I'm studying YAML as a replacement for XML, but I'm experiencing difficulties when dealing with elements containing free-flowing text with embedded elements. For instance, the following XML document:
    <text>
    This is an example text, spanning multiple lines, and it has embedded elements
    like <a p="value">this</a> and <b>this</b>.  There is also a list:
         <quote>
            <text>The text of the quote, spanning multiple lines, and it has
            embedded elements like <c p="value">this</c> and <b>this</b></text>
            <author>The Author of this quote</author>
        </quote>
    Text continues here.
    </text>
I don't know how to convert the embedded elements in YAML. My understanding is that the above XML document segment translates to something like this (except for the embedded elements):
    text: >
            elements like <a p="value">this</a> and <b>this</b>.  There is also a
            list:
                 quote:
                    text: >
                            and it has embedded elements like <c p="value">this</c>
                            and <b>this</b>
                    author: The Author of this quote
Also, is indentation not needed in some places?
Anthon
  • 228
Eleno
  • 133
The YAML website describes YAML in the following terms:
YAML: YAML Ain't Markup Language
What It Is: YAML is a human friendly data serialization
  standard for all programming languages.
You probably don't want YAML for this. YAML is meant to be used to save data out to files for future retrieval, basically as a form of serialization. The major benefit it has over XML in this regard is the fact that he lacks the clutter of XML's angle brackets and end tags. It's easy to read and edit for humans. XML, on the other hand, is already designed to work with an HTML-like syntax. XML's major purpose is as a markup language.
You could look at it this way:
  • Use YAML when you want to save text or objects to a file.
  • Use XML when you want to provide markup for documents
KChaloux
  • 5,773
  • 35
  • I though YAML had the same capabilities as XML, but with a light-weight syntax similar to text. If I have to resort to quoted strings and the likes, then I misunderstood its use. Thank you. – Eleno Jul 19 '12 at 15:27
  • It has similar capabilities, but it's primarily meant for modelling object data, NOT marking up websites. It was basically created to make it easier to do the sort of config files and data storage that people were *trying* to do with XML (which was never XML's intended purpose) – KChaloux Jul 19 '12 at 16:53
  • So the answer is: what I'm trying to do cannot be done. Thanks. – Eleno Jul 19 '12 at 18:15
    It probably CAN be done, with enough futzing and fiddling. I just don't think YAML is particularly suited for the task. – KChaloux Jul 19 '12 at 19:14
If an XML/HTML/SGML parser, for some programming language X, generically parses your kind of input (instead of generating abstracted objects), you normally have the tags translated to the mapping construct for X, with the children tags and string elements as a sequence construct for X (as these need ordering), with the attributes of the tag some special first element of that sequence (if attributes are available).
Such a hierarchy is a perfect match for YAML¹:
text:
  like
- a:
  - .attribute:
      p: value
  - this
- and
- b: this
- '.  There is also a list:'
- quote:
  - text:
    - c:
      - .attribute:
          p: value
      - this
    - and
    - b: this
  - author: The Author of this quote
- Text continues here.
The literal block has been used here to preserve newlines in the original data, but folded could be used as well.
This YAML can be used to regenerate the orginal XML/HTML/SGML structure except for some stripped and collapsed white-space information, which normally do not affect e.g. rendering of HTML. The above YAML is not the representation of XML/HTML/SGML in YAML, just one of the possible ways of doing that.
As for your second question:
As you can see from the output, indentation is not always needed, the sequence elements under the key text: are not indented. But if you outdent, then you always end a collection (sequence/mapping).
¹ This is the output of yaml from-html --no-body input.xml with input.xml containing your XML document. yaml is a command that is part of my python package ruamel.yaml
Anthon
  • 228
