58
We have big enterprise projects they normally involve copying data from a source database to a destination database and then setting up a number of additional applications that sync this data etc.
The last project contained 250,000 items (rows of data). The next project will only contain 4,000 items. Project managers / business people believe the project should be 1/10 the time to complete because its only a fraction of the size of the last project.
What is a good analogy I can use to explain that writing code to transfer data from one system to another takes the same amount regardless of the number items - writing it for 1 item or for 100,000,000 will take roughly the same amount of time from a programming point of view.
phtimsp1970
  • 103
Daveo
  • 900
    It doesn't seem to be precisely the same situation - but when I encounter managers who think they can speed up a project by throwing more bodies at it I say *"9 women can't make a baby in a month"* – MattDavey Aug 21 '12 at 13:58
    Be careful how you explain this. It clearly doesn't take as long for 1 item as 100,000,000 items. For 1 item, you'd just convert by hand with no programming at all. – MarkJ Aug 22 '12 at 21:03
  • If you actually need to explain it you're already doomed – Balog Pal Jun 06 '13 at 03:56
10 Answers10
113
Tell them it's like building a new four lane highway to a remote part of the country. Whether that road gets used by 100 cars a day or 1000 cars a day, the effort to create the road will be about the same.
Granted, if it's going to support 1,000,000 cars a day you'll have to make the road a little more robust, but regardless, you're going to have to cut down the same trees, blast through the same mountains, level the same amount of dirt, and these activities are pretty much a fixed cost no matter how many cars use the road.
Bryan Oakley
  • 25,192
  • 64
  • 89
    +1 good analogy, I was struggling to find a physical one that worked ;) – jk. Aug 21 '12 at 11:37
    +1 I was thinking of a plumber running pipe from one location to another. – Joshua Drake Aug 21 '12 at 14:21
    Car analogies will never let you down :-) – Daniel Serodio Aug 21 '12 at 22:39
    "Fixed cost" is a great keyword that business people like and understand :) – Tamás Szelei Aug 22 '12 at 15:09
    Trouble is, the analogy doesn't work. Road builders only build a 4-lane highway if they expect a lot of traffic (25,000 vehicles a day would be typical. A million cars a day? Wow). If they expect 50 times fewer, they'd build a much cheaper road. Your managers might say "then why are you building a 4 lane highway on this problem? This is a single-lane problem or a dirt track problem" – MarkJ Aug 22 '12 at 20:47
    As @MarkJ said, this analogy doesnt quite work. Because the purpose of the project isnt "building a road", it's "getting 1000 car to the other end" (or 1000000). I believe I [gave another car analogy that works a bit better](http://programmers.stackexchange.com/a/161969/6007). – AviD Aug 23 '12 at 09:42
  • @MarkJ: actually I'd say it **is** working for exactly that reason. Depending on the load of the final system, you'll need to be more or less stringent about some requirements. If I only ever need to handle a single object at once, then I won't implement a great batch system that automagically handles retries. – Joachim Sauer Aug 23 '12 at 09:59
  • @AviD - the point is that there's some minimum width road you need to build and that means you have to do a certain minimum amount of work clearing land, etc. A 4 lane highway isn't a good example, but saying "road" would be good enough. – Scott Whitlock Aug 23 '12 at 12:03
  • @ScottWhitlock no, because there are inherently two parts: building + traffic. The requirements may change the building slightly, but the linearly-affected traffic part is the much smaller of the two. – AviD Aug 23 '12 at 12:07
    Maybe switching the analogy to train tracks would work better? It takes the same amount of effort to lay down train tracks regardless of how many trains travel over it or how much cargo they're carrying. – Allon Guralnek Aug 23 '12 at 18:35
103
Give them a calculator and ask them to add 1238783423 to 9858238483, time how long it takes. then ask them to add 3423 to 8483 and tell them you expect the answer approximately 100000 time quicker.
You might also explain the amount of data (probably) effects the length of time the software will take to run not the development time.
jk.
  • 10,216
  • 43
    I logged in just to +1 your calculator analogy. Managers can be hilarious sometimes. – Alex Aug 21 '12 at 15:43
    I laughed at this one, but up-voted Eric's. I don't think this one is what they call "managing up". – David W Aug 22 '12 at 00:16
    Not sure. I think it's more like "how much does it cost for a calculator that can add two numbers 4000 times in a row" vs. "host much does it cost for a calculator that can add two numbers 250,000 times in a row". – Scott Whitlock Aug 22 '12 at 14:22
  • wow, that is brilliant – Balog Pal Jun 06 '13 at 04:02
35
Put it into manager speak.
If you build a machine to make widgets at 1 widgets per second, it does not matter if you use it to make 100 widgets or 10000 widgets, the machine itself takes the same time to build.
the difference is at run time, not build time.
All management classes work on problem like this with hypothetical widget factories.
Don't use an analogy. Just explain it.
