In the end, I created a custom builder which called an external test runner. Just save the following to site_scons/site_tools/run_py_test.py
, import it in the main SConstruct file, and use it as you would any other builder.
import sys
import os
import subprocess
try:
from fabulous.color import red, green, fg256
utest_fail = lambda x: sys.stderr.write(red(x).as_utf8+'\n')
utest_pass = lambda x: sys.stdout.write(green(x).as_utf8+'\n')
utest_directory = lambda x: sys.stdout.write(fg256(63, x).as_utf8+'\n')
except ImportError:
sys.stdout.write('Fabulous module not found: '
'To install it, run sudo pip-python install fabulous\n')
utest_fail = lambda x: sys.stderr.write(x)
utest_pass = lambda x: sys.stdout.write(x)
utest_directory = lambda x: sys.stdout.write(x+'\n')
def which (program):
"""Reimplementation of the shell command 'which'.
@see: http://stackoverflow.com/a/377028/232794
@type program: String
@param program: The program name.
@return The full path to the program or None.
is_exe = lambda x: os.path.isfile(x) and os.access(x, os.X_OK)
fpath, fname = os.path.split(program)
if fpath:
if is_exe(program):
return program
else:
for path in os.environ["PATH"].split(os.pathsep):
exe_file = os.path.join(path, program)
if is_exe(exe_file):
return exe_file
return None
def runTests (target = None, source = None, env = None):
"""Run a test aggregation tool (by default py.test) in directories
provided in TEST_DIR_LIST.
@type target: String
@param target: A target.
@type source: String
@param source: A source.
@type env: SCONS ENV.
@param env: This should contain TEST_RUNNER or TEST_DIR_LIST otherwise
defaults values are used.
if not 'TEST_RUNNER' in env:
env.Append(TEST_RUNNER='py.test')
if not 'TEST_DIR_LIST' in env:
sys.stderr.write("+++ TEST_DIR_LIST is not set, using project root.\n")
env.Replace(TEST_DIR_LIST=['./'])
cmd = which(env['TEST_RUNNER'])
if cmd:
retCode = 0
for path in env['TEST_DIR_LIST']:
utest_directory('\n+++ Running unit tests in directory %s:' % (path))
retCode += subprocess.call([cmd], cwd=path)
line = "="*80 + "\n"
if retCode:
try:
utest_fail(line + u" ✘ Unit tests failed!\n" + line)
except UnicodeEncodeError:
utest_fail(line + " - Unit tests failed!\n" + line)
else:
try:
utest_pass(line + u" ✓ Unit tests passed.\n" + line)
utest_pass(line + " + Unit tests passed.\n" + line)
env.Exit(retCode)
else:
sys.stderr.write("*** Could not find %s command\n" % (
env['TEST_RUNNER']))
env.Exit(-1)
If you are going to down vote, at least leave a comment as to why this is a bad answer so it can be improved!!!
