36
I'd like to find a way to write an API that can be accessed from any other programming language via language bindings (or some other framework). Is it possible to do this? If so, which programming language would be the most suitable for writing a "cross-language" API? My goal is to create a single set of functions that I can access from any programming language that I'm working with, so that I won't need to manually re-write the entire API in each language.
Anderson Green
  • 563
    If you just want to be able to say "we support EVERYTHING" for marketing reasons, you can just write a low-level DLL or shared library in C. If you want anybody in say, Java, to use your thingy, you'd better provide a Java interface. – mjfgates Jul 20 '12 at 07:59
    You say "(almost) any", which languages would you exclude for this purpose? Or which are the most important to you? – funkybro Jul 20 '12 at 08:12
    Webservice? You can write some functions in for instance php. Almost any language has the posibility to interface with webpages, supply arguments and read the results. – Pieter B Jul 20 '12 at 08:28
    +1 'cause it's an interesting question - but your question would be improved by saying why you want to do this. What are your goals? – TarkaDaal Jul 20 '12 at 08:28
  • @PieterB => answer. – Konrad Rudolph Jul 20 '12 at 13:05
  • I am not trying to exclude any specific language, but I wasn't sure if it was possible to write an API in one programming language that could be accessed from any other language. I want to write a cross-language API that is accessible to as many languages as possible, because I want to avoid the hassle of re-writing the entire API whenever I switch from one language to another. – Anderson Green Jul 20 '12 at 15:42
  • I recently found a programming language called Haxe- it can be compiled to many different programming language, and appears to be extremely well suited to this purpose. – Anderson Green Nov 23 '12 at 06:56
  • Did you get a chance to look at https://haxe.org/ ? – Deepan Prabhu Babu Jan 11 '21 at 10:58
8 Answers8
45
You have a few options:
  1. Create an HTTP interface, almost everything can talk HTTP so that will get you a lot of languages.
  2. Create something that can be linked into a language runtime, this will be rather time consuming as you will need to find a way to connect it to many different languages.
svick
  • 9,999
  • 51
Zachary K
  • 10,433
  • 55
30
I think C or C++ would be most suitable for your purpose. You can use SWIG (Simplified Wrapper and Interface Generator) to generate language bindings from your C or C++ API.
SWIG is a software development tool that connects programs written in C and C++ with a variety of high-level programming languages. SWIG is used with different types of target languages including common scripting languages such as Perl, PHP, Python, Tcl and Ruby. The list of supported languages also includes non-scripting languages such as C#, Common Lisp (CLISP, Allegro CL, CFFI, UFFI), D, Go language, Java including Android, Lua, Modula-3, OCAML, Octave and R. Also several interpreted and compiled Scheme implementations (Guile, MzScheme/Racket, Chicken) are supported. SWIG is most commonly used to create high-level interpreted or compiled programming environments, user interfaces, and as a tool for testing and prototyping C/C++ software. SWIG is typically used to parse C/C++ interfaces and generate the 'glue code' required for the above target languages to call into the C/C++ code. SWIG can also export its parse tree in the form of XML and Lisp s-expressions. SWIG is free software and the code that SWIG generates is compatible with both commercial and non-commercial projects...
gnat
  • 21,442
  • 112
  • 288
LMC
  • 552
    SWIG is a great tool. – setzamora Jul 20 '12 at 04:47
  • 32
    C++ would be an awful choice. There are numerous problems with it: dependency on a runtime library, unspecified ABI (especially mangling), etc. Generating bindings from C++ headers is prohibitively tricky. SWIG is quite a limited thing. See all the overcomplicated infrastructure around, say, Python Qt bindings. – SK-logic Jul 20 '12 at 08:04
    @SK-logic: Not really. C needs a runtime lib just like C++. The ABI can be controlled in C++ via `extern "C"` so it is C-compatible on the outside. Hence, you do have the internal advantages of C++ (higher type-safety, libraries) but the external advantages of C (de facto ABI standard) – MSalters Jul 20 '12 at 09:12
  • @MSalters, there's much less problems with C runtime than with C++ runtime (think of Android, for example). `extern "C"` is not that interesting, it will be a C API then, not C++. Try to provide a plain C wrapper API to the said Qt, for example. – SK-logic Jul 20 '12 at 10:41
  • @SK-logic: Qt doesn't have a pure C++ API to start with, you need to run their `moc` preprocessor first to generate C++ code. I'm not sure what problem you see with the Android C++ runtime (my company currently has a very big C++ app running on stock Android). – MSalters Jul 20 '12 at 11:06
  • @MSalters, there is a limited libstdc++ in Android. The best option is to link a full one statically, but in many cases it is not acceptable. It is more or less ok if you've got a single binary, but it is not nice for a library. Especially if there are some other libraries used as well, depending on potentially different versions of libstdc++. I've had all this issues with LLVM on Android (and its requirements are pretty modest, e.g., no RTTI or exceptions are needed). – SK-logic Jul 20 '12 at 11:14
    @SK-logic The unspecified ABI is simply a solved problem, see SWIG, Boost.Python and a host of other language bindings. – Konrad Rudolph Jul 20 '12 at 13:04
    @MSalters don't forget about exceptions and their general non-workiness across library boundaries – sehe Jul 20 '12 at 13:07
  • @KonradRudolph, unfortunately, SWIG is still too limited, not nearly a solution. I've already failed with trying to wrap Clang interface with it - and it is a pretty simple one. A really complicated, heavily templated C++ API cannot be wrapped into any decent, usable bindings automatically. – SK-logic Jul 20 '12 at 14:42
    -1 for C++ suggestion. C is easy, C++ makes things needlessly hard. – Ernest Friedman-Hill Jul 21 '12 at 01:18
24
There are pretty much 2 ways:
  • a C API. Practically ever language there ever was will load a C library and call its functions. How you do this depends on the source language.
