No, you actually should. I would even go as far as to say - everyone should.
Parallel programming is actually a huge problem for the whole industry, it's a topic universities, tutorials, project managers and architects usually shy away from. This is bad, very bad, and should be fixed ASAP.
Parallel programming is not actually that hard, but it needs a different mindset that most people are not comfortable with. Decent multi-threaded apps can be written with just knowing and abiding by the rule that all function calls should be reentrant and shared objects protected. This solves most of the problems.
But getting used to that is problematic. Documentation is not always threading aware, or does not explicitly talk about threads. Bread and butter safety nets like unit-tests fail miserably in parallel programming. Thread joining and abnormal termination/cancellation is a huge issue. And deadlocks are one scary thing as soon as people start getting overly creative.
This extra complexity is enough that most people just forget about extra threads, heck, even I used to, and even now I sometimes "forget" about threads. This is also a perfect way for cloud providers to forget about multi-cores, and run more VMs on the base hardware.
But this is wrong, computing power growth is in threads now, we as programmers have to get used to the new world, and we should try to use the threads whenever possible.
