53
This blogpost was posted on Hacker News with several upvotes. Coming from C++, most of these examples seem to go against what I've been taught.
Such as example #2:
Bad:
def check_for_overheating(system_monitor)
  if system_monitor.temperature > 100
    system_monitor.sound_alarms
  end
end
versus good:
system_monitor.check_for_overheating
class SystemMonitor
    if temperature > 100
      sound_alarms
    end
  end
end
The advice in C++ is that you should prefer free functions instead of member functions as they increase encapsulation. Both of these are identical semantically, so why prefer the choice that has access to more state?
Example 4:
Bad:
def street_name(user)
  if user.address
    user.address.street_name
  else
    'No street name on file'
  end
end
versus good:
end
class User
  def address
    @address || NullAddress.new
  end
end
class NullAddress
  def street_name
  end
end
Why is it the responsibility of User to format an unrelated error string? What if I want to do something besides print 'No street name on file' if it has no street? What if the street is named the same thing?
Could someone enlighten me on the "Tell, Don't Ask" advantages and rationale? I am not looking for which is better, but instead trying to understand the author's viewpoint.
Kazark
  • 1,810
Pubby
  • 3,290
  • 26
  • Code examples might be Ruby and not Python, I dunno. – Pubby Jul 20 '12 at 00:36
    I always wonder if something like the first example isn't rather a violation of SRP? – stijn Jul 20 '12 at 07:33
    You may read that: http://pragprog.com/articles/tell-dont-ask – Mik378 Nov 15 '12 at 01:12
  • Ruby. @ is shorthand for instance and Python ends its blocks implicitly with whitespace. – Erik Reppen Feb 27 '13 at 06:01
    "The advice in C++ is that you should prefer free functions instead of member functions as they increase encapsulation." I don't know who told you that, but it's not true. Free functions can be used to increase encapsulation, but they do not necessarily increase encapsulation. – Rob K Jul 23 '14 at 18:09
  • The second example looks weird to me because I don't see why sound_alarms should be a method on SystemMonitor. – Sebastian Redl Jan 13 '16 at 18:33
  • @RobK That advice comes originally from Sutter, and the original quote suggests preferring nonmember, nonfriends when possible. Friend functions would do no better for strengthening encapsulation than member functions, so it's specifically for nonfriends. He's basically defining the strength of encapsulation based on a class's ability to maintain invariants. If you have 10,000 member functions of a class that have access to its internals, the point of encapsulation (and its subset, information hiding) is largely defeated as so much of the codebase has access to the class's internals. –  Jan 13 '16 at 21:20
  • Yes, I was objecting to his mischaracterization of the Example 2 bad version as being the preferred form in C++. It's not the preferred form in C++ and I doubt Sutter would say it is. I love non-member non-friends and use them all the time. Defining interface is NOT where they should be used. – Rob K Jan 13 '16 at 21:42
  • " Both of these are identical semantically" That is not correct. *Semantically* they both depend on the *intention* behind the concept SystemMonitor. If system monitor is *intended* conceptually as being responsible for measuring physical quantities, such as temperature, and *also* acting on them, then the first example is indeed a poor implementation of that intention. If however your intention is that SystemMonitor be only responsible for supplying a realtime stream of data to say a SystemManager, then the first answer is correct. The other answers below are to some extent wrong in this. – Sentinel Apr 26 '18 at 20:51
9 Answers9
89
Asking the object about its state, and then calling methods on that object based on decisions made outside of the object, means that the object is now a leaky abstraction; some of its behavior is located outside of the object, and internal state is exposed (perhaps unnecessarily) to the outside world.
You should endeavor to tell objects what you want them to do; do not ask them questions about their state, make a decision, and then tell them what to do.
The problem is that, as the caller, you should not be making decisions based on the state of the called object that result in you then changing the state of the object. The logic you are implementing is probably the called object’s responsibility, not yours. For you to make decisions outside the object violates its encapsulation.
Sure, you may say, that’s obvious. I’d never write code like that. Still, it’s very easy to get lulled into examining some referenced object and then calling different methods based on the results. But that may not be the best way to go about doing it. Tell the object what you want. Let it figure out how to do it. Think declaratively instead of procedurally!
It is easier to stay out of this trap if you start by designing classes based on their responsibilities; you can then progress naturally to specifying commands that the class may execute, as opposed to queries that inform you as to the state of the object.