  • a RPC mechanism of some sort. This can be a REST API running over HTTP, or a binary interface running over a socket. Unless you go for the lowest common denominator mechanism (eg a socket) you run the risk of not having client access routines (eg some languages do not have the right SOAP clients to call an API implemented using SOAP, or there are interoperability issues). Stick to the simplest, either a HTTP/REST interface, or a socket. Sockets have the advantage that they do not need a HTTP server to expose the interface to the clients, and can more easily run on the same server as the client with better performance.
The work required for this changes depending on the system used, for example, a socket interface will work, but client-side libraries tend to be more low-level compared to http libraries.
You could try finding a networking library that supports all the languages you want to use, and implement the API in terms of that library - eg, using ZeroMQ gives you a lot of flexibility, so you'd write your API using ZeroMQ interfaces, and then any language that wants to call your API must use the ZeroMQ client library to do so. Choose a library that supports a broad range of languages, and allows you to in-process as well as out-of-process communication for best performance.
gbjbaanb
  • 48,354
  • 102
  • 172
  • So what steps would I need to take if I wanted to write the API in multiple languages as well? (In my case, those languages would be Javascript, C++, and Java.) – Anderson Green Jul 22 '12 at 03:14
  • Should I just write 3 separate RESTful APIs for each of the languages? – Anderson Green Jul 22 '12 at 05:38
  • You write a native wrapper in each of these languages that handles the loading and calling the underlying C dll. Or write it in C++ and use SWIG to do this for you. If you're using a REST API, then the same applies, either write a single API and then 3 wrappers, but if you're writing a REST API then each language will be able to call the REST API directly - don't bother with a wrapper. – gbjbaanb Jul 25 '12 at 10:44
  • Would the dll (dynamically linked library) be compatible any platform besides Windows? I need cross-platform compatibility here. – Anderson Green Jul 25 '12 at 22:59
  • no, you'd need to recompile it for other platforms. Linux for example uses .so instead of .dll. Just a straight recompile is needed, no (or very minor) code changes. – gbjbaanb Jul 29 '12 at 13:52
If performance and call latency is not an issue, consider providing a comprehensive command line interface (probably, using a scripting language on top of it). ImageMagick can be a good example of such an "API". Another good example is Tk toolkit.
SK-logic
  • 8,497
  • Which scripting language and/or programming language would you recommend for the purpose of creating a command line foreign function interface? Also, have you found any concrete examples of such interfaces? – Anderson Green Jul 27 '12 at 03:34
  • @AndersonGreen, any language with decent metaprogramming is ok for such a purpose. E.g., Scheme, MetaLua, various other embeddable Lisps, Tcl. You can easily implement your own command language as well. Many CAD/CAE systems operate this way. An already mentioned Tk is another typical example. – SK-logic Jul 27 '12 at 08:15
  • In order to use a command-line interface in this way, would you get the console output for a specific command (such as `whoami` on Ubuntu to get the username), or did you have something else in mind? – Anderson Green Dec 13 '12 at 20:46
  • @AndersonGreen, piping stdin and stdout should be sufficient in most cases. – SK-logic Dec 13 '12 at 20:52
By API, what exactly do you mean?
On many platforms you could link to a DLL or similar construction, but would having to be re-compiled for a particular native target (Intel/ARM) or endianness still qualify? A particular binary interface might still have difficulties with certain languages because of datatype issues or constructs (pointers trying to be returned to languages which don't support them well), so you would also have to consider the design of the API itself so as not to exclude some languages or make its use from those languages cumbersome.
