I'm doing a function point count for a large website. Does the main website menu count as an External Input?
I'm doing a function point count as described in this article.
If so, since you only click on one menu item at a time, I assume the number of DETs == 1?
willem
  • 1,053
    Hi Willem, don't worry about the downvotes, the community already took care of that ;) Can you edit your question to tell us which FPA method you are using? I _think_ menu items qualify as external input, they are elementary processes that control information outside the boundaries of the application (but I could be horribly wrong, last time I concerned myself with FPA was over a decade ago). You might be interested in the [Function Point Counting Practices Manual](http://perun.pmf.uns.ac.rs/old/repository/research/se/functionpoints.pdf) (warning: PDF) – yannis Aug 27 '12 at 16:29
  • Thanks Yannis. I clarified the question a little. I don't know of different types of function point counts, but hopefully that article will clarify. – willem Aug 28 '12 at 07:20
  • From the linked document, pg 65: "A data element type is a unique user recognizable, non-repeated field." My instinct, further supported by this suggests to me that a menu group would be one function point, and not each menu item. A set of radio buttons that all share and operate on the the same exclusivity would be one function point. And so on...but I have rather ancient experience doing this kind of analysis, so thats about all the further I can help with that. – JustinC Nov 02 '12 at 07:07
Yes a menu is an external input from the user that gives control information. I also agree that this is DETs == 1 since it gives you one low complexity data item: the destination of the navigation.
Ed Greaves
  • 123