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
    The example text disallows *many* things which are clearly good practice. – DeadMG Jul 20 '12 at 01:38
    @DeadMG it does what you say only to those slavishly follow it, who blindly ignore "pragmatic" in the site name and key thought of [site authors](http://pragprog.com/about "Andy Hunt, Dave Thomas") that has been clearly stated in their key book: ["there is no such thing as a _best_ solution..."](http://programmers.stackexchange.com/a/157321/31260) – gnat Jul 20 '12 at 05:01
    Never read the book. Nor would I wish to. I only read the example text, which is completely fair. – DeadMG Jul 20 '12 at 05:46
    @DeadMG no worries. Now that you know key point that puts this example (and any other one from pragprog for that matter) in the intended context ("no such thing as a best solution..."), it's OK not to read the book – gnat Jul 20 '12 at 13:10
    I'm still not sure what Tell, Don't Ask is supposed to spell out for you without context but this is really good OOP advice. – Erik Reppen Feb 27 '13 at 06:10
    This made me think of [GRASP - *The Expert principle*](https://en.wikipedia.org/wiki/GRASP_(object-oriented_design)#Information_expert) – Chris Wohlert Apr 04 '17 at 11:54
  • This answer is not really correct. It depends on the intention of the concepts in the domain model. If SystemMonitor in the OP example is intended as both a *provider* of realtime metrics and a *decision maker* over them, then yes. If the SystemMonitor is intended as being a feed to a (say) SystemGovernor , then no. A clearer example of why the above blanket statement in the answer is too sweeping is the simple relationship between class Doctor and class Patient. – Sentinel Apr 26 '18 at 20:54
  • @Sentinel: It's just a principle. Like all other principles, you follow it when it makes sense to do so. – Robert Harvey Apr 26 '18 at 21:35
  • @RobertHarvey Yeah, well a poorly worded and misleading one. It should read 'put your methods where they belong'. The above answer instructs quite heavily that the method Diagnose should be placed on Patient, not Doctor. Even in OP, if the calling class was SystemManager, the advise in OP would be wrong and in above answer wrong too. 'Tell don't ask' as a tenet is nonsense. – Sentinel Apr 27 '18 at 04:36
    @Sentinel: You apparently don't understand the principle. – Robert Harvey Apr 27 '18 at 14:40
  • `Diagnosis = Doctor->Diagnose(Patient)`. – user3019105 Aug 29 '20 at 13:42
18
Generally, the piece suggests that you should not expose member state for others to reason about, if you could reason about it yourself.
However, what's not clearly stated is that this law falls into very obvious limits when the reasoning is way over the responsibility of a specific class. For example, every class whose job is to hold some value or provide some value- especially generic ones, or where the class provides behaviour that must be extended.
For example, if the system provides the temperature as a query, then tomorrow, the client can check_for_underheating without having to change SystemMonitor. This is not the case when the SystemMonitor implements check_for_overheating itself. Thus, a SystemMonitor class whose job is to raise an alarm when the temp is too high does follow this- but a SystemMonitor class whose job is to allow another piece of code to read the temperature so that it can control, say, TurboBoost or something like that, should not.
Also note that the second example pointlessly uses the Null Object Anti-pattern.
DeadMG
  • 36,794
  • 70
  • 139
    “Null object” isn’t what I’d call an anti-pattern, so I wonder what’s your reason for doing so? – Konrad Rudolph Jul 20 '12 at 07:04
    Pretty sure that nobody has any methods which are specified as "Does nothing". That makes calling them kinda pointless. That means that any object implementing Null Object breaks LSP, at the very least, and describes itself as implementing operations that it, in fact, does not. The user *expects* a value back. Their program's correctness depends on it. You simply bring more problems by pretending that it is a value when it is not. Have you ever tried to debug silently failing methods? It is *impossible* and nobody should ever have to suffer through that. – DeadMG Jul 20 '12 at 07:39
    I’d argue that this entirely depends on the problem domain. – Konrad Rudolph Jul 20 '12 at 08:27
    @DeadMG I agree that the above example is a bad usage of the Null Object pattern, but there *is* a merit to using it. A few times I've used a 'no-op' implementation of some interface or other to avoid null-checking or having true 'null' permeating the system. – Max Jul 20 '12 at 10:20
    Not sure I see your point with "the client can `check_for_underheating` without having to change `SystemMonitor`". How is the client different from `SystemMonitor` at that point? Aren't you now dissipating your monitoring logic across multiple classes? I also don't see the problem with a monitor class that provides sensor information to other classes while reserving alarm functions to itself. The boost controller should be controlling boost w/o having to worry about raising an alarm if the temperature gets too high. – TMN Jul 20 '12 at 13:26
    @KonradRudlph has a point. DeadMG, how is displaying, 'No street name on file' silent or failing? A null pointer exception would be better? How are you going to recover from that exception? The POINT of the null object pattern is to provide behavior that is constant with the system but rejects the premise of a question. It's the same thing the number 0 does in mathematics. If you hold up a fist and ask, "How many fingers am I holding up?" I use 0 as my way to say, "You aren't holding any fingers up" which is much better than saying, "You're question makes no sense. Please restart" – candied_orange Aug 01 '14 at 06:30
    By the way, if you've ever passed something an empty string "" you've used the null object pattern. – candied_orange Aug 01 '14 at 06:38
The real issue with your overheating example is that the rules for what qualifies as overheating are not easily varied for different systems. Suppose System A is as you have it (temp>100 is overheating) but System B is more delicate (temp>93 is overheating). Do you change your control function to check the type of system, and then apply the correct value?
