Will this be going over the wire (serialized/deserialized) any time now or in the future? Favor the single ID type over the who-knows-how-large full object.
If you're looking for type-safety of the ID to its entity, then there are code solutions as well. Let me know if you need an example.
Edit: expanding on type-safety of ID:
So, let's take your method:
public Foo GetItem(int id) {}
We only hope that the integer id
that's passed in is for a Foo
object. Someone could misuse it and pass in some Bar
object's integer ID or even just by hand type in 812341
. It's not type safe to Foo
. Secondly, even if you used the pass an object Foo
version, I'm sure Foo
has an ID field which is int
which someone can possibly modify. And lastly, you cannot use method overloading if these exist in a class together as only the return type varies. Let's rewrite this method a bit to look type-safe in C#:
public Foo GetItem(IntId<Foo> id) {}
So I've introduced a class named IntId
which has a generic piece to it. In this particular case, I want an int
that's associated with Foo
only. I can't just pass in a naked int
nor can I assign an IntId<Bar>
to it accidentally. So below is how I've written these type-safe identifiers. Do take note that the manipulation of the actual underlying int
is only at your data access layer. Anything above that only sees the strong type and has no (direct) access to its internal int
ID. It should have no reason to.
IModelId.cs interface:
namespace GenericIdentifiers
using System.Runtime.Serialization;
using System.ServiceModel;
/// <summary>
/// Defines an interface for an object's unique key in order to abstract out the underlying key
/// generation/maintenance mechanism.
/// </summary>
/// <typeparam name="T">The type the key is representing.</typeparam>
[ServiceContract]
public interface IModelId<T> where T : class
/// <summary>
/// Gets a string representation of the domain the model originated from.
/// </summary>
/// <value>The origin.</value>
[DataMember]
string Origin
[OperationContract]get;
/// <summary>
/// The model instance identifier for the model object that this <see cref="IModelId{T}"/> refers to.
/// Typically, this is a database key, file name, or some other unique identifier.
/// <typeparam name="TKeyDataType">The expected data type of the identifier.</typeparam>
/// </summary>
/// <returns>The unique key as the data type specified.</returns>
[OperationContract]
TKeyDataType GetKey<TKeyDataType>();
/// <summary>
/// Performs an equality check on the two model identifiers and returns <c>true</c> if they are equal; otherwise
/// <c>false</c> is returned. All implementations must also override the equal operator.
/// </summary>
/// <param name="obj">The identifier to compare against.</param>
/// <returns><c>true</c> if the identifiers are equal; otherwise <c>false</c> is returned.</returns>
[OperationContract]
bool Equals(IModelId<T> obj);
ModelIdBase.cs base class:
using System;
using System.Collections.Generic;
/// <summary>
/// Represents an object's unique key in order to abstract out the underlying key generation/maintenance mechanism.
/// </summary>
[DataContract(IsReference = true)]
[KnownType("GetKnownTypes")]
public abstract class ModelIdBase<T> : IModelId<T> where T : class
/// <summary>
/// </summary>
[DataMember]
public string Origin
get;
internal set;
/// <summary>
/// The model instance identifier for the model object that this <see cref="ModelIdBase{T}"/> refers to.
/// </summary>
public abstract TKeyDataType GetKey<TKeyDataType>();
/// <summary>
/// otherwise <c>false</c> is returned. All implementations must also override the equal operator.
/// </summary>
/// <returns>
/// <c>true</c> if the identifiers are equal; otherwise <c>false</c> is returned.
/// </returns>
public abstract bool Equals(IModelId<T> obj);
protected static IEnumerable<Type> GetKnownTypes()
return new[] { typeof(IntId<T>), typeof(GuidId<T>) };
IntId.cs:
// System namespaces
using System;
using System.Diagnostics;
using System.Globalization;
/// <summary>
/// Represents an abstraction of the database key for a Model Identifier.
/// </summary>
/// <typeparam name="T">The expected owner data type for this identifier.</typeparam>
[DebuggerDisplay("Origin={Origin}, Integer Identifier={Id}")]
public sealed class IntId<T> : ModelIdBase<T> where T : class
/// <summary>
/// Gets or sets the unique ID.
/// </summary>
/// <value>The unique ID.</value>
[DataMember]
internal int Id
get;
set;
/// <summary>
/// Implements the operator ==.
/// </summary>
/// <param name="intIdentifier1">The first Model Identifier to compare.</param>
/// <param name="intIdentifier2">The second Model Identifier to compare.</param>
/// <returns>
/// <c>true</c> if the instances are equal; otherwise <c>false</c> is returned.
/// </returns>
public static bool operator ==(IntId<T> intIdentifier1, IntId<T> intIdentifier2)
return object.Equals(intIdentifier1, intIdentifier2);
/// <summary>
/// Implements the operator !=.
/// </summary>
/// <returns>
/// </returns>
public static bool operator !=(IntId<T> intIdentifier1, IntId<T> intIdentifier2)
return !object.Equals(intIdentifier1, intIdentifier2);
/// <summary>
/// Performs an implicit conversion from <see cref="IntId{T}"/> to <see cref="System.Int32"/>.
