Dear fellow programmers,
We're developing software which simulates vehicular traffic. Part of the process called "assignment" is concerned with assigning vehicles to their routes and has to use some kind of shortest-path-finding algorithm.
Traditionally, people do this with Dijkstra's, and certain scientific literature seems to indicate that A* and other alternatives don't give any significant improvement, perhaps due to the nature of the graph.
Hence, we're using Dijkstra's as well. A small problem arose in that, if you treat traffic links (spans of roads between intersections) as edges and intersections as nodes, you can't get a classic uni-directional graph: when approaching an intersection, where you can turn frequently depends on where you're coming from, whereas in a traditional graph you can take any edge from a node.
We resolved this problem quite easily by representing a link-intersection pair (call it "lath") as a node. Since you'd need to traverse a link to get to any subsequent "lath", or point of choice, an edge would then be defined as this traversal, and you get a typical graph.
The results then are stored in a simple table, N x N, where N is the number of "laths."
Here's the (unavoidable?) drawback. If a typical network for our simulation can have, say, 2000 intersections, it will have somewhere around 6000 links, i.e. N = 3V. Obviously, if counted in terms of intersections (V), we're now up to O(log(3V)*(3V + E)).
You might argue that 3 (or 9) is a constant factor, but from the practical standpoint, it does slow things down quite a bit, and increases storage space to 3V x 3V.
Does anyone have any idea how we can restructure this to improve performance? Not necessarily any alternative algorithm, perhaps reshape the data structures to fit a graph in some other way?
Greg Kramida
  • 282
  • I'm not clear what N and V are. Is V the number of vertices (intersections) and N the number of arcs between vertices? Also, what is E? – Mike Dunlavey Aug 22 '12 at 21:09
  • What resources did you read? IIRC, A* is proven to find the optimal path in the least amount of time given a pessimistic heuristic. In fact, A* regresses into Dijkstra with an empty/0 heuristic. – Steven Evers Aug 22 '12 at 21:39
  • Also, what graph representation are you using? Unidirectional graphs with adjacency lists would easily permit roads as edges/intersections as nodes (actually, even an adjacency matrix would, but it'd obviously have to be a full matrix instead of upper/lower triangular). TBH: I'd suggest a lot of game programming literature, it's a highly worked problem in that field and has the same ore more stringent performance restraints as you're mentioning. – Steven Evers Aug 22 '12 at 21:48
    @SnOrfus: yes, but you can't always represent a single intersection as a single node, for example of an intersection allows you to turn left or go straight but not turn right, the simple adjacency matrix would not be able to represent that (worse if you have a roundabout). – Lie Ryan Aug 23 '12 at 04:01
  • @LieRyan: Maybe I'm misunderstanding you but that's no different from an intersection where there is no right turn and should be represented in the same way. – Steven Evers Aug 23 '12 at 14:27
  • @SnOrfus: You can't represent them the same way, because nodes in directed graphs can go from any incoming edges to any outgoing edges. That's not always the case with road networks, therefore a single cross intersection might require up to 4 nodes and 12 edges to model correctly or if you want to keep one-node-one-intersection relationship, you would need a nonstandard type of nodes that can keep track of which turns are allowed (therefore you can't use an adjacency matrix to represent the graph or you'd need additional data structure). – Lie Ryan Aug 23 '12 at 16:40
  • @SnOrfus: in any case, I don't think adjacency matrix is the best data structure to represent road network. A road network is a very sparse graph. – Lie Ryan Aug 23 '12 at 16:44
  • @LieRyan: I agree that an adjacency matrix is not a wise choice because of the sparseness (way too many zero/null entries in the matrix) but I still contend that you could model the topography of the network just as easily. That's why my first thought was an adjacency list. Either way, it's a really interesting problem. I might have time to work it out in the next couple weeks and write an essay/article on it. – Steven Evers Aug 23 '12 at 17:34
  • Currently we're using adjacency lists. Matrix is just to store the results, and these don't turn out sparse at all (typically, you can get from any link to any other link in the network except for out-flowing links at the borders). Reconstruction of a path from a matrix is linear in terms of number of links/nodes traversed, and turns out extremely fast. – Greg Kramida Aug 23 '12 at 19:55
Dijkstra's finds the shortest path between a given node and all other nodes, so I expect it would be more expensive than A*. However, it looks like you're trying to pre-compute the cost & path from any node to any other? Then Dijkstra's is the way to go.
As for a simpler representation, a few things come to mind:
At many intersections, you can come & leave any way you want. It's only a a subset that you have restrictions like "no left turn." So you could use the "laths" only for intersections where you actually need them. That should greatly reduce the size right there.
You could do this automatically by looking for "equivalent laths" and combining them. Two laths are equivalent if all the links coming out are the same. E.g. if "Intersection X coming from the West" and "Intersection X coming from the South" both lead to the same set of other nodes, with the same cost, then just merge them into a single node.
Are you sure you need/want to precompute the best path, instead of computing it online? Video games typically compute these things online.
Also, how are you representing the paths? In your matrix, you only need to represent the first link in the path. For example, to get from Bob's house to Bob's work, you only need to know the first link, since when they get there, you can now look in your matrix for how to get from the first link to Bob's work, which will give you the second link, etc.
Martin C. Martin
  • 1,223
  • Combining "laths" is indeed an interesting idea. You're right, we're finding shortest path between every node pair and then generating paths. In a typical traffic simulation, hardly any roads never get used (why would there even be a road there in the first place, right?). When you say "online," do you mean in real time? All we really can do is compute "expected" shortest paths, since we don't really know exactly what the conditions are going to be on some link when the vehicle actually gets there. We update the shortest path matrix based on current conditions. – Greg Kramida Aug 23 '12 at 14:23
  • Yes, by "online," I mean in real time, i.e. when Bob leaves his house and wants to go to work, do the A* then. – Martin C. Martin Aug 23 '12 at 14:45
  • Depending on how often the shortest path matrix needs to be updated, you may do a lot of work for the update, and not end up using most cells before doing the update again. I don't know the details of your use case, but from the outside, it seems A* is at least worth trying. Also, while all N nodes are used at some point, that doesn't mean that all N^2 pairs will be used at some point. The people on Bob's block, how many unique destinations do they have? – Martin C. Martin Aug 23 '12 at 14:51
  • Yeah, I concur, A* is probably worth trying. For some simulations, we're routing some fraction of vehicles at each origin to almost all destinations, but by far not in every case. I found a few papers on people using various heuristics w/ A* specifically for traffic networks, I'm going to try these out. Thanks for your help, Martin. – Greg Kramida Aug 23 '12 at 15:38
You have large graph and you made it even larger. Martinc C. Martin advised using lathes only when needed, so i will not go into this.
One of things that could help you, is tranform your graph into smaller graphs.
First simplification that helped me a lot (I worked with road networks of europian states) was "removing" nodes with digree 1 and 2 recursively. This way you have no dead end roads, and T intersections (originally degree 3) becomes degree 2 and that is not interesting, if you are not pathing to that node or node in that removed cull de sac.
After that, you can try to divide your graph into parts that have large ammount of internal nodes and edges, but have minimal connection with other parts. To find them, I used minimal cut where sink and source were as far from each other (in edges) from each other and edges near them had huge capacity and edges somewhere in between had small.
user470365
  • 1,229