if (system is a System_A and system_monitor.temp >100)
else if (system is a System_B and system_monitor.temp > 93)
end
Or do you have each type of system define its heating capacity?
EDIT:
system.check_for_overheating
class SystemA : System
      sound_alarms
    end
  end
end
class SystemB : System
    if temperature > 93
      sound_alarms
    end
  end
end
The former way makes your controlling function get ugly as you start dealing with more systems. The latter lets the control function be stable as time goes on.
Matthew Flynn
  • 13,345
  • 38
  • 57
    Why not have each system register with the monitor. During registration they can indicate when overheating occurs. – Martin York Jul 20 '12 at 19:47
  • @LokiAstari - You could, but then you could run into a new system that's also sensitive to humidity or atmospheric pressure. The principle is to abstract out what varies--in this case it is the susceptibility to overheating – Matthew Flynn Jul 20 '12 at 20:59
    This is exactly why you should have a tell model. You tell the system the current conditions and it informs you if it is outside normal working conditions. Thus way you never need to modify the SystemMoniter. That's encapsulation for you. – Martin York Jul 20 '12 at 23:40
  • @LokiAstari - I think we're talking at cross purposes here--I was really looking at creating different systems, rather than different monitors. The thing is, the system should know when it is in a state that raises an alarm, as opposed to some outside controller function. SystemA should have its criteria, SystemB should have its own. The controller should just be able to ask (at regular intervals) whether the system is OK or not. – Matthew Flynn Jul 21 '12 at 02:54
First off, I feel I must take exception to your characterization of the examples as "bad" and "good". The article uses the terms "Not so good" and "Better", I think those terms were chosen for a reason: these are guidelines, and depending on circumstances the "Not so good" approach may be appropriate, or indeed the only solution.
When given a choice, you should give preference to including any functionality that relies solely upon the class in the class instead of outside it -- the reason is because of encapsulation, and the fact that it makes it easier to evolve the class over time. The class also does a better job of advertising it's capabilities than a bunch of free functions.
Sometimes you have to tell, because the decision relies upon something outside of the class or because it is simply something you don't want most users of the class to do. Sometimes you want to tell, because the behavior is counter intuitive for the class, and you don't want to confuse most users of the class.
For example, you complain about the street address returning an error message, it isn't, what it is doing is providing a default value. But sometimes a default value isn't appropriate. If this was State or City, you might want a default when assigning an a record to a salesman or a survey taker, so that all of the unknowns go to a specific person. On the other hand, if you were printing envelopes, you might prefer an exception or guard that keeps you from wasting paper on letters that can't be delivered.
So there can be cases where "Not so good" is the way to go, but generally, "Better" is, well, better.
jmoreno
  • 10,640
This paradigm is sometimes referred to as ‘Tell, don't ask’, meaning tell the object what to do, don't ask about its state; and sometimes as ‘Ask, don't tell’, meaning ask the object to do something for you, don't tell it what its state should be. Either way around the best practice is the same — the way an object should perform an action is that object's concern, not the calling object's. Interfaces should avoid exposing their state (e.g. via accessors or public properties) and instead expose ‘doing’ methods whose implementation is opaque. Others have covered this with the links to pragmatic programmer.
