allocate your buffer, you can make a buffer that's the ideal size for the data you are copying. Either the exact size of all your data, or big enough for the data to be copied in a reasonable number of chunks. If you have to guess, some size around 1MB is reasonable for an unknown purpose.
To create the perfect sized buffer, you need to study the data that you are going to use it for. If you are copying files, how big are most of the files people copy? Then you guess at a good buffer size and time it. Tweak the size and time it again. Your total available memory may limit your maximum size. Eventually you arrive at the ideal buffer size for your specific goal.
