I have a need to make a somewhat custom change request system (very high auditing requirements).
Instead of completely reinventing the wheel I was wondering if there's an open-source change request system, considered decent that I could write a custom module for?
I've done some searching but the ones I have found don't seem to encapsulate what a change request system should be (no way of recording test plans or work streams).
In my experience a change request system has (does) store test plans / technical specs and a log of work.
gnat
  • 21,442
  • 112
  • 288
Michael A
  • 466
We use jira (10 users for 10 bucks) and it is great. We track almost everything in it. Bugs/ Tasks/ Feature requests.
Okay... it's not open source but these guys build like crazy and it just works out of the box.
We tried a lot of open source apps... but non really worked like we would like it to work.
Just give it a try... it's just 10 bucks :-)
http://www.atlassian.com/company/customers/?tab=jira
Would a change request system differ greatly from an issue tracking system?
For a general web based feature tracking/issue tracking system I find mantis to be good.
The code is procedural, the UI is ugly, but it works and it's easy to modify.
http://www.mantisbt.org/
  • In my experience a change request system has (does) store test plans / technical specs and a log of work. This would be related to features only. Maybe this terminology is just associated with my work and isn't an industry standard though? – Michael A Aug 04 '12 at 06:05
  • I just laughed at this "I find mantis to be good" ... "The code is procedural and the UI is ugly" ;) +1 for a good suggestion though! – Fergus In London Dec 22 '12 at 22:27
Is it something related to Bug Tracking System?
If you are looking for something like that with some extensions, i would advice to look at the followings - Top 10 Open Source Bug Tracking System.
There is also an alternative Change Request Management tool from SourceForge.net that you may extend as required - Change Request Management
Yusubov
  • 21,328
  • 45
  • 71
  • The Change Request Management tool that you mention has no files associated with it. It would require an awful lot of "extending." – chb Dec 01 '13 at 02:07
