Possible Duplicate:
Why not Spring framework?
I've read numerous articles about the Spring MVC framework, and I still can't see the benefits of using it. It looks like writing even a simple application with it requires creating a big hodgepodge of XML files and annotations and other reams of code to conform to what the framework wants, a whole bunch of moving parts to accomplish a simple single task.
Any time I look at a Spring example, I can see how I can write something with the same functionality using a simple servlet and template engine (e.g. FreeMarker, StringTemplate), in half the lines of code and little or no XML files and other artifacts. Just grab the data from the session and request, call the application domain objects if necessary, pass the results to the template engine to generate the resulting web page, done.
What am I missing? Can you describe even one example of something that is actually made simpler with Spring than using a combination of raw servlets with a template engine? Or is Spring MVC just one of those overly complicated things that people use only because their boss tells them to use it?
EDIT: A summarized concrete description would be helpful. For example, "I used Spring MVC to build an application that did XYZ, and its feature Q saved me from having to do the extra work of A and B and C which would have been necessary with raw servlets and a template engine." Simply mentioning marketing buzzwords like "dependency injection" doesn't clarify anything.