Something portable like C and an interface based on binary endpoints in a DLL might be fine and generally callable on most platforms and from most languages, but it might need to be compiled differently and/or offered in different flavors or linked to different static libraries.
It seems to me that the choice of language you write your library or service or whatever is, by definition, not intrinsic to the question until you've given more about the platform/service the API exposes. If you can assume a network stack is available and direct-linked function-call-level performance is not a requirement, the API could easily be HTTP-based with some kind of shim for the client language to make the requests transparent.
I think in general this question is overly broad to be useful in the real world, because you haven't given indication about what kind of API might be suitable given the type of service which is being offered.
Cade Roux
  • 904
To add to above answers that suggest using an RPC mechanism. You could use Apache Thrift.(http://thrift.apache.org/). It is basically a RPC framework.
As per the Thrift wiki:
The Apache Thrift software framework, for scalable cross-language services development, combines a software stack with a code generation engine to build services that work efficiently and seamlessly between C++, Java, Python, PHP, Ruby, Erlang, Perl, Haskell, C#, Cocoa, JavaScript, Node.js, Smalltalk, OCaml and Delphi and other languages
gnat
  • 21,442
  • 112
  • 288
gt5050
  • 121
Have any language write out a text file with function to call with params to pass in. Have your "I get along with anybody" app watching a directory and once it sees a process-call.txt have it go to work. No servers or network protocols; even a non-computer language method can init the functions. Even a person could just create the text file.
Content could look like:
Call-method:  fdisk()
Params:  (string) "/root", (string) "write-back-file-expected.txt"
;) you might wait forever to get an answer though. You just need to push a few bytes to the other process, but I'm sure that's not the whole spec.
  • Seems overly complicated when you could just have a command-line interface + stdin/stdout. – Brendan Long Jul 20 '12 at 16:15
    Even better call can ++1 that, Brendan. I never saw it in action but once upon a time people were punching holes in card to transfer the bytes around. – Pareshkumar Jul 20 '12 at 20:58
    This is a joke answer, right? We don't do that here. – Ernest Friedman-Hill Jul 21 '12 at 01:15
  • Well the fdisk and /root part is a joke, but the I was involved as a platform r&d (developer and analyst) for over 5 years to create a platform-product that produced good in the 10's of millions of dollars. It's spit out millions of shippable physical (not pdf and emails) items for client (with processing Files ranging in hundreds of MBs per item) using this type of REST method. We had major system triolgy-SAP-MS Office-PLC Drivewrs-PDF Workflow all taking to each other and working well together with plain-old-UTF-8-text files and a zip with-in a zip with-in a zip, and no HTTP bs overhead. – Pareshkumar Jul 21 '12 at 03:20
  • May I ask a question? Why does no one think that JSON is a joke? How is what I recomended any different? We would/might have used json but it wasn't around in 2003. XML is too fat, but back then that was the flavor of the month not the most pratical and simplest soulition. – Pareshkumar Jul 21 '12 at 03:35
  • Can you explain what you mean by a "non-computer language method?" – Anderson Green Jul 26 '12 at 19:58
  • I ment, even person who knew only english could invoke that call. One thing to think about very throughly is what is an API Call or invocation of a method (Hint: go back to goto: statement), start from the BASIC and PASCAL impl and see how they relate to modren day program paths including the word of the day REST! Once you fully understand not know that an API call is an Address Pointer, just like a variable or a reference to an object. At the end of the day you still pushing bits around, so for your solution I think you need figure out how you're going to push bits any lang to your api lang – Pareshkumar Jul 27 '12 at 23:10
  • better results = { "Content-Type" : "JSON", "HTTP-Method" : "Get", "Call-method" : "fdisk()", "Params" : "/root", "Call-back-method" : "write-back-file-expected.json" } – Pareshkumar Jul 27 '12 at 23:36
  • OP is looking for a suitable language to form a cross language API using some sort of language binding or framework. You're suggesting they implement a very slow and error prone file solution from scratch. Your answer is not within the scope of the question. – aj.toulan Oct 09 '19 at 18:17
OpenGL is a good example of what you describe - it's an API written in C, designed in a way that is easy to write bindings for in other languages
  1. C libraries can be called from most programming languages (usually as compiled extensions, or things like PyPy's ctypes library etc)
  2. All functions take simple data-types as arguments (boolean, integer, floating point, constants, arrays), as functions taking pointers can be awkward to translate into some languages
  3. Having it's own numeric data-types, which specify precision and signed'ness (whereas int float etc can differ)
The resulting API isn't necessarily the nicest-to-use C API you could write if targeting only C users. However it means the functions can be almost directly exposed to another language (e.g the PyOpenGL docs list the differences, most of which are pretty minimal)
On top of this verbose API, you can write more "developer friendly" wrappers around this (game frameworks and such)
dbr
  • 161