  • For a very small number of items (10?) it's cheapest to manually convert. Don't write a program at all.
  • For a small number of items (100?) it will be worth writing a program. You may be able to make savings by ignoring some permutations of the data that are theoretically possible, but don't appear in practise in the small dataset. Or appear in such small numbers that the program can reject them, and they can be converted manually. It's feasible to run quick analyses on the data to check whether corner cases actually appear in the data. If they don't appear, they can be ignored.
  • Once you pass this point, the actual size of the data has no impact. You need to write a serious program that can handle any possible input. The program can handle 1,000 items or 100,000. It just takes longer to run.
Education is better than talking down :)
MarkJ
  • 2,827
Not really an analogy, but I still believe a good way to deal with this argument: demonstrate there is a fatal flaw in it.
Your previous project included (from what I get) copying data with some modifications on it.
If I got it right, that's something a team of, say, 100 accountants can do in a matter of a few months. Then why did they throw software developers at the problem?
Because the software you created doesn't care whether it will process 10 or 10 million pieces of data (not exactly, but I doubt your managers care for O(n) complexity). Thus, it was probably cheaper, faster and cleaner (less error-prone process).
If you're more radical, you might even suggest that if they don't like how fast the software team works, they can always call in the accountants to do the work by hand.
This made your managers' lives much easier while you were developing the last project, and now, when they have to apply the same logic to figure out the next piece of software doesn't care either if it's going to work on 10 million or 4 000 rows, they suddenly forget about it.
I think in your case the managers are simply playing an estimation game and are trying to force the team to work faster, by pointing out the difference between 4000 and 250000 and hoping for some 'guilt'. I could be wrong, but I've seen this done before.
It's a terrible way to manage a team of programmers (actually any type of creative team) and it doesn't help anyone.
K.Steff
  • 4,475
I know you asked for an analogy, but I think that's the wrong technique.
I believe, as others have mentioned in passing, that you need to emphasize that data size affects run time, not build time.
So, break it down for them - you actually have two sub-projects, building and running. The building project should (for the most part) be irrelevant of how much data it will run on, it only matters the types of data.
As for the runtime - sure, they can factor that according to data size (excluding any non-trivial fixed overhead).
It's like if you have to drive to Melbourne - but first you have to build the car.
Sure, driving to Sydney might be faster - but building the vehicle takes the same amount of time.
Okay, I gave you an analogy after all.
AviD
  • 490
Maybe a telephone? Your customer wants a custom-made phone. If he makes 0 calls per day or 100 calls per day it would take the same amount of time to create his phone.
The data a phone transmits is analogous to the data copied by your program.
Your managers seem to confuse dev-time with the actual run-time of the program. But their misunderstanding may be different. They may assume that there are fewer "fields" involved. Not just fewer data records. If there are 100000 individual data fields it would be a massive dev effort compared to only 10 fields. More mapping work from system to system. In this case they may actually be correct, but there is still some constant overhead involved and you can't simply divide by the number of fields to get the time.
mike30
  • 2,788
As i like to describe it data has 2 dimensions length and width. Length is the number of records, width is the total number of columns across all tables
Now when you want to import data it is like getting a block through a hole. You need to make a hole big enough for the smallest dimension, and then carry the block through
now with 10 million and 10 thousand the smallest dimension is still the width. So it is the width that decides how long it takes to make the hole.
TO complete the metaphor, ff it is the length that is smaller you would just type the data in manually
Andrey
  • 285
I import hundreds of client files every week.
One thing I have found is that the small files generally take longer to develop the data import for because:
  • They are less likely to follow the rules (we have standard file structures, I have never seen a small client give us the data in the standard format that we ask for but large ones understand why that is important)
  • They tend to have more data integrity issues especially if they are coming from an Excel file rather than a database (where the large files tend to come from) which already had data integrity rules built in
  • They are less likely to be provided in the same format every time.
We have found that we save a lot of time in development by building a parent child SSIS package that has a standard child process and any necessary manipulation to get the data in the form of the standard can be done in the parent. That way, it becomes less an issue of how many records when we do an estimate but an issue of how close to the stanrdard is the file we are getting. We now don't get as many complaints when smaller things take longer to develop because they don't fit the standard.
HLGEM
  • 28,709
  • 67
  • 116
-1
Writing a program is kind of like hiring a new employee. You have to teach them where to find the data, what to do with it, and how to give you the results. You have to keep an eye on them for a little while to make sure they're doing it right. It might take a little longer to train them if they have a complicated/important job or if they're going to do a very large amount of work, but it takes a substantial amount of time no matter what.
Many managers are familiar with the overhead involved in training a new employee, so this might make sense to them.
(the analogy breaks down insofar as your new employee is a superpowered robot who can get the job done in a trivial amount of time no matter how many records you throw at them, but hopefully you've made your point by then.)
octern
  • 99