/// </summary>
/// <param name="id">The identifier.</param>
/// <returns>The result of the conversion.</returns>
public static implicit operator int(IntId<T> id)
return id == null ? int.MinValue : id.GetKey<int>();
/// <summary>
/// Performs an implicit conversion from <see cref="System.Int32"/> to <see cref="IntId{T}"/>.
/// </summary>
public static implicit operator IntId<T>(int id)
return new IntId<T> { Id = id };
/// <summary>
/// Determines whether the specified <see cref="T:System.Object"/> is equal to the current
/// <see cref="T:System.Object"/>.
/// </summary>
/// <param name="obj">The <see cref="T:System.Object"/> to compare with the current
/// <see cref="T:System.Object"/>.</param>
/// <returns>true if the specified <see cref="T:System.Object"/> is equal to the current
/// <see cref="T:System.Object"/>; otherwise, false.</returns>
/// <exception cref="T:System.NullReferenceException">The <paramref name="obj"/> parameter is null.</exception>
public override bool Equals(object obj)
return this.Equals(obj as IModelId<T>);
/// <summary>
/// Serves as a hash function for a particular type.
/// </summary>
/// <returns>
/// A hash code for the current <see cref="T:System.Object"/>.
/// </returns>
public override int GetHashCode()
unchecked
var hash = 17;
hash = (23 * hash) + (this.Origin == null ? 0 : this.Origin.GetHashCode());
return (31 * hash) + this.GetKey<int>().GetHashCode();
/// <summary>
/// Returns a <see cref="System.String"/> that represents this instance.
/// </summary>
/// <returns>
/// A <see cref="System.String"/> that represents this instance.
/// </returns>
public override string ToString()
return this.Origin + ":" + this.GetKey<int>().ToString(CultureInfo.InvariantCulture);
/// <summary>
/// </summary>
/// <returns>
/// </returns>
public override bool Equals(IModelId<T> obj)
if (obj == null)
return false;
return (obj.Origin == this.Origin) && (obj.GetKey<int>() == this.GetKey<int>());
/// <summary>
/// </summary>
public override TKeyDataType GetKey<TKeyDataType>()
return (TKeyDataType)Convert.ChangeType(this.Id, typeof(TKeyDataType), CultureInfo.InvariantCulture);
/// <summary>
/// Generates an object from its string representation.
/// </summary>
/// <param name="value">The value of the model's type.</param>
/// <returns>A new instance of this class as it's interface containing the value from the string.</returns>
internal static ModelIdBase<T> FromString(string value)
if (value == null)
throw new ArgumentNullException("value");
int id;
var originAndId = value.Split(new[] { ":" }, StringSplitOptions.None);
if (originAndId.Length != 2)
throw new ArgumentOutOfRangeException("value", "value must be in the format of Origin:Identifier");
return int.TryParse(originAndId[1], NumberStyles.None, CultureInfo.InvariantCulture, out id)
? new IntId<T> { Id = id, Origin = originAndId[0] }
: null;
and, for completeness' sake of my codebase, I also wrote one for GUID entities, GuidId.cs:
using System;
/// <summary>
/// </summary>
[DebuggerDisplay("Origin={Origin}, GUID={Id}")]
public sealed class GuidId<T> : ModelIdBase<T> where T : class
/// <summary>
/// </summary>
[DataMember]
internal Guid Id
get;
set;
/// <summary>
/// </summary>
/// <param name="guidIdentifier1">The first Model Identifier to compare.</param>
/// <param name="guidIdentifier2">The second Model Identifier to compare.</param>
/// <returns>
/// </returns>
public static bool operator ==(GuidId<T> guidIdentifier1, GuidId<T> guidIdentifier2)
return object.Equals(guidIdentifier1, guidIdentifier2);
/// <summary>
/// </summary>
/// <returns>
/// </returns>
public static bool operator !=(GuidId<T> guidIdentifier1, GuidId<T> guidIdentifier2)
return !object.Equals(guidIdentifier1, guidIdentifier2);
/// <summary>
/// Performs an implicit conversion from <see cref="GuidId{T}"/> to <see cref="System.Guid"/>.
/// </summary>
public static implicit operator Guid(GuidId<T> id)
return id == null ? Guid.Empty : id.GetKey<Guid>();
/// <summary>
/// Performs an implicit conversion from <see cref="System.Guid"/> to <see cref="GuidId{T}"/>.
/// </summary>
public static implicit operator GuidId<T>(Guid id)
return new GuidId<T> { Id = id };
/// <summary>
/// </summary>
/// <summary>
/// </summary>
/// <returns>
/// </returns>
unchecked
var hash = 17;
return (31 * hash) + this.GetKey<Guid>().GetHashCode();
/// <summary>
/// </summary>
/// <returns>
/// </returns>
return this.Origin + ":" + this.GetKey<Guid>();
/// <summary>
/// </summary>
/// <returns>
/// </returns>
if (obj == null)
return false;
return (obj.Origin == this.Origin) && (obj.GetKey<Guid>() == this.GetKey<Guid>());
/// <summary>
/// </summary>
/// <summary>
/// </summary>
if (value == null)
Guid id;
return Guid.TryParse(originAndId[1], out id) ? new GuidId<T> { Id = id, Origin = originAndId[0] } : null;
