115
I was wondering if anyone knows what is the operating system used in commercial airplanes (say Boeing or Airbus).
Also, what is the (preferred) real-time programing language? I heard that Ada is used in Boeing, so my question is - why Ada? what are the criteria the Boeing-guys had to choose this language? (I guess Java wouldn't be a great choice if exactly on lift-off the garbage collector wakes up).
gnat
  • 21,442
  • 112
  • 288
adhg
  • 1,149
    When I first saw this question I thought it was asking about the systems that run the in-flight movies and such in the backs of seats. I was once on a Delta flight where they rebooted that system and you could tell that it was running Linux, a Debian variant I believe. – Kris Harper Jun 18 '12 at 12:28
    @root45: ahhhhhh... I admit it didn't even cross my mind. Could have been. I've seen some run some QNX I think, and others run Windows Embedded. – haylem Jun 18 '12 at 13:03
  • @haylem I'm sure your interpretation was correct, but looking at the title I wasn't sure. Nice answer, very enlightening. – Kris Harper Jun 18 '12 at 13:04
    "What kind of operating system does it use?" "I think it's Vista." "We're going to die!" – StuperUser Jun 18 '12 at 15:42
  • I haven't heard about Java being used either, but just FYI it *is* possible to run Java in "real-time mode", which will prevent mid-takeoff pauses :-) – Oak Jun 18 '12 at 17:47
  • @Oak: Java? In real...[garbage collection]...[garbage collection]...time? Not likely to happen for non-critical systems. (I'm aware of the JavaRT attempts, but I doubt those would be used for the in-flight entertainment terminals) – Piskvor left the building Jun 18 '12 at 19:39
    @StuperUser: One of my favorite I.T. Crowd episodes. (http://www.youtube.com/watch?v=8y4akOH8v8Q - 2:34 minutes). Also, not just commercial airlines, but it would be interesting to know more about what military aircraft use, if it's not the same. Vista, lol. – Bratch Jun 18 '12 at 22:04
    @Piskvor: there are real-time VMs for Java (as in the language, not the platform). I don't know if JavaRT variants have been used for serious (and inhabited) flight systems, but I've seen it used for models or drones. – haylem Jun 19 '12 at 10:39
  • I once worked on an aircraft subsystem and it ran Ada. – Engineer2021 Jun 21 '12 at 18:03
  • Java will never be certified to run on an airline. We can all be thankful for that. –  Nov 21 '12 at 17:14
  • Related: [Assembly Language being used in Aircraft System](http://programmers.stackexchange.com/questions/170969/assembly-language-being-used-in-aircraft-system/17097) – user16764 Nov 21 '12 at 17:30
  • @Bratch +1 for the video :) – Tsvetomir Dimitrov Jan 04 '13 at 14:48
Avionics
For aircraft control systems, we don't speak of operating systems but of avionics, integrated avionics or computer airborne systems in general. And they are actually a combination of a multitude of independent or inter-dependent systems, for different functions (flight control, collision avoidance, weather, communications, blackboxes...).
Each controller is usually an independent module (hardware and software) for obvious security and safety reasons: they are critical control and monitoring systems and if one of them were to fail or get damaged, it's a rather big "inconvenience" for the people which are depending on the aircraft. Dependability takes all its meaning when you are in the flying machine. So usually it's
  • custom built for the purpose of their mission,
  • built to work independently and interface with other systems,
  • built to be fault-tolerant to its own failures AND to failures of the other systems it's interfaced to (because you don't want the pilot's sound system taking down the engine controls, for instance).
It's not a big computer running everything. If you think of it from the perspective of a military aircraft rather than a commercial one (though it's similar in this respect, the image might help): if a part gets shot at, you'd rather at least have some other parts be able to keep going (the part controlling the communications and safety systems might be interesting to keep alive...). Hence also the big bunch of buttons you see in jetliners, to keep track of the status of different systems.
They are usually either built as custom components operating their own system, or they are run and scheduled by a micro-kernel (in most cases, with support for real-time capabilities).
It depends across vendors and countries, obviously, but they usually at least need to follow rather strict sets of regulations, design requirements and protocol specifics, which allow for:
  • the control of their strict-compliance to security and safety standards,
  • the inter-communication with other systems (much better if that airplane you took off with in Reykjavik can "talk" to that ground-control equipment in Tokyo...)
Standardization Efforts
The DO-178B (revised in 1992) and its successor the DO-178C (revised in 2012) (and a bunch of associated documents) are an example of reference certifications for such compliance levels, and are recognized by the FAA (US), the EASA (EU), and Transport Canada, amongst others. Multiple other organizations are involved in the creation of such documents, like the EUROCAE.
Such airborne systems are usually bespoke software, but the following systems are known to be used in some airplanes:
To give you a vague idea of elements built into an avionics system, this list of avionics acronyms points to some of them (with some overlap).
Notable Languages used in Commercial and Military Avionics
Apart from the usual suspects we know in the "mainstream" programming world, you'll come up some often referenced names like Ada, and some less known languages like the (dated and now "retired" since 2010) JOVIAL.
