I'm curious about the birth of the compiler. How did programming begin? Did people first build hardware that recognized a certain set of commands, or did people define a language and then build hardware around it? And on a related note, what was the first programming language?
6A similar question is [Who created the idea(s) of the first loop constructs?](http://programmers.stackexchange.com/q/149465/1033). It includes a [great answer about history of computing](http://programmers.stackexchange.com/a/149484/1033). – mouviciel Jul 09 '12 at 09:47
2One of the sub questions was a question in it's own right: [What was the first programming language written for computers?](http://programmers.stackexchange.com/q/141356/22493). – Mark Booth Jul 09 '12 at 16:42
Surely this is something you could [look up](http://en.wikipedia.org/wiki/Compiler#History)? – Caleb Jul 09 '12 at 20:02
@Caleb read the comments in SkyDan's answer.. – David Cowden Jul 09 '12 at 20:44
+1 Star, I don't know which is better, the insightful expert advice, or the eeery feeling that there is about to be a chicken vs. the-egg smacdown here... well done. – Jack Stone Jul 10 '12 at 03:25
This strikes me as a chicken and egg problem. Wouldn't a language and accompanying compiler be developed in Tandem? You might argue that the source code came first (writing a compiler involved having a source code specification, in your head or otherwise, and writing a compiler in machine language which could translate that code into assembly), but source code without a compiler is not so meaningful outside of academia. – Brian Jul 11 '12 at 17:59
2@Brian Valid assumption, but turns out to be wrong. It’s not a chicken-egg problem at all, there’s a very clear answer (hint: the most highly voted below is wrong). Source code *long* predates compilers. – Konrad Rudolph Jul 11 '12 at 20:09
This has a very clear answer, actually: Source code came first – by a big margin.
Before giving the technical details, a bit of perspective:
The first programming languages were all translated into machine language or assembler by hand. The idea of using a piece of software to automate this translation (either via a compiler or evaluator) always came later, and was far from intuitive.
Consider this quote of the Wikipedia article on FORTRAN which illustrates the reluctance compilers had to face:
… the first FORTRAN compiler [was] delivered in April 1957. This was the first optimizing compiler, because customers were reluctant to use a high-level programming language unless its compiler could generate code whose performance was comparable to that of hand-coded assembly language. [emphasis mine]
=> By the time the FORTRAN compiler hit the market (1957), people were already happily programming both in assembly language and FORTRAN.
The case was similar for LISP (from Hackers & Painters):
Steve Russell said, look, why don't I program this eval …, and I said to him, ho, ho, you're confusing theory with practice, this eval is intended for reading, not for computing. But he went ahead and did it. That is, he compiled the eval in my paper into IBM 704 machine code, fixing bug, and then advertised this as a Lisp interpreter, which it certainly was. So at that point Lisp had essentially the form that it has today..."
Once again, not only does the source code (in LISP) predate the interpreter, the latter wasn’t even implicit in the former.
But these developments are relatively late. Even not considering Charles Babbage’s Analytical Engine and Ada Lovelace’s related first program, there were programming languages in the 20th century which predated compilers:
Konrad Zuse’s Plankalkül and the mathematical construct of λ-calculus introduced by Alonzo Church. Both of these are indubitably formally specified programming languages, but neither had a compiler at the time.
To put this into perspective, λ-calculus is from the 1930s, and Plankalkül was developed around 1945. By contrast, the first FORTRAN compiler came out in 1957 (but again three years after FORTRAN was specified).
- 13,059
- 4
- 55
- 75
Great answer! I didn't know code used to be compiled by hand, but that makes sense. – ckb Apr 24 '13 at 15:32
Programming began with people writing machine code directly into memory, onto punched cards and paper tape or even shorting links on a patch panel. Whether the hardware was built around the needs of the software or vice versa is difficult to tell. Certainly the earliest design for a turing complete programmable computer, Babbage's Analytical engine, pre-dated Ada Lovelace's first documented program.
As to the first programming language, I have argued that it was the machine language of Babbage's analytical engine (from the question What was the first programming language written for computers?)
