Possible Duplicate:
When are Getters and Setters Justified
Why do we use get and set method in C#? And why do we use public and private method property?
For example:
public class Date
    private int month = 7;
    public int Month
        get
            return month;
        set
            if ((value > 0) && (value < 13))
                month = value;
imonbayazid
    This question is covered in depth here: http://csharpindepth.com/articles/chapter8/propertiesmatter.aspx – Robert Harvey Jul 29 '12 at 07:07
    See http://programmers.stackexchange.com/questions/21802/when-are-getters-and-setters-justified, http://programmers.stackexchange.com/questions/120828/are-get-set-methods-a-violation-of-encapsulation, http://programmers.stackexchange.com/questions/38423/is-it-a-good-programming-practice-to-not-use-getters-and-setters-in-trivial-part and http://programmers.stackexchange.com/questions/144347/when-or-why-should-one-use-getters-setters-for-class-properties-instead-of-simpl among many others – ChrisF Jul 29 '12 at 12:16
  • Those are *two* questions, not one. – tdammers Jul 29 '12 at 15:00
Private set modifier is used to control the access to object's property value.
Public set modifier is directly accessing the object's property value.
When you have a closed Domain, as a rule of open/close principle, private set modifiers used to restrict direct access to modify the properties of the object.
Private setters were not available before .NET 2.0 Framework. This has meant that people have written separate SetXXX methods if they wanted a public getter but a more limited setter.
public class MyTest
    string someProperty;
    public string SomeProperty
        get
            return someProperty;
        private set
            someProperty = value;
The basic rules are that you can't specify an access modifier for both the getter and the setter, and you have to use the "extra" modifier to make access more restrictive than the rest of the property.
Your question example comes from MSDN article Using Properties (C# Programming Guide). Look at that again and it will clear up the things.
Yusubov
  • 21,328
  • 45
  • 71
