I am using the combination of spring, spring-security, struts and iBatis in my application. Now I am looking to migrate the struts UI to GWT.
The new combination must be spring, spring-security, GWT and iBatis.
I applied a layered approach to develop my application. In Controller/UI layer i am using Struts. I want to replace struts and use GWT in Controller/UI layer.
Is is possible to use GWT without affecting another layers DAO/BL/SL?
Satish Pandey
  • 1,340
    Why GWT as opposed to say Spring MVC? I assume because you don't want to have to deal with Javascript etc? – Martijn Verburg Aug 28 '12 at 08:55
  • Correct .. I want to handle AJAX and JavaScript related stuff in more frequent way. Also GWT provides rich client look and feel tools are very nice to work on. – Satish Pandey Aug 28 '12 at 09:07
  • Some other technologies that you may consider for the presentation layer would be JSF or Wicket, both can also integrate well into Spring. I warn though that there are always little quirks and oddities in any of these frameworks that will force you to write custom javascript from time to time. – maple_shaft Aug 30 '12 at 11:31
  • The previous answers give good advice. I'd just like to add that there is a Vaadin add-on ([JSP Integration](https://vaadin.com/directory#!addon/jsp-integration)) that might help during the migration process, depending on your actual migration strategy and whether your current Struts implementation uses JSP as a view technology. – Alejandro Duarte Apr 14 '16 at 15:47
  • I'm voting to close this question as off-topic because it's not about conceptual software design. – MetaFight Apr 24 '16 at 15:47
The short answer is: Yes, you can.
The problem is how to do it, as you will probably need a rewrite of your presentation layer and I don't think there is any tool that can help you easy up the migration.
adosaiguas
  • 380
  • Do i need to edit, spring application context and spring security settings also? – Satish Pandey Aug 28 '12 at 09:16
  • Well, I haven't seen your code, but I you'll probably have to adapt them too. It depends on how tied they are to the presentation layer and how you finally decide to do the migration. – adosaiguas Aug 28 '12 at 09:23
Well, yes, sure you can. Just make sure that the classes used in your frameworks are on the GWT white list. What that means in practice is:
  • Decide on the version of GWT you'll use in your project. If no constrains exist, use the latest.
  • Decide the versions of the other frameworks as well.
  • Decide which of the classes from those frameworks will be used in the CLIENT side code of your GWT project
Finally, if you arrive in a situation where certiain classes that come from your framework(s) will not be directly usable in GWT client code, there's multiple solutions:
  • check out if there's not already a "bridge" library/framework that deals with this issue (like Gilead for Hibernate)
  • if you have to do it by hand, explore the options (by maybe doing a small proof of concept): either implement a custom serialization policy, or make a DTO layer, etc.
Shivan Dragon
  • 4,583