To answer the question in your question title, since assembly language is source code, and assembly languages pre-date high level languages which could be compiled into assembler, the source code came first.
Also, a compiler has never been necessary, just convenient.
It is perfectly possible to write software directly into memory if you have memorised the appropriate op-code tables. In fact, some early computers required the user to punch in the bootstrap code on the front panel hex keypad to get them to boot, but you could tap in any code you liked and it would be run.
Admittedly as CPU's get more complex, this gets more difficult, but a simple instruction set like 6809, or Z80 (ignoring all the weird indexed modes) is relatively easy to program even without an assembler, let alone a compiler from a high level language.
If Babbage's analytical engine had ever been built, I'm sure there would have been a steampunk Mel, writing optimised programs directly onto loom cards.
- 14,214
- 3
- 40
- 79
1Did you actually read the definition of source code at that wikipedia link you posted? As said above, machine code is not source code. And machine code != assembly. Machine code was there first. – occulus Jul 09 '12 at 13:47
4@occulus - In what way is *assembly language* not *source code*? Assembly language maps one assembly language instruction to one machine code and can be trivially *assembled* in your head, *if* you know your op code tables. Honestly, kids these days... *8') – Mark Booth Jul 09 '12 at 15:02
1To me, *assembly language* is `movl $0, -20(%rbp)`, whereas *machine code* is `C745EC00000000`, and it's the latter (well, something like it) that was first manually entered or read from paper tape. As to whether *machine code* counts as *source code*, I'm inclined to say "whatever floats your boat". If you're toggling it in manually, then yeah, I'd say it counts. – John Bode Jul 09 '12 at 15:55
@JohnBode - Oh I agree, but given the 1:1 correspondence between assembly instructions and machine code instructions, assembly is just a matter of mechanical translation (assembly), the logic is identical. Compilation implies a much more complex many:many translation (though [Occam](http://en.wikipedia.org/wiki/Occam_%28programming_language%29) is a high level language and many Occam statements mapped 1:1 onto [Transputer](http://en.wikipedia.org/wiki/Transputer) instructions due to its [MISC](http://en.wikipedia.org/wiki/Minimal_instruction_set_computer) architecture. *8'). – Mark Booth Jul 10 '12 at 09:40
The compiler was first. It was directly written in machine code, for the source could not be compiled without a compiler.
Wikipedia articles like this one about Computer Languages can answer most of the questions. If not, just pick one of the books by Tanenbaum, like Structured Computer Organization , which can answer more questions than you can even ask :)
I can not say anything more specific, for your question is too broad.
- 321
- 2
- 10
21It could also be argued that the source was first, because for the very first "computers" the source was equivalent to the binary (i.e. they were programmed directly in the machine-readable language). – Joachim Sauer Jul 09 '12 at 09:44
5@Joachim By definition, source code is human-readable text that is translated by the compiler into machine code. Machine code itself therefore is not source code. – hellodanylo Jul 09 '12 at 09:46
11The compiler was first, but it was implemented in biological neural networks. – Den Jul 09 '12 at 10:00
@Den - Not really, because by definition a compiler works on human-readable code. Thoughts and patterns in ones own biological neural network don't count as human readable. – occulus Jul 09 '12 at 13:55
1@SkyDan My question isn't really that broad.. I asked two questions, what came first, and what the first programming language was. Both can be answered with one or two concise paragraphs. – David Cowden Jul 09 '12 at 14:53
2@SkyDan: *source code is human-readable text* could still be quite subjective. If I had learned to read in binary, wouldn't machine code then be considered human readable? Albeit, quite contrived, it doesn't matter what is human readable, a human had to write some source for something to work - even if it was a compiler. – IAbstract Jul 09 '12 at 15:11
@IAbstract Binary still can not be source code by definition for it's not compiled for some target platform. It's directly executed by the target platform. – hellodanylo Jul 09 '12 at 16:21
1@David Honestly, it will take you 3-5 minutes to find the answers to your questions in Wikipedia by just googling them. I don't see any reasons for copying Wikipedia here. – hellodanylo Jul 09 '12 at 16:23
