Possible Duplicate:
What is a normal “functional lines of code” to “test lines of code” ratio?
I've found that more often than not, when you write lots of unit tests, and have good coverage (80% or so), the test suite ends up being larger than the code itself.
Do my observations match that of everyone else?
I've also found that more often than not, a the larger the test suite, the harder it is to maintain the test suite. What ends up happening is that the test suite rots away as for every X lines you change you make to the code, X^2 lines need to change in the test suite.
Is this an attribute of unit test suites in general? Or am I just working on crappy unit test suites?
nbv4
  • 1,552
  • How many lines of code does it take to write a test? – JeffO Aug 22 '12 at 03:43
    It's also typical for it to have more bugs than the actual code – Coder Aug 22 '12 at 03:58
  • In general, yes, it seems like people have more test code than "actual code". There are plenty of [examples](http://stackoverflow.com/questions/2633860/typical-size-of-unit-tests-compared-to-test-code) out there, and TDD literature frequentyly mentions factors or 2x or more. As with any code, you should still simplify and refactor it, where beneficial. – Daniel B Aug 22 '12 at 06:14
  • In the project I was working on previously, we had, at all times, around 10-15% more lines of test code than the actual code it was testing. With those figures we had a code coverage of 65%, and 95% in critical areas. – Niklas H Aug 22 '12 at 10:00
Bigger tests than code?
It depends.
Sometimes the test will be more complex.
Sometimes the code will be more complex.
Refactoring to Simplify Code and Test Cases
It may be worth considering some simplifications and refactoring if things are getting exponential on you.
I have worked with several maintenance projects that were littered with God classes. These tended to be much more manageable when refactored into smaller classes.
Some classes are not minimal and a search for repeated code, and refactoring to eliminate repetition has the potential to reduce your test surface significantly.
Black Box vs. Glass Box Testing
One issue that arises is that of TDD methodology. When the user story changes, that produces more tests. On initial execution, they fail, and more code is written to make them pass. When they pass, the user story is implemented and we ship. Naturally, in real life, things might not be this pure. However, I guess it might be worth asking how much does the user story elaborate the test cases? Are the test cases functional, black box testing based on exercising the valid and invalid inputs?
It sounds from your description that some of the test cases are aimed at statement coverage. I like statement coverage, but there are several additional kinds of coverage as well. There are methods to optimize coverage test cases that you should perhaps consider if you find that part of your high test case count is due to brute forcing things to get through to every line.
Code Coverage Types
The following link illustrates with some cool graphics several types of coverage. I don't endorse or have an opinion about their product, just their diagram.
http://www.atollic.com/index.php/trueanalyzer/types-of-code-coverage-analysis
In their example, they show modified condition/decision coverage and determine that for the code they show, four test cases both execute every statement, and cause the branching into the if statement for every kind of condition that might occur. Discovery of test cases when the decision criteria are nested comparisons like
if (a < 5) // d1
   if (b < 10) //d2
      a = 7;
if ((a + b) < 8) //d3
   c = 5;
can be trickier to analyze for test case values, but you know you will need a test case with a < 5 and a >=5 from the very first if, and also b < 10 and b >= b from the second if.
Because in some paths a will be the input, and others a will be a modified value (a=7), you may need to use a technique called symbolic execution where the third if is analyzed in terms of a' and a''. To execute c = 5, you will need a test case where the condition is satisfied. You will also want to run a test where c is never assigned.
A list of test cases that I think covers everything is:
T1: a=4, b=9 => a'=4, a''=7, covers d1=true, d2=true, d3=false
T2: a=5, b=9, covers d1=false
T3: a=4, b=10, covers d2= true
But how do we get d3 covered? Assigning a in the second if statement makes the analysis more complicated unless we do this with it.
