This post is a follow up to this question: PHP Atomic Memcache on StackOverflow.
Considering I am using Memcache (no d at the end) on PHP 5.3.10, I implemented a custom locking system where a client will wait until a lock key is destroyed before it begins to modify a key on memcache.
So:
Client 1 connects, checks for an active lock on key 1, finds none, and gets the data
Client 2 connects a few microsecond after Client 1, requests the same data from key 1,
but finds a lock
Client 2 enters a retry loop until Client 1 releases the lock
Client 1 saves new data to key 1, releases the lock
Client 2 gets the fresh data, sets a lock on key 1, and continues
This works 90% of the time. It would work 100% of the time if two requests are made far apart from each other (say 500ms). But lets say two requests are made at almost the same time (10 to 100 microseconds apart) the above solution fails, and both clients write to the same key, resulting in incorrect data.
I have tried many things, including a loop that varies in wait time every iteration:
while(/*lock key exists*/)
usleep(mt_rand(1000,100000);
This helps only a little.
What would be the solution to this particular issue? These mecache processes must be atomic. I am willing to tolerate a 1% failure rate (since it means I just need to work a little harder to make it 0), but anything more is just too risky.
I've broken my head trying to figure this out. There is no possibility to upgrade to Memcached, and the value changes are not simple (they are not increments)