Related StackExchange Questions:
haylem
  • 28,856
  • 103
  • 119
    @mattnz: Thanks. But it's honestly a bit far from what the OP is asking. I tried to provide useful insight and pointers for documentation purposes, but when it comes to actual implementation details it's harder to find hard data. – haylem Jun 18 '12 at 04:43
  • "And they are actually a combination of a multitude of independent or inter-dependent systems" do you mean there is seperate hardware for these? – stijn Jun 18 '12 at 09:53
    Yes, they tend to be purpose built hardware. There isn't a rack of x86 pcs running your aircraft. – Rig Jun 18 '12 at 12:04
    @stijn: Well, yeah. Think of it this way. They are **critical** control and monitoring systems. If one of them fails, that means big freakin' problem, with a super big F and less polite than that. So usually it's a) custom built for the purpose of their mission b) built to work independently and interface with other systems c) built to be fault-tolerant to its own failures AND to failures of the other systems it's interfaced to (because you don't want the pilot's sound system taking down the engine controls, for instance). It's not a big computer running everything. – haylem Jun 18 '12 at 12:43
  • @stijn: Think of it from the perspective of a military aircraft rather than a commercial one, if that helps: if a part gets shot at, you'd rather at least have some other parts be able to keep going (I'd say the part controlling the communications and safety systems might be interesting to keep alive...). Hence also the big bunch of buttons you see in jetliners, to keep track of the status of different systems. – haylem Jun 18 '12 at 12:45
  • @Rig: indeed. Well I guess you could x86-based microcontrollers, for all I know. I don't really know what hardware specs they use. I assume some vendors use some "retail" parts to a certain extent, but I'd assume a lot of the hardware itself is pretty much engineering in-house or in partnership with hardware vendors, as they have pretty specific needs. – haylem Jun 18 '12 at 12:46
  • For what it's worth we use QNX in our flight simulators to run the avionics instruments (and if you're interested, C# running on Windows for the PC part). – Blindy Jun 18 '12 at 14:37
  • @haylem. Great answer; you should have integrated your comment to stijn as well. Thanks! +1 & accepted answer – adhg Jun 19 '12 at 00:29
  • About the programming languages: In such safety-critical systems it's a common practice the same software parts to be written using different programming languages (eg. one version in Ada and one in C++) by different programming teams. The redundancy focuses on the importance of the human factor and emphasizes on using different tools to solve the same problem as a way of writing "better" (for example faster, with less bugs, cleaner, more fault tolerant, etc.) code. Here's a related se-radio [podcast](http://www.se-radio.net/2008/06/episode-100-software-in-space/) – sakisk Dec 04 '12 at 20:30
  • Also for each component there is a backup. And for each backup there is another backup – Kemoda Jun 24 '13 at 09:14
  • answer is a bit too general. Can you specify for example for the big commercial leaders (ie. Boeing/Airbus), what OSes they run (at least in SOME of their computers) ? because I don't think that will change between countries and companies that own them :). – Matt Sep 22 '17 at 08:21
23
Most modern aircraft use a general purpose RTOS (realtime operating system) pretty much the same thing that is used in factory automation, power stations, ships etc
Airbus use a few, including INTEGRITY from Northrop-grumman and program it in C/C++, Boeing use VxWorks among others
Martin Beckett
  • 15,776
  • 42
  • 69
    The statement "...general purpose RTOS..." trivializes what it takes for an RTOS to make it into an avionics system, it's hardly the same RTOS thats using in ACME Corps Digital TV Reciever . – mattnz Jun 18 '12 at 04:08
    No but VxWorks can be used for anything from a Mar Rover to your Blackberry phone – Martin Beckett Jun 18 '12 at 04:52
  • Sorry it's QNX that is used in Blackberry, not VxWorks. But the same principle applies - COTS rtos's can be used in aircraft – Martin Beckett Jun 20 '12 at 14:22
12
For what it's worth: For spacecraft (satellites and interplanetary ones) C and C++ is still dominant (and with very strict compliance to ISO standards), generally running VxWorks. Labs will generally stick with either C or C++ based on developer familiarity, confidence in the compiler toolchain, and internal coding standards. There are compelling reasons for both languages for real-time flight software, but each organization tends to stick with one or the other. Ancillary instruments, on the other hand, are commonly programmed in Forth, C, and increasingly modern scripting languages like Lua.
Bill
  • 609
    Usually it's also a subset of C or C++, like MISRA C or JSF C++, as far as I've read. – Coder Jun 18 '12 at 17:43
Also worth noting that the control systems are often developed using model-based-design using Simulink. The design is then converted into C code automatically. Humans still read and validate the code.
Ben Martin
  • 201
  • My professor indeed mentioned it when talked about critical systems in Software Engineering. – Dielson Sales Jan 11 '13 at 19:28
  • I believe Airbus uses [SCADE](http://www.esterel-technologies.com/products/scade-suite/) for the functional specification of the hardware and software in their flight control systems. The tool can generate either C or Ada code. – dodgy_coder Aug 21 '14 at 04:30