((a' + b) < 8), ((a'' + b) < 8)
((a' + b) < 8), ((7 + b) < 8)  // Remember a'' = 7
((a' + b) < 8), (b < 1)  // Remember a'' = 7
T4: a=1, b=0, covers d3=true
Symbolic execution is a test related technique that you can use to reduce the test cases needed to perform decision coverage. It is not an easy read, but a classic paper on the subject is:
http://www.cs.uiuc.edu/class/sp11/cs477/king76symbolicexecution.pdf
Apologies in advance if this diverts too far from your original question. I hope it will be of some use.
DeveloperDon
  • 4,958
  • 26
  • 53
This may indeed happen when you write lots of unit tests and do a lot of TDD. When you come to a point where the test suite hinders you in making changes to a specific function in your code, then your test suite most probably contains too many (similar-looking) calls to this same function of your code. That's almost always a sign for your test suite not beeing "DRY" any more. My suggestions to avoid that::
  • refactor your test suite regularly to make it more DRY. Bundle your function calls to the code if they are looking similar in a central function, bundle the test data creation if the test data is reused for more than one test, write supporting functions to allow the comparison of complex objects with the expected values in less lines of code, and so on.
  • write parameterized, data driven tests. Most modern unit test frameworks allow you to write a test function once and supply several sets of test data to it. If your framework does not have direct support for this technique, you can easily build it manually.
It may also be a good idea to study some "classic" test theory (see, for example, here) how to systematically design as few test cases as possible to achieve a high coverage.
Doc Brown
  • 199,015
  • 367
  • 565
I worked in a Java project in which we had more than 90% code coverage. The code of the unit tests was definitely more than the code of the project (I would reckon about 20 % more).
On the other hand we had very few bugs.
Giorgio
  • 19,486
  • 84
  • 135
  • If you mean that the test suite as a whole has more LoC than all your application's code, then no, I haven't experienced that. Maybe because I've worked on projects with lots of unit tests, not many integration tests, and zero automated UI tests. The UI can really be huge in terms of lines of code, so I guess you really have to have comprehensive UI tests in order for the size of the test code base to exceed the total size of the production code base.
  • If you mean your average test fixture has more LoC than the module it tests, it's possible, especially if your production code has a lot of short, public methods. However, it could also mean that you're testing too many things. Stuff like accessors and code constructs that contain no logic are generally considered not worth testing.
I guess there's not a lot you can do about that mathematical fact. You can't expect your test suite to come at no cost, and the cost will naturally increase with its size. There are things you can do about overly fragile tests though. See http://xunitpatterns.com/Fragile%20Test.html.
guillaume31
  • 8,358
Having more code in the test for a given function is a sign that the function/method doesn't stick to the single responsibility principle.
This means that in time the code becomes more convoluted and the tests need to grow in size exponentially to accommodate all the code paths and possible parameter combinations.
Most anti-patterns out there violate the single responsibility principle so it's the first thing that goes out the window in a typical project. This leads to the situation that you mentioned.
A solution to this is to write concise tests for a given routine before writing the routine. If the tests are too complicated it means it's time for refactoring.
linkerro
  • 687
  • IMHO, your argument is flawed. See, for example, this BLOG entry about refactoring a function down to SRP: http://blog.objectmentor.com/articles/2009/09/11/one-thing-extract-till-you-drop: the needed unit tests for testing the only public method `replace`of that class dont' change because the function is refactored. SRP means "do one thing" on a certain level of abstraction - it does not exclude delegation to lots of other private functions, which typically don't get unit tested on their own. – Doc Brown Aug 22 '12 at 10:33
  • Link is broken. And you are right, there are areas where this logic doesn't apply, like API methods. Still, I think of it as a basic rule of thumb, if you see hairy tests it's clean-up time. – linkerro Aug 22 '12 at 13:57
  • http://blog.objectmentor.com/articles/2009/09/11/one-thing-extract-till-you-drop – Doc Brown Aug 22 '12 at 21:31
  • indeed, when a function does too many things, you will need more unit test code for it. But you cannot solve this by *refactoring* the function (which means: no semantics changes) - you can only solve this by *redesign* the function (which means: you have to change semantics), for example, by providing two different functions, reduce number of parameters etc. – Doc Brown Aug 23 '12 at 05:57