2@SkyDan that can be said for 97% of all questions on stackexchange.com.. The point of these sites is to have a repository of interesting questions with useful answers. Of course we can all Google answers, but sometimes people here provide really interesting insight that you don't often get in a strictly factual Wikipedia article. If it is such a waste of your time to answer the question then why even bother in the first place? – David Cowden Jul 09 '12 at 16:44
2@David I am new here. I might be wrong. But I feel like questions that are preferred as those that require synthesizing information from different sources. Cross posting Wikipedia just engages people to be lazy and to ask simplest questions instead of doing research. – hellodanylo Jul 09 '12 at 16:51
@SkyDan I'm certainly not asking you to cross post Wikipedia if you don't want to. If you don't have any authoritative knowledge on the topic, or can't add anything that Wikipedia already covers, then tough, perhaps you are not the best one to answer the question. Sometimes people know of very good documents, books, articles, and snip-its of information that a typical Google search or Wikipedia article doesn't provide -- heck, a CS PhD who's focus is compilers might even answer.. – David Cowden Jul 09 '12 at 17:27
@SkyDan and don't get me wrong, I'm happy you answered and provided Wikipedia links. This type of answer is also completely valid for some questions -- it's really up to the asker whether their question is answered right? I'm not trying to discourage you. I'm just saying that complaining because *you* think Wikipedia is sufficient for me is not really helpful. – David Cowden Jul 09 '12 at 17:30
9Why is this so highly voted? It’s wrong. Source code in high-level languages (notably λ-calculus, Plankalkül and LISP) long predates both compilers and interpreters. This isn’t even taking into account the semi-formal programs Ada Lovelace wrote. – Konrad Rudolph Jul 11 '12 at 20:01
@Konrad, this actually a matter of definition. With your definition, my answer is wrong, with mine - yours. – hellodanylo Jul 12 '12 at 04:44
5@SkyDan What’s your definition then? I know of no sensible definition for which your answer is correct (both for “compiler” and “source code in a high-level language” – let alone low-level). – Konrad Rudolph Jul 12 '12 at 06:54
Interpreters existed before compilers so source code existed before compilers.
There are some very interesting papers on the history of computing here. The source code for the FORTRAN II compiler is supposed to be available, but those links are broken.
This paper, from 1954, describes the Whirlwhind interpreter.
- 666
- 5
- 7
This question is pivots strongly on our semantic interpretation of 'source code'. If we define it as 'text-based computer instructions that are compiled', then presumably a compiler came first.
I'm more inclined to go with something more authoritative, such as Mark Harman's paper "Why Source Code Analysis and Manipulation Will Always Be Important" presented at the Tenth IEEE International Working Conference on Source Code Analysis and Manipulation
Definition 1 (Source Code): For the purpose of clarity ‘source code’ is taken to mean any fully executable description of a software system. It is therefore so construed as to include machine code, very high level languages and executable graphical representations of systems.
And I think your answer is implicit in that definition - source code most certainly came first.
- 4,199
- 18
- 27
“presumably a compiler came first” – only if you define “compiled” as “translated by an automatic tool”, rather than “translated to machine code by hand”. – Konrad Rudolph Jul 12 '12 at 15:06
Very interesting paper. I like that definition of source code -- although it makes my question a non-question really.. – David Cowden Jul 12 '12 at 18:33
@KonradRudolph isn't the unit that performs compilation, whether it's a machine, human, or divine intervention, called 'a compiler'? – Kirk Broadhurst Jul 12 '12 at 23:37
The algorithms were sorted out on paper, then the alus were wired up physically/mechanically (moving wires). to change the program you move the wires and run again.
Later the assembly language sorted out on paper, translated to machine code by hand, then using switches, etc to feed it into ram. Or punch cards, etc. Eventually you can make an assembler, then you can program in assembly not machine code, then you can make a compiler. Eventually you can bootstrap that compiler. And make new languages and new compilers, etc.
The first language was not a language, later the first language was assembly language. for every processor the first language is assembly language (derived from the machine code). The instruction set is designed first then the hardware to implement it then assembler, then compilers.
- 969
- 5
- 8
