Possible Uses
Fast Prototyping
You could do this with Groovy or others, so that's not a very strong point, but as CRaSH gives you code-level access to the JVM and the processes it runs, it may come in handy to just keep a JVM running and experiment with small code snippets (for instance, using it as a REPL to implement solutions to StackOverflow questions).
The JCR extension would seem potentially useful to supplement this, by giving you shell access to remote repositories, and contains a notion of workspace to separate projects.
Interacting with a Running Process
I could see this being an interesting use case. I don't know of many good process inspection command-line tools for JVM processes, apart from the JDK-packaged ones. CRaSH might help in interacting with them in novel ways.
For instance, you can use the Attach Mode to attach to a running JVM, and then use the thread
command to ls
, dump
or interrupt
threads.
You could also write some additional control commands for non-programmers to use CRaSH to perform routine maintenance and monitoring.
Content Repository Management
The JCR extension seems to be very interesting as well, as it would give a Java-scriptable access to remote development environments. It could also simply allow content-editors to access and edit remote content, when used in the context of CMS-type apps built on top of a JCR-capable content repository.
What Others Say About CRaSH
Summary
Basically, I see it as a power-user or administrator interface to JVM processes, built on top of Groovy and networking protocols. So it combines the power of scripting with a nice facade and some built-in connectors.
Note on Flexibility
I agree with SK-logic: most of this can be done with most JVM-languages, and they provide more and flexibility. But CRaSH might provide a shorter path to achieving such goals.
The same applies to the JCR extension capabilities: you can achieve this by glueing together a few age-old and time-tested tools. But this might be a shorter and simpler path (like commands for the heroku platform, or PaaS services, for instance).
