In general, yes, using public fields instead of properties is a bad practice.
The .NET framework by and large assumes that you will use properties instead of public fields. For example, databinding looks up properties by name:
tbLastName.DataBindings.Add("Text", person, "LastName"); // textbox binding
Here are some things you can easily do with properties but not with fields:
You can add validation (or any other code, within reason) to values in a property:
private string lastName;
public string LastName
get { return lastName; }
set
if(string.IsNullOrEmpty(value))
throw new ArgumentException("LastName cannot be null or empty");
lastName = value;
You can easily change accessibility levels for getters and setters:
public string LastName { get; private set; }
You can use them as part of an interface definition or an abstract class.
If you start out with public fields and assume it'll be easy to change to properties later, you will likely run into trouble. If you have any code in other assemblies that depends on accessing your public fields, you will have to rebuild and redeploy all of them if you switch to property-based access. You might also have code that uses reflection to get at the values... that'd also need to be changed.
And if you're really unlucky, those changes would have to be made in a part of the codebase you have no control over and you'll be stuck hacking around public fields.
For more gory details, check out item 1 in the first chapter of Effective C# by Bill Wagner.