This rule is related to the rule about avoiding "double-dot" or "double arrow" code, often referred to as ‘Only talk to immediate friends’, which states foo->getBar()->doSomething() is bad, instead use foo->doSomething(); which is a wrapper call around bar's functionality, and implemented as simply return bar->doSomething(); — if foo is responsible for managing bar, then let it do so!
Nicholas Shanks
  • 337
Data/Object Anti-Symmetry
As others pointed out, Tell-Dont-Ask is specifically for cases where you change the object state after you asked (see e.g. the Pragprog text posted elsewhere on this page). This is not always the case, e.g. the 'user' object is not changed after it was asked for its user.address. It's therefore debateable if this is an appropriate case to apply Tell-Dont-Ask.
Tell-Dont-Ask is concerned with responsibility, with not pulling logic out of a class that should be justifiably within it. But not all logic that deals with objects is necessarily logic of those objects. This is hinting at a deeper level, even beyond Tell-Dont-Ask, and I want to add a short remark about that.
As a matter of architectural design, you might want to have objects that are really just containers for properties, maybe even immutable, and then run various functions over collections of such objects, evaluating, filtering or transforming them rather than sending them commands (which is more the domain of Tell-Dont-Ask).
The decision which is more appropriate for your problem depends on whether you expect to have stable data (the declarative objects) but with changing/adding on the function side. Or if you expect to have a stable and limited set of such functions but expect more flux at the objects level, e.g. by adding new types. In the first situation you would prefer free functions, in the second object methods.
Bob Martin, in his book "Clean Code", calls this the "Data/Object Anti-Symmetry" (p.95ff), other communities might refer to it as the "expression problem".
ThomasH
  • 149
In addition to the other good answers about "tell, don't ask", some commentary on your specific examples that might help:
That choice does not have access to more state. They both use the same amount of state to do their jobs, but the 'bad' example requires the class state to be public in order to do its work. Further, the behavior of that class in the 'bad' example is spread out to the free function, making it harder to find and more difficult to refactor.
Why is it the responsibility of 'street_name' to do both 'get street name' and 'provide error message'? At least in the 'good' version, each piece has one responsibility. Still, it's not a great example.
Telastyn
  • 108,850
  • 239
  • 365
    That's not true. You presume that checking for overheating is the only sane thing to do with the temperature. What if the class is intended to be one of a number of temperature monitors, and a system must take different action depending on many of their results, for example? When this behaviour *can* be limited to pre-defined behaviour of a single instance, then sure. Else, it obviously can't apply. – DeadMG Jul 20 '12 at 01:47
  • Sure, or if the thermostat and the alarms existed in different classes (as they likely should). – Telastyn Jul 20 '12 at 01:53
    @DeadMG: The general advice is to make things private/protected until you need access to them. While this particular example is meh, that doesn't dispute the standard practice. – Guvante Jul 20 '12 at 17:50
  • An example in an article *about the practice* being 'meh' kinda disputes it. If this practice is standard because of it's great benefits, then why the trouble to find a suitable example? – Stijn de Witt Mar 15 '16 at 23:09
These answers are very good, but here's another example just to emphasize: note that it's usually a way to avoid duplication. For example, let's say you have SEVERAL places with a code like:
Product product = productMgr.get(productUuid)
if (product.userUuid != currentUser.uuid) {
    throw BlahException("This product doesn't belong to this user")
That means you'd better have something like this:
Product product = productMgr.get(productUuid, currentUser)
Because that duplication means most clients of your interface would use the new method, instead of repeating the same logic here and there. You give your delegate the work you want done, instead of asking for the info you need in order to do it yourself.
I believe this is more true when writing high-level object, but less true when going down to the deeper level e.g. class library as it's impossible to write every single method to satisfy all class consumers.
For example #2, I think it is over-simplified. If we were actually going to implement this, the SystemMonitor would end up having the code for low level hardware access and logic for high level abstraction embedded in the same class. Unfortunately, if we are trying to separate that into two classes, we would violate the "Tell, Don't ask" itself.
The example #4 is more or less the same -- it's embedding UI logic into data tier. Now if we are going to fix what user wants to see in case of no address, we have to fix the object in data tier, and what if two projects using this same object but need to use different text for null address?
I agree that if we can implement "Tell, Don't ask" for everything, it would be very useful -- I myself would be happy if I can just tell rather than ask (and do it myself) in real life! However, as same as in the real life, the feasibility of the solution is very limited to high level classes.
tia
  • 965
